E39 Facelift Halogen to Xenon HELLA OEM retrofit
I got these headlights from ebay and I I want to retrofit my Facelift Halogen 2001
They are xenon OEM hella from 2003 530i ![]() last night in installed them on 2003 530i car with xenon ( simple swap just to be sure that all is in working condition ) before Halogen swap 2 questions : 1 I need to do some light correction , right side it down left side is up As far as i can see adjusters are not broken and auto leveling system is working How you guys adjust your headlights ? 2. Xenon light is kind of purple . My OEM is white ... is it headlights or bulbs ? just strange for me , i am kind of new to this staff thanks Last edited by champaign777; 01-09-2011 at 08:08 AM. |
I like this forum
![]() have clue about purple light ? thanks ! |
![]() ![]() Difference between OEM D2S HID Bulbs and H7 halogen bulbs. Do you have OEM D2S bulbs?
i have no idea
which one has purple color ? |
Lights look like they are in good shape. Hopefully your adjusters aren't broken. If not, adjustment is very simple with the white turnstyle adjusters up top. Good luck~!
![]() Mods: Shark Injected | Magnaflow Exhaust + Resonator | H&R Springs | Bilstein SP Shocks + Struts | TMS Power Pulleys Eibach F+R Sways | BeastPower Brackets | M-Tech bumpers | Predator ICE V3 + HID Fogs | Eurodyne CF Hood | BSW Sub + Dice + spec dock [---Quote (Originally by Tex330i)--- You can warranty a turd, that way when you have a problem you can exchange it for a new turd.---End Quote--- |
yap you right
no they are not broken , no movement at all Last night i played a bit and adjusted them ( up down movement ) , thanks to bluebee I need to try left right adjustment as well Guy told me they are off from 540i and this why they have purple color If you ask me i like white color more ... which bulbs I need to look for ? Last edited by champaign777; 12-20-2010 at 05:09 PM. |
How much did you pay for the lights?
Purple color means the bulbs are not creating the chemical reactions that produces the light. Inside an HID lamp, there's this chemical called halide. WHen voltage is applied between the two electrodes inside the lamp, a chemical reaction takes place because this element is negatively charged and will react to the positive charge. It's this reaction that produces the light.
http://forums.bimmerforums.com/forum...d.php?t=836630
http://web.mac.com/esckoehler/iWeb/S...c%202009-1.pdf
they work great as far as i can see except of color which i dont like Last edited by champaign777; 12-21-2010 at 04:53 PM. |
i just need to swap headlights and decode them - this is the whole point of buying OEM Xenon Hella set and replace Halogen Last edited by champaign777; 12-21-2010 at 05:44 PM. |
The links are also there to help you understand the difference between halogen bulbs and HID D2S bulbs.
Champaign,
Curious to know how much you paid for those oem xenon h/lights? GL with sorting out issues.
usually they run about ~1200-2000$ new or ~400-1000$ used You may need some hardware as well check ebay Last edited by champaign777; 02-15-2011 at 02:47 PM. |
I use after market HID on my E39, 5k, 50W set, much brighter than the 35W set, no regret
i try to figure out where auto level server is connected
This yellow triangle is a servo ?
FYI OP, most on here seem to prefer OEM White which is typically 5000k*. I have my DS2 lights (HID Fogs included) 6000k and I think they all look great. Very bright white with a subtle hint of blue. Good luck. *Corrected to Jason's post below. 4300k stock/OEM.
![]() Mods: Shark Injected | Magnaflow Exhaust + Resonator | H&R Springs | Bilstein SP Shocks + Struts | TMS Power Pulleys Eibach F+R Sways | BeastPower Brackets | M-Tech bumpers | Predator ICE V3 + HID Fogs | Eurodyne CF Hood | BSW Sub + Dice + spec dock [---Quote (Originally by Tex330i)--- You can warranty a turd, that way when you have a problem you can exchange it for a new turd.---End Quote--- Last edited by Mack; 12-27-2010 at 10:31 AM. |
Yeah... I have no idea... ![]() Says the new-b... OEM is 4300k. I am pretty sure you will want OEM bulbs. Please post a picture of the D2S bulb you have now. Is your bulb OSRAM-SYLVANIA? http://www.eactuning.com/parts/produ...ls/63217160806
thanks guys
just point me where I can buy best OEM white bulbs ( Philips ? ) and i will be happy ( i think this link which Jason sent right ? ) can somebody post a picture where auto level server is connected ? I try to disconnect it on a working headlights mm Last edited by champaign777; 12-27-2010 at 08:21 PM. |
Pictures? You probably do not need to replace the bulbs. You are probably only comparing the halogen light temp. to the HID D2S light temp. To buy OEM HID bulbs, reference the EAC link I posted above, or look on HID Concept, or on Ebay. http://www.hidconcept.com/Bulbs-Philips4K.html http://shop.ebay.com/i.html?_nkw=phi....c0.m270.l1311
Lighting chart for reference.
![]() Best pricing on your DS2 bulbs on the net. I'm running these and for the price they cannot be beaten anywhere by anyone. Good luck! http://www.jlevistreetwerks.com/5-Se...duct_info.html
#25
I am going to make a wild guess and say not Germany... Probably China...
