Clicking Noise when I brake or Accelerate - Bimmerfest - BMW Forums
Old 01-18-2011, 02:56 PM
dirt_monkii dirt_monkii is offline
Mein Auto: BMW E46 3 Series 320d
I drive a 3 series, E46 2002/03. When I am stuck in a stop/start traffic, i hear a clicking noise on the passenger side's front wheel when i brake. Similarly, when i accelerate, I get the same clicking noise front the front passenger side as well as the back passenger wheel.
The click is only once though. For example, if i was to brake, i will hear the click, and if i take my foot off the brake and then brake again (without touching the accelerator), i wont hear the click again.
Any ideas what this could be?
Old 01-18-2011, 06:31 PM
gordo325xiwagon's Avatar
gordo325xiwagon gordo325xiwagon is offline
Urban Knucklebuster
Mein Auto: '01 325xit & '93 300zx TT
Check your brake pads and the caliper pins. Everything "floats" and if they are sticking, you'll hear a clicking sound. The fix is to loosen then up so they slide. If you pull off the wheels, and begin to remove the calipers and pads, you'll see how they are installed and you'll probably be able to feel the sticking and hear the clicking. gordo
__________________________________________________ ___
2001 325xit & 2012 328i Sportwagon - Evolution of the Brand
Old 01-18-2011, 08:51 PM
marinekilz's Avatar
marinekilz marinekilz is offline
Noone Special
Mein Auto: 01 E46 330 xi
Does the car pull at all at highway speeds when you just barely apply pressure to the brakes?
01 E46 330Xi
06 E92 328i ZSP
07 E92 335i ZSP
E9 One Day It Will Be Mine
Old 01-19-2011, 01:25 AM
I'm not sure if I understand what you mean mate. The faster I go, the less fainter the clicking noise is obviously. The brakes seem to be working fine if I'm honest, the car doesn't feel heavy when i apply the brakes or anything, even at highway speeds. The click comes when pressing the brakes at halfway point.
Thanks mate, will try this at the weekend and get back to you if it does or doesn't work.
Old 01-19-2011, 03:41 AM
zQUEz zQUEz is offline
Mein Auto: 325i
What marinekilz means is, when at highway speeds, if you touch lightly on the brakes, does it pull to one side or the other? If it pulls to the right, then the right side is likely grabbing earlier than the left and should be where you start.
Old 01-19-2011, 11:08 AM
marinekilz's Avatar
Noone Special
well correct, I was thinking thrust rod bushings being worn causing the noise. but checking for a sticking caliper or something in the brake system is also a good direction to go like someone else suggested
01 E46 330Xi
06 E92 328i ZSP
07 E92 335i ZSP
Old 01-20-2011, 01:04 AM
Cheers for clearing that up. It doesnt seem to be pulling any side really. I was on the motorway/highway this morning doing about 80mph and didnt feel anything when i pressed the brake pedal.
Old 01-21-2011, 11:34 PM
mindgames11 mindgames11 is offline
Mein Auto: 1977 benz 230
It might be your fuel economy gauge, I have a similar noise. The faster you accelerate the faster the clicking? Watch the gauge when you change throttle.
accelerate, brake, click, noise
