5 Series DIY
Knowledge Is Power! ~ The place for do-it-yourself threads on a variety of topics. Start a thread describing a particular job (oil change, cooling system overhaul, brakes, shocks and springs, etc.) or search for one you need help with! |
#76
Ahh..Awesome!!
Live the e39..!!
#77
Oh no! It was actually very important. I just wanted it to be clear it was a verbatim quote of a paragraph or two. I just "fixed" it by bringing the font back up to a size 2, italicizing it, and blue'ifying the text so that it stands out as an important quote.
Thank you very much for pointing that out! (As for the PM thing, I guess it has a purpose in a public forum.) Note: Here's a smaller pic of the tool dimensions previously posted: Last edited by bluebee; 09-13-2010 at 07:16 AM. |
#78
FIRST....make it out of cardboard using scissors, see that the cardboard version fits your vehicle, then just trace/transfer the measurements to steel...EASY! (Thanks to Mr. Gilkey, 7th grade metal shop teacher!)
#79
The dimensions on Michel's otherwise wonderful diagram don't seem to show 'exactly' how the curve should go (e.g., the distance from the curve to the holes is not shown). So, it seems to be some stiff cardboard would be perfect as a doublecheck. |
#80
![]() Quote:
MatWiz "Seeing is not believing. Believing is seeing." -Judy the Elf |
#81
I don't know about you, but I don't generally click on any thingeys. I just type [ QUOTE ] when I need a quote. And [ U R L ] when I need a URL, and [ BOLD ] when I need bold, etc.
Anyway, good ole' Ågent99 posted his (rather unique) fan-clutch replacement tool ensemble here and referenced it today, so I figured I'd add it to this thread to keep that 'all in one place' feeling for newbies. |
#82
It looks like there is no dearth of ideas for both the source of the 32mm wrench and the counterhold tool.
Here, Ågent15 recommends a Park brand bicycle headset wrench from REI for the fan counterhold tool. The other end of that $15 headset wrench can double as a 36mm wrench for the oil filter cap in a pinch. |
#83
1.25" = 31.75 mm
32 mm = 1.2598" Close enough me thinks....
2001 530i/5 (E39), Topaz Blue/Stone Green/Black (97k miles) 2005 545i/SMG (E60), ED Order, Titanium Grey/Grey (lease transferred...no longer have) |
#84
Thanks to the technical drawings here, I was able to use 1/4" thick plate and plasma cut these on my CNC table... They worked great. Took about 10 minutes and I used some scrap plate I had laying around. I got video of it on the camera. Will get that up eventually if anyone is interested.
#85
Thanks for the info. Just finished my cooling system overhaul and I had to make this tool to do it. Mine wasn't perfect, but it worked.
#86
It won't be anywhere near as pretty as what my store-bought tool looks like, but the satisfaction of doing it yourself is worth the effort! BTW, here are some pictures of the tools in operation. This first pic is my store-bought tools in place on my M54 engine (2002 BMW 525i). Notice the tool only fits over one set of the four bolts because they are in a rectangle, not a square. For others to get an idea, here's how the two tools work in conjunction with each other on the BMW E39 engines. Here's another shot of the two tools working together on an E39. And, yet another (different style tool but the same effect) shot on an E39. And this shows how thin the tools must be to both fit in place. Last edited by bluebee; 12-17-2010 at 12:46 AM. |
#87
I just saw your post for the first time, as I had not seen it before.
What a WONDERFUL job you did there on these tools! I like the hand cutouts for your fingers too! We're glad the drawings helped you out! I'd love to see the video as I can't imagine how CNC machining works. BTW, can your CNC file format be posted here for others to use? |
#88
Luckily, for the poor-man's method, the 1 1/4" open-end wrench isn't all that hard to come by in the USA.
And, here's the poor-man's method in operation on a BMW E39. |
#89
As yet another cross reference, here is a thread which I had not known about previously where the measurement of the BMW fan clutch nut counterhold tool are listed for the purpose of making them yourself.
- DIY BMW tool thread In that thread, they cover the making of a bunch of tools: - Rtab removal tool - Upper timing chain locking tool - Flywheel locking tool - Cylinder head bolt removal tool - Cam locking nut tool - Fan clutch removal tool <===== the topic of this post |
#90
As a cross reference, here's yet another option for sourcing the fan clutch nut removal tools ... these are from Lowes.
#91
In case anyone wants the measurements to these tools that I have, just let me know.
All I'd ask in return is the CNC or CAD file so that others would benefit. |
#92
No Problem... Heres what I made for the CNC table. This will work for water jet and laser tables as well. Just give the file to your local fab shop.
32mm Water Pump Wrench DXF file Water Pump Pulley Holder DXF file I have the g-code but that is usually written for the machine its going to be cut on. The video... Last edited by Scotts Elle; 12-17-2010 at 06:54 AM. |
#93
Where did you get the tools and how much?
Where were the tools purchased and how much? My Christmas Present to me.
#94
Fan Clutch Removal Set for BMW & Mercedes
As a cross reference, here is a COMPLETE cooling system & drive belt overhaul toolkit apparently!
- Fan Clutch Removal Set for BMW & Mercedes |
#95
For the record, 540indiana
successfully removed the viscous fan nut using this $22 tool and a 32mm wrench (details here). |
#96
Do we really need the SLOT in the fan counterhold tool?
I was wondering ... do we really need the SLOT in the fan counterhold tool?
Look at this picture of my M54 with the fan counterhold tool in place. WHY would we need the slot (which is harder to manufacture at home)? Do you think it would work (almost?) as well without the slot? |
#98
For the crosslink record, folks over on the E34 side of the house are making some really uuuuugly 32mm fan clutch nut counterhold tools!
![]() - Fan removalBTW, did anyone ever make that CNC program for others to download? |
#99
For the record, the video of fan clutch removal is pretty nice here:
- Fan Clutch Tool Question, need one, in central PA |
#100
For the record, folks on the E34 side of the house are asking for people to ship the fan clutch removal tools to them (and they'll ship 'em back).
- Anybody wanna lend me tools? Seems to me we've got plenty of solutions in this E39 thread which would cost less than two-way shipping of the tools! ![]() BTW, here's the famous smolck video of the hammer & wrench method: |
