Old 01-07-2011, 11:32 AM
desertdman desertdman is offline
Mein Auto: 2001 Z3 3.0i
Question HK Subwoofer Grill replacement
Hey...I'm a newbie to the forum but have been here for the past 3 days carefully reading all the threads concerning care/effect/replacement/fixes for the HK subwoofer. Good Stuff.
I own a 2001 Z3 3.0i and have been doing some interior detailing and repair on it.
I'm in need of the HK Grill that covers the front of the subwoofer compartment. The part number stamped into the plastic reads 51.16-8 398 959 but I cannot find this anywhere on the internet. The problem is that part of the foam material that sits between the metal grill work and the plastic back has deteriorated leaving unsightly inconsistencies while looking at the face of the grill. (Yes, I too am probably OCD about my Z3)
The metal part of the grill is attached to the plastic back by 12 metal "tabs" that are easy enough to bend out, but it is also attach to the plastic back by crimping the entire overhang of the metal frame around the plastic. This has proven impossible to disengage since putting it back together would be next to impossible for me. This seems to leave replacement as my last alternative. I have called some local yards that carry wrecked/damaged Z3's but no one had the correct model with the correct grill.
Does anyone know how to get this part or have one available in great condition? Has anyone altered or repaired theirs in much the same way as I am trying? Any solutions?
Old 01-08-2011, 07:50 AM
BeemerMikeTX's Avatar
BeemerMikeTX BeemerMikeTX is offline
Mein Auto: Z3 3.0i Roadster, K1300S
My solution to my H-K grill foam deterioration was to remove the grill, remove all the remaining foam (including a good vacuuming), and then popping the grill back in. It looks fine. Yes, you can see the speaker through the grill, especially if the suns shines on it at a certain angle, but the grill looks neat and tidy again. Problem solved.
Mike White
"That's right, you're not from Texas, but Texas wants you anyway." -LL
2001 Z3 3.0i Roadster (Topaz Blue Metallic, 5-speed manual, Sport Package, CD radio, heated seats and mirrors, non-power top via special order)
"Beemer" is for my BMW motorcycles - '13 K1300S, '95 R1100RS, '88 K75S, '75 R90S (gone, but not forgotten).
Old 01-08-2011, 03:24 PM
vivace vivace is offline
Vivace
Mein Auto: 2002 Z3; 2003 330xi
Subwoofer Grill without foam
Same problem with grill and I did just what BeemerMikeTX suggested. The grill cleans up very nicely and, if needed, some light matte black spray paint can take out any discoloration or unevenness. My car had been sitting under a tree in Vermont with various sap drippings, including a nice one on the grill, which are very resistant to removal. A very light sanding and a quick spray made it look very sharp. I like seeing the speaker through the grill, particularly with the inexpensive silicone foam repair which shows up as a white ring.
I'm sure you have seen in other postings, but be very careful with the plastic tabs. They are brittle and easily broken upon reinsertion.
Old 11-12-2016, 03:48 PM
khammack khammack is online now
Warning - Thin Air
Mein Auto: 2002 M Roadster/2014 435i
I know this is an old thread, but maybe this can help anyone searching on this subject as I was.
My issue was the same as the OPs. The foam on the inside of the grill was falling off allowing you to see behind the grill in some situations.
I found that the grill can be replaced - https://www.ecstuning.com/b-genuine-...r/51168410429/
for $60, so I decided to try to fix mine. If I screwed it up, then I could always purchase a new one.
As desertdman said, the grill screen can be removed by bending the 12 tabs around the edge of the grill. On mine some of the grill cover material was also pushed around the edge of the plastic on the corners. With a few small tools it was easy to work the grill cover off with no damage. The grill cover is made of metal and does not seem to break easily while bending it. Once removed I cleaned everything I then sandwiched a black glasses cleaning cloth (I think it was made of rayon or something like that) between the metal grill and the plastic (only thing I could find around the house which could work). It worked best if I laid out the cloth on the plastic and then put the grill on top of that. Once sandwiched together I was able to turn everything over and fold the metal tabs back down. I had to use a pick to gently work the corners back into place, but it really wasn't that hard. In all it only took about 10 - 15 minutes. The best thing is I didn't need to spend $60 for a new grill and I am very pleased with the way the grill looks now.
2014 435i M-Sport, Mineral Gray, Black Dakota Leather, Driver Assistance Pkg, Prem Pkg, Tech Pkg, 8 Speed Sport AT, Heated Front Seats, Active Cruise Control, BMW MPPK w/MPE, BMW Limited Slip Diff, BBS CH Wheels.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, Black Soft Top, Steel Gray Metailic Hard Top, TC Kline Double Adj Shocks with H&R Springs, Stromung Exhaust, SSR Type C Wheels.
