Ack....regular gas added to diesel X35d - Bimmerfest - BMW Forums
Old 01-27-2011, 01:23 PM
jdibber jdibber is offline
back to bimmer
Mein Auto: car
Daughter accidently added 8 gallons of regular fuel to my X5 35d. After realizing what she had done, she immediately stopped pumping and called me. We had the car towed to the local dealership. The car was never started.
Dealer wants $1200 to flush & clean the tank, replace fuel filter, a rubber gasket and the fuel pump....
why would I need to replace the fuel pump if the car was never started?
many thanks....jd
MY11 35d
Old 01-27-2011, 01:25 PM
UncleJ UncleJ is offline
Mein Auto: '09 Cayenne "S"
Why take a chance, change the fuel pump too. This might also be a candidate for the comprensive section of your insurance policy. Check that out, it could save you a bunch of bucks. It will NOT be covered under warranty! Too bad, good lesson for the daughter, but a costly one.
Old 01-27-2011, 01:35 PM
Newmanium Newmanium is offline
Mein Auto: Zipcars
Are they aware that it wasn't started with the gasoline in the car? Should just be a matter of draining and refueling with diesel, nothing like a 1200 charge. Can you call around to other dealerships?
Past: 2011 X5 35d .... 2007 530i ..... 2002 530i ..... 1999 Honda Civic ..... 1990 Honda Accord ..... 2008 TSX
Old 01-27-2011, 01:56 PM
back to bimmer
Mein Auto: car
thanks for the quick feed back....i did call another dealer and they said if the car wasn't started then the fuel pump doesn't need to be replaced. Now I guess I need to know if the current dealer drove the car into the bay. I gave explicit instructions not to start the car.
MY11 35d
Old 01-27-2011, 02:35 PM
vinsk vinsk is offline
Mein Auto: 2011 BMW X5 Xdrive35D
My cousin pumped diesel into his 2008 Honda pilot when it was brand new, don't ask me how! He thought there was some problem with the nozzle and forced the diesel into the tank by holding it all the time. He drove for around 20 min and engine started making loud knocking sounds, it was so loud that the people on other side of the road could hear it. Finally he towed the car to the dealer and called the insurance, the lady rep never heard about this case and called the supervisor. Eventually the insurance covered it, though it was a long process where insurance didn't agree to change the engine but eventually ended up paying more , replacing each block and piston, exhaust, catalytic etc..... Around 10k
2011 X5D BLK/BLK: Premium, Tech, Cold, Sports Activity, Premium Sound, Rear Climate, Third Row, Comfort Access
2008 MB SLK280 BLK
2006 Acura TL Silver
2006 MB E350 4Matic BLK (Gone)
2001 Nissan Maxima BLK (Gone)
Old 01-27-2011, 03:26 PM
Penguin Penguin is offline
Mein Auto: Z4 and X5 Diesel
How did she get the gasoline nozzle to fit into the fuel opening? Isn't the interlock suppose to prevent the gasoline nozzle from fitting? If the interlock is defective, you might be able to make a case for BMW to provide some goodwill and pick-up part of the cost.
Old 01-27-2011, 03:33 PM
black_fx_35 black_fx_35 is offline
Mein Auto: 2011 X5D
Glad it was your daughter, and not your wife.
Joking of course. I certainly hope things turn out okay for you. Good luck.
Old 01-27-2011, 04:05 PM
TireSmoke TireSmoke is offline
Mein Auto: 2012 Audi A6 3.0T
I know someone who did the same to Toyota RAV4. How it happened? Well, that gas station had both hoses next to each other. The diesel hose didn't fit well, but the person was able to just hold the trigger and fill 1/4 tank. Toyota's tank design allowed some part of the hose to get in. Anyway, there was already 1/4 tank of gas, so the mixture was 50/50. She drove for some time, but the car choked eventually. Toyota dealer took $800 to evacuate fuel and clean out fuel lines (blow air through them). They didn't change fuel filter or anything else. The car is fine (gotta love Toyota for that at least). However, I think putting in gas into diesel might be a more serious offense.
2012 Audi A6 3.0T Quattro , Glacier White/Nougat Leather | Wood trim | Premium Plus: Nav & Google Earth, MMI, Xenons, Parktronic, Rear view camera, Satellite Radio, Google Search, WiFi hot spot | Cold Weather Package | Audi Side Assist
SOLD: '06 BMW 330xi, Sparkling Graphite/Terra Leather | Aluminum trim | Premium | Sport | Cold Weather | Nav | Comfort Access | Satellite Radio | Rear Power Sunshade | Parktronic | Rear Deck Spoiler | Logic 7
Old 01-27-2011, 04:12 PM
samsonitep samsonitep is offline
Mein Auto: BMW
pics of said daughter and wife to determine if I would be mad!
