Old 12-20-2010, 10:10 PM
jayace jayace is offline
Mein Auto: Z4M coupe
Syncromax Tranny oil after 7k miles
Today I swapped out the Syncromax transmission oil after just 7k miles. It was grayish and from the looks of it has degraded badly. I replaced it with OEM LT2 oil and the car shifted better than it had the last 2k miles.
For those of you thinking of going with Syncromax. I'd recommend sticking with OEM.
Old 12-21-2010, 05:27 AM
Mpire's Avatar
Mpire Mpire is offline
The Anti-Rice
Send a message via AIM to Mpire Send a message via MSN to Mpire Send a message via Yahoo to Mpire
Mein Auto: S54 M Coupe x2, M52 Z3
I change mine every year as part of the fall service, but I can tell you the synchromax definitely makes the S6S-420G shift better than the OEM fill.
2001 Alpine / Schwartz Coupe
2001 Estoril / Estoril Coupe
2001 Steel Grey / Estoril Coupe
1999 Estoril / Estoril Coupe
Sunroofs are for girls.
Old 12-21-2010, 07:40 AM
wildag's Avatar
wildag wildag is offline
///M 'n it up!
Send a message via AIM to wildag
Mein Auto: '06 Z4 M Roadster
Are we supposed to be using Syncromax or Gear Oil?
Royal Purple's site says Syncromax is automatic transmisssions, and manual transmission that call for automatic transmission fluids. Another product named Gear Oil is for manual transmissions.
DreamingWell.com Web Services
Old 12-21-2010, 08:30 AM
thekurgan's Avatar
thekurgan thekurgan is offline
Bad Lieutenant
Mein Auto: S62B50 Powered
Originally Posted by wildag View Post
are we supposed to be using syncromax or gear oil?
Royal purple's site says syncromax is automatic transmisssions, and manual transmission that call for automatic transmission fluids. Another product named gear oil is for manual transmissions.
atf
Ilse
2002 E39 M5 / TiAg / Tubi Rumore / E60 SSK / Blanton 3.45:1 7 disc 40/100% locking diff / NCS Coding / Coby Alcantara / StrongStrut STB
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts
BMWCCA #453648
Old 12-22-2010, 07:20 AM
scottyD's Avatar
scottyD scottyD is offline
Mein Auto: Z4 3.0si Coupe
When I changed the OEM transmission fluid at 60k, it also looked grayish.
I put Pentosin MTF2 back in since my research indicated that it was the actual OEM fluid. It's for use in Getrag and ZF manual transmissions.
So far so good - no problems.
Old 12-22-2010, 09:27 AM
blau335 blau335 is offline
Mein Auto: 335
It's pretty well reported that synchromax is crap.
http://www.youtube.com/watch?v=OqX7IIaXtkg Is it on a dyno? No.
TCK d/a coilovers, Stoptech 6/4 piston BBK, OEM CSL headers
Old 12-22-2010, 09:47 AM
inTgr8r's Avatar
inTgr8r inTgr8r is offline
Mein Auto: Z4 M Coupe
I've seen lots of reports on RP in the M diff is crap,
but haven't seen the same about synchromax in the tranny
What do you use?
Old 12-22-2010, 10:00 AM
Mpire's Avatar
The Anti-Rice
Personally, I think synchromax is great, and I have tried everything.
The other option is the Redline Cocktail, or whatever BMW is using currently. However, BMW thinks its lifetime fill, so I think they expect it to last for 50,001 miles.
Mobil 1 runs the coolest in the diff, so I assume its the best.
Old 12-22-2010, 10:01 AM
Mpire's Avatar
The Anti-Rice
The CRX used 10w30 motor oil in the tranny, but that thing was bullet proof.
Ran it for months with no fluid in it, and it didn't shift all that well. However, refilled it and it ran like a champ till it sold.
Old 12-22-2010, 10:10 AM
inTgr8r's Avatar
I'm the same.
I change it often though.
Old 12-22-2010, 10:42 AM
Mpire's Avatar
The Anti-Rice
I doubt I get 5k even when I let it go 2 years.
I think after a couple years it has probably absorbed too much moisture.
Old 12-22-2010, 06:07 PM
Caddyshk Caddyshk is offline
Mein Auto: 2006 Z4MC #LL93158
I would like to see those reports - The RP Diff fluid has been beat up; as has the Red Line. My surf through the Internet has not yielded "crap" on the ATF?
2006 Z4 M Coupe
2006 Z4MC - #LL93158
- SuperSprint Race - OE STB - Dave Z Modified CDV - Ground Control Coil Overs - Stoptech lines - Stoptech Pads - RE Clutch Stop - RE Transmission Mounts - LeatherZ M Shift Boot - ZHP Shift Knob
Old 12-22-2010, 06:59 PM
Mpire's Avatar
The Anti-Rice
The guys over at Blackstone labs seem to think my Synchromax is good as new when I change it.
Old 12-22-2010, 07:46 PM
ebruder's Avatar
ebruder ebruder is offline
Mein Auto: '07 Z4MC, Porsche 928S4
My experience with Synchromax has been very positive. I had experienced a 3>4 notchy shift, and the dealer couldn't fix it. They had tried a tranny flush with new OEM fluid with no improvement.
They finally put in RP Sychromax (which I supplied) and the problem went away almost completely. The one thing that keeps me from attributing this all to the Synchromax is that the dealer also replace the OEM tranny mounts with Rogue Engineering ones at the same time as the new fluid.
In any case, for the ~ 3,000 miles since these changes the tranny has been a joy.
EB
Old 01-03-2011, 01:23 PM
wrh3 wrh3 is offline
Send a message via Yahoo to wrh3
Mein Auto: 2007 M Coupe, 2008 M3
Synchromax has always improved the shift action in my BMWs, and I was a huge skeptic when I first heard about it. Tried it in the 335 and was so pleased with the improvement that I started using it in the Z4M and MCS. When I was researching it I saw a lot of positive reviews and favorable analysis results. At the same time I switched to RP in the 335 trans we switched my friend's 335 trans over to Redline and it was not any better feeling than OE and worse feeling than OE within a few thousand miles. Not enough miles on my cars yet for analysis but probably this year it will be time to change it out and send it in to Blackstone.
I plan to stick with OE fluid in the rear diff though.......
Bill
Bill
2011 Lotus Elise R, 2010 Porsche Boxster S, 2005 Mini Cooper S
BMW CCA Member # 389948
www.billswebspace.com/bmwindex
