7 Series DIY
Do It Yourself forum dedicated for 7 Series BMW Owners |
How to Change your Tranmission Fluid DIY
Wasn't much to put this together after making the mechatronics document.
Black 2002 BMW E65 / 745i 114K My DIY's - New alternator, battery, CCVs, idler/tensioner pulleys belts, NGK Iridium spark plugs, , sway bar bushings, Front rear brakes, Valve Block, Head Gasket, Exhaust Gasket, Upper and lower Timing Gaskets, Valve Covers, exhaust valves, Timing Chain slide rails, Fuel Injector o-rings, pulled radiator, Intake Manifold Gaskets, water pump, Coolant Pipe/weep hole, oil pan gasket, vacuum pump, fan shroud, Vanos solenoid o-rings, and timed it with a timing kit. |
Great Info and nice details of yours PDF'S. Thanks Wilson
