Old 11-05-2010, 07:34 AM
EarlyRider EarlyRider is offline
Mein Auto: Z4
Z4 Pad/Rotor dealer replacement ??
2007 Z4 3.0i coming up on last free maintenance/service interval next month or two. I read about this here but can't find it now. What is the wear percentage of pads and or rotors that is enough for dealer replacement?? I think I read that pads had to be certain percentage gone and rotors also had to be below xx measurement to qualify for replacement of both. I want to measure my rotors and see where I'm at. What is the rotor minimum thickness - anyone have the specs? If I'm not close enough I'll likely go with aftermarket rotors and low dust pads. Thanks very much for any guidance.
Old 11-05-2010, 07:52 AM
lstratos lstratos is offline
Mein Auto: 2007 Z4
I have no idea.. but my brake light came on this morning and made an appointment.. unfortunately its for next thursday.. you can always "break" the sensor and be like the light went on.. fix it ..
Old 11-05-2010, 09:47 AM
imz4n's Avatar
imz4n imz4n is offline
Z ENTHUSIAST
Mein Auto: 06 3.0 si Z4R
The important part to realize here is the 30-05 has two brake sensors ( drivers front and passenger rear ) the 06-08 has only one sensor ( drivers front)
Old 11-05-2010, 11:08 AM
jmillet's Avatar
jmillet jmillet is offline
Mein Auto: E86 Z4 M Coupe 7LM08376
Here is BMW NA's latest clarification (disclaimer) regarding their lame 4yr/50,000 mile Maintenance Program.
BMW Maint Prog Disclaimer.pdf
No free rotors unless the pads are worn down to minimum thickness (3mm) or less.
Jim Millet
2007 Imola Red Z4 M Coupe'
Premium Package, Nav, HD Radio, Heated Seats, CDV Delete, RPI Scoop, Strong-Strut fire wall braces, TCK DA Coil Over Suspension with Camber/Caster plates.
Old 11-06-2010, 06:03 AM
STIHLBOLTS STIHLBOLTS is offline
Hat's On, Tops Down!
Mein Auto: 2013 335is
The free rotors was the selling point for the Finance guy when I had the 04 3.0i but 2nd go around and with 2 years regular warranty left on the M car I passed getting it this time. While some things got taken care of under the extended maintenance contract, for the most part it really did not pay for itself over the course of the 2 year extension.
Best regards
2013 335is Convertible
MODS:M3 Strut Brace / Smart Top Module / Ikon Lip and spoiler
VRSF Charge Pipe /
BMWCCA Member
Previous: 2004 3.0 Z / 2008 Z4M
Old 11-08-2010, 07:40 PM
CalRick CalRick is offline
Mein Auto: 2007 Z4MC & 95M3 Tracktoy
Both of my 07's had the two sensors - maybe yours is just missing the rear one?
Old 11-09-2010, 11:56 AM
imz4n's Avatar
Z ENTHUSIAST
This prompted me to go check my rear brake replacement job. The sensor was not missing , it was taped up in the finder well and was missing the retainer clip. That has now been replaced and the person telling me that there was no sensor has been corrected as well. Thank you for pulling my head out, and correcting me or I would have been running around without a proper install. All I knew was I did not have one connected when I did the brake job. The issues you find when you buy a used car.
Old 11-11-2010, 05:36 PM
Mein Auto: 2007 Z4
Got my front brakes done for free.. didn't qualify for a free rotor.. i figure if i took the rotor off, get it machined for 5 bucks,get it replaced for free
Front brake outter pad 3mm, inner pad 2.8mm
Front rotor @ 20.5, 20.4 is min specs.
