Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series - E23 / E32 (1977 - 1994)
Old 07-08-2009, 02:02 PM
bmw740iVA bmw740iVA is offline
Mein Auto: 1993 740i
Thumbs up 1993 740i - Need help to fix brake light
Hi
I have 1993 BMW 740i series. The Brake light is not working on driver side.
The Lamp looks ok. Even with the new lamp also it is not working. So what could be the problem? Is there any chance for breaking of electrical wires? Also, How do I find that the brake sensor is working and where it is located.
Thank you all for your help.
Old 07-08-2009, 04:28 PM
crewdog843's Avatar
crewdog843 crewdog843 is offline
Mein Auto: '08 Z4 3.0si Roadie
If the brake light on the passenger side is working but the one on the driver's side is not, it is most probable that the brake sensor is not the fault. In some cars, corrosion can cause this problem, and can be cleaned up with a small wire brush and application of an electronics spray cleaner. Does the entire unit detach from inside the trunk (on my '01 e30...the entire unit came off by unscrewing a single larger screw, making everything very easy). Also, check the bulb and make sure it is the same type as the one on the pax side. I had a similar problem with my '01 when I first got it and found out that someone had installed an incorrect bulb. Bulbs sold at Autozone do not match BMW's bulbs and in some cases, although their computer claims it to be the correct bulb, you cannot even insert it into the mount/socket.
jake
Old 07-14-2009, 01:26 PM
Thanks Jake, I will try ur suggestion
Old 05-29-2010, 08:51 AM
PETER NEWMAN's Avatar
PETER NEWMAN PETER NEWMAN is offline
Mein Auto: BMW 635 CSi BMW 730i E38
Most problems with non working brake lights is the plastic bulb holder having over heated and the bulb becomes loose in the holder, This problem occurs mainly on auto BMW's due to drivers sitting at traffic lights with their foot on the brake pedal which over time over heats the bulb holder, Another very common problem.
Old 11-14-2010, 04:41 AM
dolberry dolberry is offline
Mein Auto: 740il
Recall on brake light switch
Old 11-14-2010, 06:57 AM
drivinfaster's Avatar
Mein Auto: rescued bmw's
recall on an e32??
df
