Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series - E23 / E32 (1977 - 1994)
Old 12-21-2010, 10:44 AM
cadensdad8 cadensdad8 is offline
Mein Auto: 1991 bmw 735i
1991 735i overheating
what can i do to check and see if the water pump is working properly? vehicle is overheating and im trying to narrow it down. also how do i bleed the coolant lines? thanks for any help you can give me.
Old 12-21-2010, 03:56 PM
drivinfaster's Avatar
drivinfaster drivinfaster is online now
bimmerfest Supporting Member
Mein Auto: rescued bmw's
first i would check the coolant level, and if low, then find and repair any leaks.
the coolant would not be circulating if the pump decided to go south, and a non-contact infra red thermometer would work great to check the temps.
iirc, there should be a bleeder on the thermostat housing. i believe all of the m30 engines are similar in this proceedure, so there should be lots of diy's online. pelican may even have a good link as well. here's one that i have glanced over and think is accurate to the proceedures) i have done on many, many different makes and models, not just bmw.
http://www.bmw7resource.co.uk/TechDo...d%20System.pdf
good luck,
df
