Old 01-05-2011, 01:08 PM
tim330i's Avatar
tim330i tim330i is offline
Bimmerfest.com Founder
Mein Auto: Ti Silver 03 M3
Bentley Publishers - Repair Manual for the E39 5 Series 1997 - 2003 On sale in Feb!
The BMW 5 Series (E39) Service Manual: 1997-2003 is a comprehensive source of service information and specifications for BMW 5 Series models from 1997 to 2003. The aim throughout this manual has been simplicity, clarity and completeness, with practical explanations, step-by-step procedures and accurate specifications. Whether you are a professional or a do-it-yourself BMW owner, this manual will help you understand, care for and repair your E39 5 Series.
Click here to view an excerpt from this manual: Radiator and Cooling System - 170-19 Valley pan cover, replacing (M62 V8 engine)
Though the do-it-yourself BMW owner will find this manual indispensable as a source of detailed maintenance and repair information, the BMW owner who has no intention of working on his or her car will find that reading and owning this manual will make it possible to discuss repairs more intelligently with a professional technician.
Engines covered
* 6-cylinder engines: M52, M52 TU, M54
* V-8 engines: M62, M62 TU
Fuel injection systems covered:
* Bosch M 5.2, M 5.2.1, ME 7.2
* Siemens MS 41.0, MS 42.0, MS 43.0
Manual transmissions covered:
* Getrag S5D 250G, S6S 420G
* ZF S5D 320Z
Automatic transmissions covered:
* A4S 270R, A4S 310R
* A5S 360R, A5S 390R
* A5S 325Z
* A5S 560Z, A5S 440Z
Features:
* Procedures from the basic oil change service to interpreting the Malfunction Indicator Light (MIL). This manual tells you what to do and how and when to do it.
* Engine and cylinder head service, including camshaft timing chain setup and adjustment.
* Information for specific driveability problems, including explanation of engine management systems and BMW OBD II Diagnostic Trouble Codes (DTCs).
* Theory of operation and repair information for the Siemens and Bosch engine management systems.
* Drivetrain maintenance, troubleshooting, adjustment and repair of self-adjusting clutch (SAC), gearshift linkage, driveshaft, and drive axles.
* Manual and automatic transmission removal, installation, seal replacement and external service.
* System description and repair information for Antilock Brakes (ABS), Automatic Stability Control (ASC) and Dynamic Stability Control (DSC).
* Heating and air conditioning repair (IHKA and IHKR), including component replacement.
* Body adjustments and repairs, including sunroof and tailgate.
* Wiring schematics and extensive electrical component section specifying relay, control module and ground locations with detailed illustrations and photos.
For additional technical content for E39 platform BMW 5 Series models, visit the Bentley Publishers online technical library by clicking below -
https://wiki.bentleypublishers.com/x/AgDCAQ
Pre order your manual today from Bentley Publishers here - http://www.bentleypublishers.com/bmw...ir-manual.html
ID:	261077   Click image for larger version
Old 01-05-2011, 01:23 PM
bmw_jeff_325i bmw_jeff_325i is offline
Mein Auto: 2013 X5 xDrive 35i Prem.
Bentley
I have a 2003....too bad I just received the 1997-2002 version for Christmas.....I wonder how much difference there really is?
Current BMWs:
2014 F25 X3
2013 E70 X5
Past BMWs:
2014 E84 X1
2008 E70 X5
2006 E53 X5
2003 E39 525i
2001 E46 330ci
2001 E46 325i
Old 01-05-2011, 01:49 PM
Jim Rolando Jim Rolando is offline
Mein Auto: 1999 528i
Thanks for spurring me to action. My kids gave me the money for this for my birthday, but I never had gotten around to ordering. Now it's on the way.
Old 01-05-2011, 02:32 PM
bmw_n00b13's Avatar
Freude am Fahren
Mein Auto: 99 528iA
The old version (i assume this is a new one) said it covered 03s by extension. The m54b30 didn't really change. Geez, they do a good job of making it sound good.
