Old 11-24-2010, 05:07 PM
vsrinee vsrinee is offline
Mein Auto: 2002 E39 525
CCV Replacement - Engine Failsafe Prog
I just replaced my CCV. When I started the car, Engine Failsafe prog show up. Car is starting rough. Any information would be greatly appreciated.
Old 11-24-2010, 05:22 PM
bmw_n00b13's Avatar
Freude am Fahren
Send a message via MSN to bmw_n00b13
Mein Auto: 99 528iA
Probably missed a connection or cracked a dead vacuum hose.
CCV Replacement DIYs
'99 528i ('98/12 build). 174,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals
'99 540i (grandfather's)
Old 11-24-2010, 05:54 PM
poolman poolman is offline
Mein Auto: 525i station wagon
check your plugs and make sure they are all clean--throttlebody connection can cause the code your running into.
Old 11-24-2010, 07:07 PM
The car starts, but when I hit the gas, it would immediately die. Engine Failsafe Prog shows up and ABS light comes on. I will probably go back and recheck everything. I followed the DIY to perfection.
Old 11-24-2010, 07:21 PM
Fudman's Avatar
Fudman Fudman is offline
Check for codes and check for loose connections to the wiring box.
Old 11-26-2010, 08:34 AM
Do you know where I can get the scanner to read the codes? I don't have one. Also, where can I find a diagram for the wiring harnesses? Even though I took extreme care in identifying the different connections, there is a great possibility that I might have some wrong connections. I am trying to work on it today.
Old 11-26-2010, 02:18 PM
Since you're not in HI or CA, you can just borrow the scanner from AutoZone.
Or, for $30, including shipping & tax, you can buy your own scanner (I was borrowing one from a friend but got tired of that and just bought it).
From the bestlinks:
- Cheapest CAN OBDII scanner on the net that reads DTCs, pending codes, & clears codes
- OBD II PC freeware & $15 J1962 cable for the BMW E39
Old 11-28-2010, 07:24 AM
None of the local auto parts shops loan out scanners.. I went to a dozen local stores and no luck. I just ordered the one from Amazon that Bluebee mentioned. Now, with regard to the car, I did go back and recheck everything (literally had to do all over again). Still getting the Engine Failsafe Prog and the ABS on and the car dies when I press the gas. I still need to figure this out as time is running out or else need to tow it to my mechanic tomorrow. I don't want my first ever project to be unsuccessful.
Old 11-28-2010, 07:43 AM
16valex's Avatar
16valex 16valex is online now
Mein Auto: 530I/5SC 97-528/5
Remove your abs control module plug, go for ride then update us.
Old 11-28-2010, 08:04 AM
Thanks. I will try. Where do I find the abs control module plug?
Old 11-28-2010, 09:33 AM
16valex's Avatar
You know where you ABS module is? It's in the engine compartment right side. The plug is a huge one, to remove the plug you need to slide the lock clip slider, use a flat screw driver to start slide it out, once the the lock is fully slide out you can pull the plug straight up.
Old 11-28-2010, 10:10 AM
More than you want to know about the ABS is in this one post.
Tons more in the bestlinks thread.
Just do a find (control + f) for "abs"; use the "F3" button to skip to the next link. Hit enter to go to the link.
Old 11-30-2010, 05:35 PM
After much screwing around, the little hose that connects to the top of the throttle had a hole (very narrow opening in the hose that was hard to find). Now everything is working fine. Thanks for all the help. Next items on the agenda--fix the seat twist and do a cooling overhaul.
Old 11-30-2010, 08:07 PM
- SEAT CABLES BREAK: seat cables that fall out causing seat twist (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) & accidental airbag light fix (1)
Cooling system overhaul DIYs:
- Pictorial look at typical E39 cooling system failure modes (1) (2) (3)
- Cooling system recommended parts list (1)
- Coolants recommended by BMW and users (1)
- Bleeding the cooling system (1) (2) (3)
- How to refill M52/M54 coolant DIY (cn90)
- Cooling system DIY (cn90 1997-1998 M54TU) (cn90 V8) (aioros '99-03 M54) (Ågent99 '01 530i) (pelican 3-series)
- E39 Fan shroud removal DIY (Besian) (M54)
- Removal instructions for the alternator & drive belt system of a 2002 525i
- Removal instructions for the fan shroud of a 2002 525i
- Tools necessary for a cooling system overhaul
- Cooling system overhaul tips (fan clutch nut removal) (fan clutch nut replace) (hose removal) (o-ring replace)
- Cooling system overhaul mishaps (broken nipple) (crooked fan clutch nut) (bleeder screw) (thermostat loom)
- Expansion tank floating mechanical coolant level sensor height (1) (2)
- High instrument cluster check of the cooling system temperature KTMP (1)
- Cooling system date stickers & radiator date codes & markings (1) (2)
- What brand of waterpump to buy (1)
- Fan clutch failure modes (1)
- Fixing a head gasket coolant leak (1)
- What is the temperature of the coolant & when the thermostat opens under normal conditions (1)
- Modifying the cooling system (pressure cap) (zero psi fluids) - Zionsville (BlackBMWs) (William) (ohmess)
- Understanding the AUC automatic air recirculation (aka stink) sensor (1)
- Behr radiator and Behr expansion (aka surge) tank autopsy (1) (2)
Old 12-01-2010, 01:37 PM
Ågent99's Avatar
Ågent99 Ågent99 is offline
Moderator 5-Series
Mein Auto: Trek 6500 MTB
Could you post a pic of what you found? It could help others in the future. Was it at all related to your recent work? Did you bump it or move it, you think?
2001 530i/5 (E39), Topaz Blue/Stone Green/Black (97k miles)
2005 545i/SMG (E60), ED Order, Titanium Grey/Grey (lease transferred...no longer have)
Old 12-01-2010, 07:12 PM
Bluebee: Thanks for the info regarding the "seat twist" and the "cooling overhaul". This is awesome.
Agent99: Sorry, I didn't take any pictures. I should still have the old hose sitting around somewhere and I can take a picture of the "hole-in-the-hose" and post it here. I am assuming this was related to the CCV replacement work I did in my car cuz everything was fine before I worked on it. I am not sure what I did--it wasn't in the greatest of shape in the first place when I was working on it. I must have yanked it out and broke it.
Old 12-01-2010, 07:30 PM
I echo that sentiment. We love autopsy pictures. It's a great example for others.