Old 01-27-2011, 04:35 PM
Iron_Chef Iron_Chef is offline
Mein Auto: 2011 X5 50i
Wasn't it not to long back that you could mix regular gas with diesel to prevent diesel sludge in very cold temperatures? Given the correct mixture of course; not like 50/50. The old diesel engines used to be able to handle that. But then a lot has changed with the modern diesel engines.
Hope it wonít be too bad and that they listened to you and didnít' start the engine!
Old 01-27-2011, 04:50 PM
back to bimmer
Mein Auto: car
The nice guys at the dealership provided this "adapter" for those older diesel pumps that might not fit the car....well it so happens those adapters work well w/ regular gas pumps, too...so "technically" it was the dealership's fault ...this is going to be the most expensive piece of plastic I've ever purchased.
MY11 35d
Old 01-27-2011, 04:54 PM
back to bimmer
Mein Auto: car
Originally Posted by Iron_Chef View Post
W
Well....this is what I'm trying to find out. We left a note in the car and a note with in the drop off box w/key. We were in contact w/ the dealership the night before and they told us not to start the car and have it towed....
MY11 35d
Old 01-27-2011, 05:39 PM
gogatorsx5 gogatorsx5 is offline
Girls!
2011 X5 50i
2002 C4 Cabriolet (996)
2011 E 350
Old 01-27-2011, 06:07 PM
Aqua Bliss Aqua Bliss is offline
Mein Auto: e92
You shoulda just filled the rest with diesel then drove it to the dealership and told them the engine sounds weird and you need them to take a look - deny any wrongdoing from that point forward. JK of course
Old 01-27-2011, 06:27 PM
Mein Auto: BMW
Wait I thought the nozzles are different and won't fit???
Old 01-27-2011, 06:54 PM
03BMW330 03BMW330 is offline
Mein Auto: 2011 X5 35D
Here is similar story, I would have gone with solution A
" have just undergone this problem; I accidentally put Gas in my VW Jetta TDI 2011 Diesel Engine, I have had it for about a month, bought it brand new last Christmas, and this mistake happened me owning the car for less than a week, talk about Bad Luck. Had I known what I know now from my experience, I would have saved myself a lot of money. Not to mention avoid the scam of the dealership and the mental agony. I feel obligated to share my experience with you all, so you can get this problem fixed without the horrendous cost to you. This is for cars or trucks that are still under Dealer Warranty or have Full coverage Insurance.
Scenario:
Having put gas in my Diesel engine, I drove the car from the Gas station to my home which is about 5 miles, then I realized the mistake but it was too late. I called the dealership and told them my mishap and I was sent over a tow truck at no cost and was told ?it is not a big deal? bring it over we will fix it. Scam #1: This is NOT covered under warranty. Having Gotten to the VW dealership, I was told all we have to do is drain the Tank and replace the Filter and I will be good to Go; Scam # 2, you have to suck out the Gas from the lines, if need be use a compressor to suck it out, Drain the Tank and change the Filter is only good if you have NOT driven the car, once driven, this is almost never help full. The dealer made my car ready and charged me $650, before I could get home the car had its Coil light on and was not catching any speed. . I went back to the dealer and they said let us do it again as there may be some particles left, charged me another $650 (Total out of my pocket $1300). This did not fix it and I went back to the dealer and they said it is all messed up and gave me an estimate of $9950 which will NOT be covered by the warranty. Below is what I did, which the VW dealer said cannot be done (I claimed it on my insurance), but before you do that ready below Solution A, it is a better route than what I did.
Solution:
Here are the steps you need to take:
Solution A:
1. Do NOT drive the car as soon as you realize
2. Tow the car right away to a ?NON-DEALER? Independent Diesel Mechanic or shop, do NOT use Roadside assistance, or else the Dealer at some point can nail you for it as that record is shared with the Dealership, Pay Cash from your pocket and an independently owned tow company, not even AAA.
3. Tow the car to a ?NON-DEALER? Independent Diesel Mechanic or shop and clean up the Tank, usually should not cost more than $300 and this should fix the problem 9/10 times if you have not driven the car and 5/10 times if you have driven the car.