'99 528i ('98/12 build). 282,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals, increasing amounts of duct tape and glue
'99 540i (grandfather's)
Old 01-06-2011, 06:38 AM
menhir's Avatar
menhir menhir is offline
Float On
Mein Auto: Not a Bimmer
I got mine from Amazon for about $70 for the two volumes. IMO that's about all they're worth.
"The wise speak of only what they know."
Old 01-06-2011, 06:43 AM
Josh P.'s Avatar
Josh P. Josh P. is offline
Bimmerholic
Mein Auto: 2001 530 SP/PP/CWP/Slush
Virtually zero.
2001 530 Steel Blue Metallic, purchased Dec 03
SP/PP/CWP/Slushbox (I know I know)
OEM M5 bumper, 40% Huper Optik ceramic tint, Dice Silverline Pro iPod adapter, 540SP radial spokes, Zimmerman Z-Coat rotors w/ Hawk HPS pads
"Mods": driveshaft, cooling system, Vanos, CCV, PSR, VCG, FSU, spark plugs, buncha belts-n-hoses, & other things I'd just as soon forget
BMW CCA member for 15 years
Old 01-06-2011, 07:12 AM
cn90 cn90 is offline
I am used to Haynes Repair series which cost about $15-20 on amazon.com etc.
Bentley is very detailed and excellent but at $110-150 range, it is way over-priced. Good for a shop that specializes in BMW.
For the average Saturday mechanics like most of us here, you don't really need Bentley because virtually everything you can ask/need help has already been discussed here.
On the same topic, Bentley vs forum was discussed here: Bentley vs Forums DIYs:
http://www.bimmerfest.com/forums/sho...d.php?t=345681
Old 01-06-2011, 10:58 AM
sferley sferley is offline
Mein Auto: 540iT, Brabus
they actually mention that the V8's a covered now .. used to be the issue before they only covered the 6bangers.. might be interesting to see difference
Old 01-06-2011, 01:52 PM
bizN bizN is offline
Mein Auto: 2003 BMW 530i
I know most of this stuff covered in the manual will be on here but it is always nice to have a handy manual laying around to refer to things right then and there. For $170 though, that is a bit pricey... Although it may be worth it to some =x
Old 01-06-2011, 03:57 PM
adjmcloon's Avatar
adjmcloon adjmcloon is offline
Mein Auto: e39's , e30's, e46's
$170 is on sale? I have routinely seen these online for $100 and less for both books.
2001 530i tiAg sport (sold)
2002 540iA sport (sold)
2006 330i sport (sold)
2008 535i-6 sport (sold)
1999 528iT sport (sold)
2002 525iT alpine sport
1990 325i sedan
1990 325is coupe
Old 01-06-2011, 05:20 PM
agent15's Avatar
agent15 agent15 is offline
Mein Auto: 87 325is, 02 530i Sport
There are lots of M62 and M62TU items covered in my E39 Bentley(s)...?
Originally Posted by Fudman View Post
For me, the e39 is the ... best balance of luxury ... performance ... good looks and class. Sort of the Catherine Deneuve of cars, if you get my drift.
Old 01-06-2011, 05:59 PM
I think the paper Bentleys I have are overpriced, yet I've used them a few times.
But, in reality, the DIYs here are better than the Bentleys.
It amazes me that someone like Beisan, cn90, or Fudman can write a better DIY than those in the Bentleys. I even think my text DIYs are vastly better (longer anyway) than what is in the Bentleys, considering we do it for free and they get paid for writing this stuff up.
Come to think of it, the Bentleys are horrid, compared to the stuff we write (of course, we use the Bentleys for some of the technical information).
- Are the Bentleys nearly as useless to you as they are for me?, by bluebee
Still, the Bentleys are recommend ... less and less so as time goes on since they don't improve their DIY procedures and we improve ours.
- Where to get Bentley manuals
PS: Maybe I should short the publisher and make myself some money!
