Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series DIY
7 Series DIY
Do It Yourself forum dedicated for 7 Series BMW Owners
Closed Thread
Old 12-02-2010, 04:22 PM
wilson009's Avatar
wilson009 wilson009 is offline
Mein Auto: 2002 745i 116k
Mechatronics DIY (Transmission valve body)
This is my DIY for the Mechatronics unit for a 2002
Black 2002 BMW E65 / 745i 114K
My DIY's - New alternator, battery, CCVs, idler/tensioner pulleys belts, NGK Iridium spark plugs, , sway bar bushings, Front rear brakes, Valve Block, Head Gasket, Exhaust Gasket, Upper and lower Timing Gaskets, Valve Covers, exhaust valves, Timing Chain slide rails, Fuel Injector o-rings, pulled radiator, Intake Manifold Gaskets, water pump, Coolant Pipe/weep hole, oil pan gasket, vacuum pump, fan shroud, Vanos solenoid o-rings, and timed it with a timing kit.
Old 12-02-2010, 04:35 PM
wilson009's Avatar
Pictures
Additional Pictures
ID:	256961   Click image for larger version
ID:	256962   Click image for larger version
ID:	256963   Click image for larger version
ID:	256964   Click image for larger version
ID:	256966   Click image for larger version
ID:	256967   Click image for larger version
ID:	256968   Click image for larger version
ID:	256969   Click image for larger version
ID:	256971   Click image for larger version
ID:	256972   Click image for larger version
ID:	256975   Click image for larger version
ID:	256976   Click image for larger version
ID:	256978   Click image for larger version
ID:	256979   Click image for larger version
ID:	256980   Click image for larger version
ID:	256981   Click image for larger version
ID:	256983   Click image for larger version
ID:	256984   Click image for larger version
Old 12-02-2010, 04:39 PM
wilson009's Avatar
Hydraulic Diagrams etc
Name:	1st Gear Hydraulic.JPG
ID:	256986   Click image for larger version
Name:	2nd gear hydraulic.JPG
ID:	256987   Click image for larger version
Name:	3rd gear hydraulic.JPG
ID:	256988   Click image for larger version
Name:	4th gear hydraulic.JPG
ID:	256989   Click image for larger version
Name:	5th gear hydraulic.JPG
Name:	6th gear hydraulic.JPG
Old 12-02-2010, 04:44 PM
wilson009's Avatar
Misc
Addition Misc.
Name:	3-2 Shift Valve.JPG
ID:	256992   Click image for larger version
Name:	4-2 Shift Valve.JPG
ID:	256993   Click image for larger version
Name:	Adaptive Transmission Control Input.JPG
ID:	256994   Click image for larger version
Name:	mechtronic torque.JPG
ID:	256995   Click image for larger version
Name:	Mechtronic Sensors.JPG
Name:	mechtronic valve location.JPG
ID:	256997   Click image for larger version
ID:	256998   Click image for larger version
Name:	Solenoid Locations2.JPG
ID:	256999   Click image for larger version
Name:	Reverse Hydraulic for E Shift Unit.JPG
ID:	257000   Click image for larger version
Name:	Switch Logic Chart expanded.JPG
Name:	ZF6HP26 E-SHIFT Upper VALVE BODY.JPG
ID:	257002   Click image for larger version
Name:	ZF6HP26 E-SHIFT Upper (channel plate) VALVE BODY.JPG
ID:	257003   Click image for larger version
Name:	ZF6HP26 E-SHIFT LOWER VALVE BODY.JPG
ID:	257004   Click image for larger version
Name:	ZF6HP26 case passage identification.JPG
ID:	257005   Click image for larger version
Name:	ZF6HP26 E-SHIFT LOWER VALVE BODY2.JPG
Name:	trans exploded view.jpg
Closed Thread