4. If the car is not fixed at the mechanic?s place at this point, then Tow the car back to your Home (Assuming it does not drive at all) this is imperative, however Ask the mechanic or shop to clean out all the Gas 100% regardless of if it is fixed or not.
5. If the car drives, fill up the tank with Diesel and drive at least 1 full tank, so all traces of Gas are gone.
6. Assuming the car is not fixed or barely fixed or not satisfied with the way it drives, then call the dealership while your car is at home and tell them your problem, DO NOT Mention you put ?GAS? or else the warranty will NOT Cover and the dealer will love to scam you. Just mention the problem and ?You don?t know how it happened, it just did?. This time use the Roadside assistance of the Dealership and tow the car to the dealership or drive the car to the dealership if it drives and let them do what it takes to fix it. Remember don?t be a ?Smarty Pants? and let the dealership fix it, less knowledge is wise at this point. No Matter how much they say that there is Gas in there, remember you know nothing about this, they will try to make this into a ?NON-Warranty? and try to make you pay for it. As far as you are concerned ?The car is not working or working right and it is an engine problem, So FIX IT DAMN IT? put up a fight (Verbal) if need be and ultimately by law they have to fix it as this can never be proven, it could be the gas station has contaminated diesel or whatever, not your business. Be strong and smart or dumb whatever works.
Solution B:
Assuming you were an idiot like me, and believed in ?Honesty the best policy?, then be ready to pay the price of honesty all the way to $10K, I am not rich and can barely make payments for the car, house, and ?wife?, so here is what I did, having told the dealer 100% about the exact situation and to the minute details of what had happened.
1. Even though my Insurance agent advised me against it and the internet did not speak about this, the dealer said: ?I have seen it numerous time, it will never happen, the insurance company will never pay?. The car was sitting at the dealership for over 3 weeks now, I figured what do I have to loose, (I have full coverage with Farmers) I called my insurance company. Believe me when I say, this was the easiest claim I ever filed; ?a walk in the park? could not be easier. I was told I have to pay the deductible, and the adjuster went to go look at it, paid the dealership close to $10K and my car was fixed just as good as new. And Yes, I told the Insurance Company the whole scenario as to exactly how it happened taking full responsibility of the ?accidental fuel contamination? (Key word for insurance claim). This can be done through your full coverage Insurance if Solution A above is not your option.
Good Luck, Its Pay Back Time Dealerships."
http://www.funtrivia.com/askft/Question76677.html
One more thing
"Prevention: better than cure
Some new diesel cars make it virtually impossible to fill up with gasoline. Since BMW launched its clean-diesel 335d and X5 models in the U.S. last year, they have all been fitted with a standard "mis-fueling protection device."
2009 Mercedes-Benz M Class 3.0L BlueTecEnlarge Photo
BMW's prevention device is a special mechanism in the filler neck that requires the larger-diameter diesel nozzle to trigger a mechanism that unlocks to open a flap to permit fueling. Hoses for unleaded gasoline have a smaller diameter, and and cannot trip the catch that operates the device.
Audi has developed a similar system that it will fit to its 2011 diesel models. In the States, those are the A3 TDI compact hatchback and the Q7 TDI sport utility vehicle.
At least one similar device, known as Diesel Key Europe, is available as an aftermarket accessory in Europe. It can be installed by the car owner, says the company, and also has the secondary benefit of preventing siphoning by fuel thieves."
http://www.greencarreports.com/blog/...oline-now-what
Old 01-27-2011, 07:34 PM
listerone listerone is offline
Oil Burners Rule!
Mein Auto: 2014 328d
This is consistent with what I've read in the past...$1,000+ if the engine wasn't started and $2,000+ if it was.This is why I'm the *only* one who puts fuel into my "d".Before I allow anyone else to drive it I make sure it has more than enough fuel for their purposes and then instruct them...*beg* them...not to stop for fuel.
Current: 2014 328d / Mineral Grey Metallic / Nav / Apps / Backup Camera
Formerly:2011 MB E350 Bluetec / Palladium Silver / Nav / Active Cruise / HarmonKardon Logic7
Formerly:2009 335d / Monaco Blue / Beige Leather / Nav / iDrive / Xenon / Sirius / HD Radio
Fuelly
Old 01-27-2011, 08:42 PM
aggie njneer aggie njneer is offline
Mein Auto: X5
Funny story, when I was in Germany last year I rented a diesel mercedes and my friends accidentally returned the car putting regular gas in it and drove it two miles to the rental car return. They never called me or anything maybe because I bought the extra insurance
kck7 kck7 is offline
Mein Auto: 2011 X535D/2011 335IS cv
My wife and I are the only people who will fuel the D, but I suspect it will be mostly me. While I am confident I will not make this mistake (few of us who buy this car on purpose will), I acted all anxious over whether I would make this mistake, mentioning it at least 10 times before taking my wife to the gas station and having her fill the first tank, with me watching. I pointed out to her the green pump handle, the green inside the fuel door, the two labels there, etc. We've also discussed ad nauseam the sound the car makes (it's our first diesel) because it's a diesel. I also make it a point to draw her attention to other diesels on the road (mostly large trucks of course).