Old 01-06-2011, 09:02 PM
540indiana's Avatar
540indiana 540indiana is offline
Mein Auto: 2000 540i Sport
Guys guys guys, You are all missing the big picture. Save your cash on these manuals and just play BLUEBee for all the pictorals. Well just browse the diys here and the almighty google. We dont need no stinking Manuals
Old 01-07-2011, 06:47 AM
...But, in reality, the DIYs here are better than the Bentleys.
It amazes me that someone like Beisan, cn90, or Fudman can write a better DIY than those in the Bentleys. I even think my text DIYs are vastly better (longer anyway) than what is in the Bentleys, considering we do it for free and they get paid for writing this stuff up...
bluebee,
The main reasons forums are better than Bentley because:
- We do these DIYs with a passion, the Bentley people write the book for money.
Whenever you do anything in life with passion, you will do well.
- The pictures are colors, not B&W.
- Each DIY has tons of different ways to do things aka "there is more than 1 way to skin a cat" kind of thing.
- We include the experience such as Bilstein, Sachs, Koni struts etc, which you will not find in Bentley.
- We post our feedback on a particular product, for example, I tell people I am into my 5th year of "Hepu" Water Pump with zero issues. Bentley does not have this info.
- We post unexpected issues such as recent Behr reservoir with a flap, who in the world would expect to see this poor Quality Control from Behr?
But as I said above, if Bentley is $15-20, I will buy it, but at $110-150, forget it.
Old 01-07-2011, 09:13 AM
menhir's Avatar
Float On
bluebee,
Herein is the value of this community. Added to this is the benefit of someone offering their time and physical assistance to help a member in need on occasion. That doesn't come in any book (and I'm a voracious reader).
Old 01-07-2011, 12:51 PM
540indiana's Avatar
If this site would allow, I may be able to get a german car repair manual made up entirely of the DIY's with pictorals from a local vocational school here in Indy and perhaps sell them to the members here on the site with all of the proceeds going to the site to either enhance it or help out the sponsors minus the cost of materials from the school? I dont know about all the stipulations regarding rules and regulations to get this done but it is just a thought. Maybe all the proceeds could go to a charity. Of course all of the info would not be copyright infringement in anyway shape or form as it would come from common knowledge from the members? Just a thought. It may also help clear up some of the traffic on the site due to the redundant questions we get on here. Which I am definately guilty of.
Old 01-07-2011, 01:10 PM
96 GGM 528I 96 GGM 528I is offline
Mein Auto: 1997 528I Daily
I found mine on the Internet and paid little to nothing. If you know how to work the internet its there.
Old 01-07-2011, 01:22 PM
540nj 540nj is offline
Mein Auto: 03 540i6
There's lots of stuff to steal on the internet - music, movies, books, cc #s, etc. It all depends on your definition of right and wrong (and your fear of getting caught!)
You could extend that to stealing stuff from stores or people.
I'm not saying I'm not guilty either.
Looks like this forum is advertising for Bentleys to pay the bills.
dave
03 540i6
Old 01-07-2011, 03:31 PM
I see where you are coming from there. Though I would call it sharing not stealing. Like when I used to copy friends tapes. Never sold them to make money. I would like it if I could help out my bimmer friends but I'm sure it would be frowned upon by moderators. However there are people on here who don't live in the US where it may be considered legal for them to share with friends. Its not like I'm trying to get copies of solidworks. All those I have where paid for and that is a 4000 dollar program.
Old 01-07-2011, 04:16 PM
540indiana's Avatar
Oh well. I want to stay in good standing on this site. I just thought it was a possible idea. Anyhow, there are enough gurus in here that will bend over backwards to help everyone out. That is priceless.
Old 01-07-2011, 08:37 PM
For the record, today I needed an engine-computer-specific table for the P1 PCodes ... and my paper Bentleys are where I needed to look for it.
- Weird question ... Where are ENGINE-specific BMW P1xxx trouble codes anyway?
It turns out that your chance of finding the correct "P1" PCode tables on the net for your particular engine, transmission, and build date could be slim ... depending on the particular PCode you're looking up.
So, despite what I said above, I hate my paper Bentleys;.I love my paper Bentleys; and I even sometimes use my paper Bentleys!
