F10 / F11 (2011 - Current)
The new chapter in the highly successful story of the BMW 5 Series Sedan (F10) and wagon (F11) |
LED lamps
Where do I get bright LEDs? I wanted to make some cool LED strips for the car but don't know where I can get loose LEDs,
BMWCCA Member #458528 www.bmwcca.org "If Things Seem Under Control, You're Not Going Fast Enough" Mario Andretti |
I want to make LED strip myself...why buy a car that has nothing but LEDs
Not sure why you'd want to do this, but any electronics retailer such as radio shack will sell LED's. Be aware though that LED's are generally rated at 2.1Volts, 20mA, therefore you can't just wire them to a 12Volt supply (cars electrical system voltage). You'd need to do the following:
*Use some kind of regulator to ensure a constant voltage (car voltages generally fluctuate between 12Volts and 14Volts depending on revs of the engine). 7812 regulators can provide up to 1A of current at 12Volts. Assuming 20mA LED's you could provide power to 50 of them with one regulator assuming it was on a heatsink or bolted to the car body. *Know the cumulative current draw of all LED's (assuming 10 LED's at 20mA each, that would be 200mA). *Work out the total voltage drop required from the source voltage (assuming 12Volts and the LED's are 2.1 Volts, you'd need a drop of 9.9Volts). *From the above calculate the size and power rating of the resistor needed to get the required drop. ideally, the electronics store will be able to confirm the specs of the LED's so you can ensure you get the calculation correct. LED's do not like over voltage. They have a tendency to blow up and they stink when that happens. Under voltage will make them dim. Personally, I think you'd spoil the car, but if you're confident go ahead!
535d MSport Carbon Black / Black Nappa / Fineline Anthracite | Visability Pack | HUD | ACC | Adaptive Drive | Folding Seats | 4 Zone Climate | Surround View | Pro NAV | USB Audio | Professional Audio | Sun Roof | Comfort Seats | Heated Seats Front / Rear | Professional Rear Seat Entertainment. Last edited by BimmerUKF10; 02-12-2011 at 05:22 PM. |
Not sure, but he could have meant they may have parts available since they use these items??
BMW-CCA Bimmerfest Supporting Member 2011 535i AT | Black Sapphire/Cinnamon | Premium | Heated Sts | Nav | Sirius | Anthracite Hdr & Trim Prior: 2008 335i 6MT Sedan | Black Sapphire/Terra Leather | Premium | Cold | CA | OEM Alarm Prior: 2005 330i 6MT | Black Sapphire/Sand Leather | Premium | Cold | UGO | OEM Alarm |
Also you are wasting a lot of energy dropping 9 volts, might be better to put them in a series-parallel array and then use a different voltage level regulator. I would personally go with LED units made for motor vehicles. Last edited by jwrtiger; 02-13-2011 at 02:54 PM. |
The main point I was trying to make though was that you can't just 'wire up' a bunch of loose LED's. I agree with you that the beat solution would be something meant for the job.
535d MSport Carbon Black / Black Nappa / Fineline Anthracite | Visability Pack | HUD | ACC | Adaptive Drive | Folding Seats | 4 Zone Climate | Surround View | Pro NAV | USB Audio | Professional Audio | Sun Roof | Comfort Seats | Heated Seats Front / Rear | Professional Rear Seat Entertainment. |
Please don't do it. Just buy an Audi
mujjuman |
Your signature photo says it all! Why change that look?
I wouldn't do it , but you can get some DRL LED strips here : http://www.gorecon.com/products.php?...Running+Lights
