Old 12-20-2010, 06:23 PM
onebluemcm onebluemcm is offline
Mein Auto: 2007 Z4MC
Is there a bottom line on S54 rod bearings?
I figured I'd make a thread, rather than jack the good S54 valve shim thread already ongoing.
I noticed in the discussion about valve shim adjustments that replacing rod bearings on the S54 came up. Having owned an E46 M3, I had heard about the recall issue, but to date, I had not heard anything about pre-emptive rod bearing replacement in later S54s.
Why and when is this necessary? Looking for some comments.
Old 12-20-2010, 07:38 PM
mhughett mhughett is offline
Mein Auto: 2003 530i/2007 Z4 Coupe
I think there was a bad supply of rod bearings that got into the first year or so of S54 engines. BMW also changed the recommended oil from 5w30 to the 10w60. I have not heard of any other rod bearing issues on S54 engines since then--despite the fact that these engines see a lot of track time.
Mike Hughett
2007 Z4 M coupe
Premium Pkg, Heated Seats, ZHP shift knob, Satellite Radio (XM) from EAS
2003 530i 5-speed, SP, PP, CWP, Xenon
Bilstein Sports
UUC short shifter with DSSR and ZHP shift knob
Michelin Pilot Sport A/S
BSW IQ speakers, Sirius
CDV delete
Huper Optik tint
2007 X3 3.0si
6-speed manual, CWP, Xenon, Cft. Seats, Premium Pkg, Sirius, Privacy glass
Old 12-20-2010, 08:24 PM
Drivewfo Drivewfo is offline
Enthusiast
Send a message via AIM to Drivewfo
Mein Auto: 2008 Z4 3.0si Roadster
Was the recommendation from 5w30 to 10w60 directly related to more rod bearing clearance? Were they spinning bearings prior to this?
BMWCCA Member
2008 Alpine White Z4 3.0si Roadster 6spd
2006 Silverstone II M5 SMG (gone)
2002 Alpine White 325i Steptronic (gone)
Old 12-20-2010, 08:53 PM
Ron Stygar's Avatar
Ron Stygar Ron Stygar is offline
19,585 Miles
Mein Auto: Z4 M Coupe 6LL93033
Oil was changed 6/2001.
The fix on the E46 M3 was from 05/23/2003.
Old 12-20-2010, 11:22 PM
Randy Forbes's Avatar
Randy Forbes Randy Forbes is offline
Investigative Tinkerer
Mein Auto: ///Motorized Vehicles
It was brought up in the other thread because Pal mentioned high lead readings (oil analysis) after track days.
To date, I've only swapped out the bearing inserts on S-54s in the Z3/M cars, but maybe I can talk Pal into some preventitive maintenance...
I'll probably coat this stack of bearings tomorrow (two__2__sets already spoken for):
Last batch was mostly Healey bearings:
Randy Forbes
1957 Austin-Healey 100/6 Wine Red
1961 McCulloch R1 go-kart Screaming Yellow
1999///M Rdstr Cosmos Black
2001///M Rdstr Steel Gray
2011 X5 35i Sport Deep Sea Blue/Cinnamon
Old 12-21-2010, 06:54 AM
Last time I saw a nice full set of rod bearings was when we changed them on an old '65 Ford Galaxie 390.
I wondered about pal's car, where the concern was coming from - I kind of deduced that it was from an oil analysis. Is increased lead specific to rod bearing wear?
So, this brings up a few more questions - I thought it was always best to change rod bearings and the crank at the same time - doing just the bearings, do you have to worry about differing wear surfaces between new bearings and the crank journals? What's the "break in" period like (duration, limits) when doing a bearing swap?
And finally, what's the coating above? How thick and how applied? Very nice work there.
_.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._
Silbergrau A08 / Sepang Brown LSD6 / Carbon Leather 4MY (1 of 3, this combo)
BMW strut brace, RAC Monolites RG63s 18x9/10, Conti EC-DW, Arqray SS cans, Axxis Deluxe+ pads
