Old 11-08-2010, 12:04 AM
markobb markobb is offline
Mein Auto: Z3Q, 2.8L, 1999/2
Loose handbrake?
I got loosy handbrake, when i pul it it has some gap before it actualy grabs a disc on the wheels, how can i loose this gap?
Old 11-08-2010, 02:24 AM
EOD Guy's Avatar
EOD Guy EOD Guy is offline
Mein Auto: 98 Z3 // 06 X5
remove the boot on the handle and adjust the nuts.
Old 11-08-2010, 04:03 AM
Boot?
Old 11-08-2010, 04:10 AM
SUNZOUT SUNZOUT is offline
Mein Auto: '00 M Roadster
the handbrake Handle between the seats....pop the leather cover off and you will find the end of the cables with adjusters on them
TC Kline S/A Coilovers | Sharked | Turner Slotted Rotors | Axxis Ultimate Pads | SS Front Strut | IE Subframe Bushings | IE Rear Toe/Camber Kit
Whalen Shift Machine | Stygar Clutch Pedal | CDV Delete | LeatherZ Armrest | Whalen seat bushings | Z3Solutions Windblocker | Shift Pin fix
Old 11-08-2010, 07:25 AM
Randy Forbes's Avatar
Randy Forbes Randy Forbes is offline
Investigative Tinkerer
Mein Auto: ///Motorized Vehicles
Boot, nuts...
Note that these nuts were completely removed to replace the individual cables, something you wouldn't need to do to just adjust them.
http://www.rfdm.com/gallery/album161?page=35
Randy Forbes
1957 Austin-Healey 100/6 Wine Red
1961 McCulloch R1 go-kart Screaming Yellow
1999///M Rdstr Cosmos Black
2001///M Rdstr Steel Gray
2011 X5 35i Sport Deep Sea Blue/Cinnamon
Old 11-09-2010, 04:04 AM
Which screw of these two must i adjust?
Old 11-09-2010, 07:27 AM
The small nut is to jam against the larger tension adjusting nut.
Loosen the (smaller) jam nuts a turn or so each, then tighten up the larger nuts to take any slack out of the cable. They're a little hard to get at with the lever all the way down, so with some trial and error, you can tighten them with the lever pulled up slightly.
When finished, you want to be sure that you're not pulling on the cables at all, while the lever is all the way down. Tighten the jam nuts against the larger nuts to maintain your adjustment setting.
One of the things you need to be certain of, is that the outer jackets of the cables aren't damaged, and letting in water. If water gets in, the inner cable can rust and sieze to the outer housing. Once that happens, you need to replace the cable(s).
Randy Forbes
