5 Series DIY
Knowledge Is Power! ~ The place for do-it-yourself threads on a variety of topics. Start a thread describing a particular job (oil change, cooling system overhaul, brakes, shocks and springs, etc.) or search for one you need help with! |
CDX-M30 Install question
I'm trying to install a Pioneer CDX-M30 CD changer in my prewired 94 525. I've got the correct PIO adapter cable but don't know how to wire in the power. I don't have the correct Pioneer connector. On the back of the changer is a 3 pin receptacle. One pin is labeled "H" one "3" and the center position is unlabeled.
Anyone know where to connect the 12V and ground? Where might I find the correct plug for this? Thanks, Walt Last edited by Walt; 10-12-2003 at 03:02 PM. |
2 Cables connected to the unit...
The other is a power and ground. It requires permanent 12V and ground. The ground you can ground to any chassis ground. The power you may/may not find a lead in the trunk. If not, wire directly to battery cable. Search unofficialbmw.com email database (E34/36), or do a search on the E36 archives of bimmer.org; the CDX M30 stuff has been tackled before. chris |
