Old 12-15-2010, 04:42 PM
jmillet's Avatar
jmillet jmillet is offline
Mein Auto: E86 Z4 M Coupe 7LM08376
Z4M oil drain plug P/N change
I notice the part number for the S54 engine oil drain plug is now 07 11 9 904 550 superseding 07 11 9 910 368. Does this mean the 6mm female Allen plug is gone and we're back to the standard hex head plug?
Jim Millet
2007 Imola Red Z4 M Coupe'
Premium Package, Nav, HD Radio, Heated Seats, CDV Delete, RPI Scoop, Strong-Strut fire wall braces, TCK DA Coil Over Suspension with Camber/Caster plates.
Old 12-15-2010, 05:00 PM
Ron Stygar's Avatar
Ron Stygar Ron Stygar is offline
19,585 Miles
Mein Auto: Z4 M Coupe 6LL93033
Don't know. I like the 6mm which doesn't fall off the socket. I have five left.
Old 12-15-2010, 06:08 PM
blau335 blau335 is offline
Mein Auto: 335
Maybe they finally fixed the first part that was bigger than the allen that people would try to loosen and tighten from which would then ruin the plug.
http://www.youtube.com/watch?v=OqX7IIaXtkg Is it on a dyno? No.
TCK d/a coilovers, Stoptech 6/4 piston BBK, OEM CSL headers
Old 12-15-2010, 06:16 PM
Ron Stygar's Avatar
19,585 Miles
6mm fits nice. I'm using a snap-on one.
Torx fits but destoys it.
Old 12-15-2010, 06:32 PM
Mein Auto: 335
I'm talking about how its tiered. If you only stick it in 5mm or so, it will strip the first "tier" farther in it gets tighter, but I see them come in all the time where people only put it in half way and striped out the first half (which makes it hard to get an allen into the second "tier).
Old 01-08-2011, 07:25 PM
Rex Tener Rex Tener is offline
Mein Auto: S54 M Coupe, S65 M3 Sedan
Here is a picture of drain plugs, from left to right:
S50/S52 - 11.13.1.273.093
S54 - 07.11.9.910.368
S62 - 07.11.9.903.199
I have not ordered the 07.11.9.904.550 yet.
My SK 3/8 inch drive 6mm hex head socket has a loose fit in the several new '368 oil drain plugs I have bought. I usually switch to using a torx 40 after a while and then replace the drain plug.
Rex
Old 01-08-2011, 10:42 PM
Pants Pants is offline
Road Rager
Mein Auto: '06 Z4 SI
Are you changing the drain plug everytime you change the oil?
Mine's still under warranty, so I have yet to beging the self oil change process as of yet.
Old 01-08-2011, 11:07 PM
Ron Stygar's Avatar
19,585 Miles
No. I torque it and the Snap-on 6mm fits nice.
I also have a hole in it for a saftey wire along with the added oil temperature in the sump.
Old 01-08-2011, 11:48 PM
Road Rager
What is the purpose for the safety wire hole?
Old 01-09-2011, 07:15 AM
Ron Stygar's Avatar
19,585 Miles
It doesn't come out.
