Old 11-09-2010, 03:27 PM
z3-o1 z3-o1 is offline
Mein Auto: bmw z3 1997 1.9l Auto
Unhappy HELP PLEASE Reset Z3 oil service light
Just done a oil change
so need some advice on how to reset oil light inspection on dash
thanks all
Old 11-09-2010, 03:54 PM
its ok
ive done it , it was simple
Old 11-09-2010, 06:11 PM
rtsuggs rtsuggs is offline
Mein Auto: 02 z3 roady
How did you do it?
2002 Z3 2.5i
Old 11-10-2010, 01:04 AM
Originally Posted by rtsuggs View Post
How did you do it?
Simple
Turn the ignition switch to position two (2). Connect the clip end of the jumper tool to a good ground in the area of the data link connector. Connect the pin end of the jumper tool to pin seven (7) of the data link connector and remove it after the appropriate time, depending on which reset you are doing. Replace the data link connector cap and turn off the ignition switch. Check to see if the reset worked by starting the car and seeing if the lights go out. If they do, good job!"
10 secs should do it let me know how you get on
ID:	254013   Click image for larger version
Old 11-10-2010, 05:09 AM
What year model is yours? Mine is an 02 , Would it be the same?
2002 Z3 2.5i
Old 11-10-2010, 06:33 AM
mine is a 1997
all the same
Old 01-23-2013, 08:50 AM
Waldvogel45 Waldvogel45 is offline
Mein Auto: Z3
thanks again: this time the system had also blocked the starter, but your method sorted it in 10 seconds; 1996, 1.9.M44
Old 02-01-2013, 04:47 PM
DreamnZ DreamnZ is offline
Mein Auto: 1996 BMW Z3
Originally Posted by z3-o1 View Post
Simple
I'm a bit confused, and therefore have to start by apologizing.
What to you connect? A wire? What's a jumper tool? Is this like my jumper cable?
This is a really good trick and I would really like to know how it's done.
Thanks in advance for clarifying.
Old 02-02-2013, 11:41 AM
vintage42's Avatar
BMW CCA 1405
Originally Posted by DreamnZ View Post
... What to you connect? A wire? What's a jumper tool? Is this like my jumper cable?...
A jumper is any conductor used to connect two points. To reset the indicator the two points are terminal 7 in the data port and the grounding nut on the adjacent passenger strut tower about a foot away. The simplest jumper for this is a stiff wire, ideally 2 feet of 12 gauge house wire with the insulation stripped back 1/2 inch on each end.
Or you can buy a "tool":
http://www.ebay.com/itm/120830233463...84.m1497.l2649
The tool means you don't have to use the wire for the right two lengths of time. Like, if you want to rest just the oil, and use the wire too long, you will reset the whole service interval. The tool has a button for each (and evidently a time chip).
See more:
http://www.unofficialbmw.com/e36/ele...ce_lights.html
http://forums.bimmerforums.com/forum....php?t=1933465
Old 02-02-2013, 05:11 PM
Ron Stygar's Avatar
Ron Stygar Ron Stygar is offline
19,585 Miles
Mein Auto: Z4 M Coupe 6LL93033
Simple
That's my picture!
