Hi all!
In my 530i, 03 model, M54 engine the A/C is blowing only hot air so i checked the compressor and, the pulley its spinning when engine is on but the clutch plate at the front of compressor stands still.
So i checked fuses, relay under the hood and all working fine. when i press the snow flake button the green light turns on but the compressor does not engage. all settings are set for cold.
I had the system checked by a specialist and said that there is plenty of gas in there, pressure is good and all. Then i went to an auto electrician which scanned for trouble codes and found nothing wrong. Then he checked the compressor and came back with the verdict no power going there.
But all wires seem fine from what i can see. Really desperate to fix this because i live in Australia and summer is already here and i dont know waht else to do except take it to a dealer and be skinned alive for it. If u think dealerships in USA charge you an arm and a leg down under they are not satisfied until you have no more limbs.
So in sumary:
- Fuses check.
- Relay check.
- System at correct pressure with plenty of gas.
- All inside settings set for cold.
- No trouble codes.
- Specialist said nopower geting to the compressor.
I read a few threads but seems that the general advice is refill at proper level etc.
So in sumary:
- Fuses check.
- Relay check.
- No trouble codes.