I think/hope she gets the point by now. Like listerone above, I will probably make sure that it has enough gas, I mean diesel, before she drives it. Longer trips will be together and I will use them as further acclimation opportunities.
To OP: sorry for your mishap. Remember, it's only money... lots of worse things can happen when cars and youngsters are involved.
Old 01-27-2011, 11:34 PM
edpm3 edpm3 is offline
Mein Auto: X5 35d, i8
Not all. I have seen diesel pumps incorrectly fitted with smaller nozzles meant to fit unleaded gasoline restrictors. You have to either use the adapter, or trip the misfueling prevention latch manually.
Old 01-28-2011, 01:37 AM
335i 335i is offline
Sup3rman
Mein Auto: '11 E90 AW M3/ '11 AW X5d
I found a nozzle in SC that wasn't different than the gasoline version - to avoid any confusion, I just found a different station all together. No telling if the nozzle was pulled off of a gas pump before the diesel use.
I ALMOST had a similar issue outside of Paris 3 years ago - stopping for gas for the 335i, and I see "gaszol" in an orange handle. I swipe my card, pull the pump to the car, and notice it doesn't fit. I try every which way, and ALMOST came to the point where I was going to just hold the handle partially in and pump very slowly (it was 4 am, and we were on a toll road, so there were limited resources). Instead, I walked into the station, and asked why the nozzle didn't fit - and he pointed me to the 2 green gas "petrol" nozzles on the other side of the station.
Now that being said, that's the only time I've ever come close to being confused.. in the US, most all diesel pumps have large signs next to the pump.. but with that adapter, any nozzle will fit unfortunately. There is no fail safe with it, except for the human brain. Expensive lesson to learn - I try to always be the person to fill up the d, as not all pumps auto shut off, and I can't stand having to clean up the mess if it doesn't shut off.
2011 ///M3 Sedan Alpine White/Bamboo Beige/Piano Black ED 9/16/2011
2011 X5d Alpine White/Cinnamon/Bamboo PCD 6/21/2010
2007 335i Coupe - 6MT Alpine White/Saddle Brown ED 5/23/2007 (retired)
ED Trip Report W/ Pics (And Engagement Story/Pics)
Old 01-28-2011, 01:41 AM
Sup3rman
I don't think I would have given the vehicle over until I was physically there to hand the keys over and come to the understanding that it HADN'T been started yet, and that there would be implications if it WAS started before the required work was completed. Did they quote you the difference between the two? For fear of repercussion from BMWNA, I'd likely change the pump - if the pump or engine ever have issues, I wouldn't want that looming.
Old 01-28-2011, 03:37 AM
JMK's Avatar
JMK JMK is offline
'Fester
Mein Auto: '11 X5 35d
sorry that happened...I hope to hear good news about the rest of this!
2011 X5 35d Alpine white/black leather, bamboo, Prem, Prem Sound, Cold, Tech, Sport, Adaptive drive, 20" 214's, CA, spare, active seat package, multi-contour seats, rear climate, roof rails, side-view cam, heated rear seats, auto high beams.
Old 01-28-2011, 04:30 AM
back to bimmer
Mein Auto: car
Originally Posted by kck7 View Post
..... I pointed out to her the green pump handle, the green inside the fuel door, the two labels there, etc. ....
My daughter went to a Hess Gas station (green and white branding) and I guess all their pump handles were green!! She assumed diesel b/c of the green handle.
MY11 35d
Old 01-28-2011, 04:48 AM
back to bimmer
Mein Auto: car
I confirmed w/ the dealer this morning they are not replacing the pumps (I guess there are two), but performing a mini 'rebuild' to clean them out. It makes me a feel a little bit better, but not much, that I'm in the ballpark price-wise....
I grew up on Peugeot diesels, the turtle-like 504s, and really thought nothing of going diesel with this car. Getting diesel fuel was second nature....to me only, unfortunately!
MY11 35d
