4 x 4 light / transfer case actuator - Bimmerfest - BMW Forums
Old 01-28-2011, 03:37 PM
xo xo is offline
Mein Auto: 2001 330ci, 2005 x3
Have had the 4x4 (DSC) light illuminated on the dash (No other lights). Tried a few suggestions from the forums to clear it but to no avail. Also there are no grinding noises. Went into a dealer in Atlanta today and they said there was a fault with the transfer case actuator motor and possibly the transfer case itself. They wanted over $1500 to change out the actuator and if that didn't fix it, over $3100 for the transfer case. The car is a 2005 and has 61K. It is out of warranty.
Anyone ever DIY replace the transfer case actuator? The part is just over $800. So saving $700 on labor seems wise.
Old 05-17-2011, 07:11 AM
Fixer4444 Fixer4444 is offline
Mein Auto: 2005 X3 3.0
Have got the same problem XO, mine is a '05 X3 w/ manual tranny. Been digging in the forum here and some are saying it could be the battery.....I might have to try that first.
Old 05-17-2011, 06:09 PM
X3-terrestrial's Avatar
Aficionado
If you are mechanically inclined, I wouldn't think it would be too hard of a job (the actuator). The transfer case could be something I wouldn't do myself.
I would start getting the BMW T.I.S, (kind of a technical service manual for BMW, you can pay per use online) and see if you can tackle it.
You always have the option on getting an estimate from an Indy shop, they are a lot less expensive than the dealership.
Old 05-17-2011, 06:52 PM
xo xo is offline
Just to bring some closure to my situation:
I went to my indy shop back in February. They confirmed that the codes were for the transfer case actuator. They tried servicing the transfer case, but the light returned during their test drives. I looked at the BMW TIS and got some good info from another member, but determined it was beyond the scope of my abilities. I believe something in the ABS computer has to be reset after the part install.
Anyway $1100 later, new transfer case actuator and no further problems.
Old 11-04-2011, 10:28 PM
dgreen78 dgreen78 is offline
Mein Auto: 07 328i
I just had my unit go out in my 06'. The install is not bad if you have the right tools. Do you have to reset the computer after installing another actuator?
Old 11-05-2011, 08:23 AM
Aficionado
If the light went off by itself, I don't think you need to reset anything. Though it wouldn't hurt to read the code to see if something comes back.
-Mario Andretti.
___________________
River City Bimmers BMW CCA
2002 ///M3 Coupe, Steel Gray Metallic on black leather, HK, three pedals.
1991 E30 325ic, AW, Black Leather, Black top, Three Pedals.
Old 09-26-2012, 10:45 AM
ricardodiazv ricardodiazv is offline
Mein Auto: 2005 X3
does any one know wher the transfer case is on bmw x3 in order to fix the transfer case actuator
Old 09-27-2012, 06:45 AM
ncativo ncativo is offline
ncativo
Mein Auto: X3 2007 3.0TD
The following link may help you to locate and fix the problem:
http://www.youtube.com/watch?feature...&v=bh6HvYcn-HA
I wish I would have found this link before spending nearly $3K to replace the transfer case actuator
Old 09-27-2012, 08:46 AM
j1800l5000 j1800l5000 is offline
Mein Auto: X3 BMW 2007
Had my x3 transfer case motor go out on me found one on eBay $200 labor $225 real problem with price with BMW dealership shop online for parts.
Old 09-27-2012, 05:11 PM
elevatorguy925 elevatorguy925 is offline
Sanity is over rated
Mein Auto: Silver 2006 BMW X3
There is a sticky on this forum about this.
http://www.bimmerfest.com/forums/sho...d.php?t=566880
Silverstar upgraded headlights
Velocity motoring vb3 19" 9.5 wheels
Yokahama S drive tires
Upgraded stereo system
Dice Mediabridge
Hitch install
Old 06-08-2014, 07:37 AM
jvest2000 jvest2000 is offline
Mein Auto: 2006 X3
Hi there, hope this is helpful ... since there is so much information spread out around the internet and in forums on this topic I created a post to try to consolidate it (see below). I did the gear only replacement and so far so good, it fixed the problem. I chose to replace the gear all together rather than risk it failing or slipping back into the worn out portion of the gear, my reasoning being if I was going to spend a Sunday working on this I didn't want to ever have to repeat it
I included my photos and the 3 best videos I found on the problem/replacement:
BMW Transfer Case Actuator Problem And Fix
Old 06-11-2014, 02:43 PM
smaglik smaglik is offline
Mein Auto: 2007 X3, 2003 M5
Thanks jvest! I hope I never have to use it, but at 98k miles, i likely will!
2003 M5
2002 M3
2007 X3 6MT
