E30 (1982 - 1993)
Old 12-13-2010, 10:23 AM
laurelshelton laurelshelton is offline
Mein Auto: 1989 325I
Oil Weight
Aloha, When living in San Diego, I used 20/50 oil per the suggestion of a mechanic. Now that I'm in Maui, should I change to a lower weight or stay with the same? My understanding is that the 20/50 weight is for real cold or real hot weather, and most days are in the 80's. I don't drive long distances, maybe 60 miles once or twice a week. Mahalo for your assistance, Laurel
Old 12-13-2010, 11:15 AM
lordofthewaters's Avatar
lordofthewaters lordofthewaters is offline
Rather Large Member
Mein Auto: 88 325is 04&09 jetta TDi
20-50 is fine for where you are. It's adequate in the range of something like 10 degrees F to 120 degrees F.
Check the manual, there's a chart you can reference.
http://jon.bimmerfest.com/bulletins/e30_manual.pdf
Sarcasm is a body's natural defense against stupid.
When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's 3.95 per minute.
"My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson
Old age and treachery, will always overcome youth and skill.
Old 12-13-2010, 11:27 AM
I guess what I really should of asked is... would it mess up my engine if I switched to a lower weight, as 20/50 costs more at oil change time. Also, changing the oil every 3,000 is a good thing... right? My sister has a Mercedes SUV and only changes every 7,000.
Old 12-13-2010, 11:34 AM
eieio4tn's Avatar
eieio4tn eieio4tn is offline
BMW...riceless
Mein Auto: 1987 325is
bet she's running synthetic oil
Old 12-13-2010, 11:44 AM
Could be... thanks!
Old 12-13-2010, 02:49 PM
Rather Large Member
Couldn't actually HURT it unless you went too thin. But it may leak.
As for the 3,000 miles, you CAN go longer (they do in Europe even in old cars), but who knows how much that affects your engine wear? Newer cars often do have a much longer change interval because they are designed to use synthetic or even a blend.
Old 12-13-2010, 05:41 PM
Mahalo for your input "Lordofthewaters"
