DISA 0 Ring
Looks like someone has brought forth the answer to the 0 ring seal problem---and it's not from BMW--go figure
http://cgi.ebay.com/ebaymotors/BMW-E...Q5fAccessories |
Great find Poolman.
Looking for a DIY? Parts? Check this out, it might be your ticket TMS underdrive pullies - Stewart WP - PSS9 - Beisan Vanos seals - Zimmerman cross-drilled & Akebono Euro - Deka 649 MF - 55w HID headlights - 35w HID foglights - Hualigan double din - ACS (rep) alu pedals - Euro central storage console - Breyton Magic Racing staggered wheels - M5 bumper - M5 steering wheel - Tint Stable: e39 M54, e53 N62 & Tribby |
For example, I already figured out which VANOS seals to buy from them (should Beisan Systems ever stop doing business).
![]() OEM BBS Style 42 (18x9) | Conti DW 245/40-18 | KraftStab Strut Bar | Bilstein Sports | Vogtland Springs | Eibach Sway Bars | Mason Sway Bar Links | e36 M3 Steering Wheel | Biarritz Blue Metallic | Nimble & Graceful
Portland BMW Club Member |
I never understood the DISA (never had to yet) but this is what we have in the bestlinks thread on the problem:
- DISA VALVE FLAP BREAKS: the DISA valve flap breaks, sometimes with parts sucked into the intake manifold (1) (2) (3) (4) (5) (6) (7) (8) & recommended parts (1) (2) & brand selection (1) The DISA system is named rather confusingly in the E39 glossary as: - DISA = Differential Air Intake Control (multiple definitions) - DISA = intake runner length tuning mechanism (multiple definitions) Googling, I find that a rattling tapping sound from the DISA valve can be easily diagnosed without the need for any special tools: - BMW E39 E49 M54 Engine DISA valve rebuild Further googling, I find a new DISA valve goes by a few names & often comes with the o-ring: - Adjusting Unit with O-Ring for Intake Manifold (DISA Valve) ~$215 - Adjusting Unit for Intake Manifold (DISA Valve) ~$215 And that the o-ring can easily be replaced as a DIY (if you find the o-ring): - BMW E39 530i DISA valve o-ring replacement So, as with the lower radiator hose thermoswitch o-ring, the hard part is finding a supplier for that simple o-ring. Thanks Poolman for giving us this link. I'm going to add it to the bestlinks along with the thermoswitch o-ring. Can someone get us the dimensions of this o-ring when they buy a new one? |
- DISA VALVE FLAP BREAKS: the DISA valve flap breaks, sometimes with parts sucked into the intake manifold (1) (2) (3) (4) (5) (6) (7) (8) or the disa valve o-ring fails (1) (2) & where to get just the DISA valve o-ring (1) What we need now is:
This is the clearest explanation yet (if it's correct) of what the DISA valve purports to accomplish ...
Is the DISA Valve O-ring unavailable for M54 engines or no longer available in general?
It's listed for M52TU engines as a $2.21 part on RealOEM (part # 11617504543). |
But that doesn't mean there isn't a similar part that BMW sells that we just don't know the cross reference to. For example, the #4 o-ring below is an exact replacement for the lower radiator hose thermoswitch o-ring (which itself doesn't have a part number). Maybe we can find a similar o-ring in the BMW catalogue for this DISA valve (aka #7 Adjuster Unit). Does anyone know the size of this DISA Adjuster Valve o-ring? Here is the link on realoem for my M54 engine. Realoem clearly lists two different o-rings: # Description Supplement Qty From Up To Part Number Price Notes 04 O-ring 8X3 1 13621743299 $1.25 06 O-ring 7X3 6 11617502761 $0.88 But neither o-ring is for the DISA valve, per se: # Description Supplement Qty From Up To Part Number Price Notes 07 Adjuster unit 1 11617544806 $212.50 Here is the complete listing from Realoem.
This is what you do:
Piece of cake!
Part 11617504543 (O-ring) was found on the following vehicles:
However, I wonder if the size of this P/N 11617504543 0-ring is similar to the o-ring for the M54 engine DISA gasket?
I would be glad to measure the o-ring, just as I did with the lower radiator hose thermoswitch o-ring as I reported over here...
- Please measure the thermoswitch O-ring size! If I had the o-ring in hand. Since I don't have a problem with my DISA valve, and since I don't have the o-ring in hand, I'm hoping someone ELSE will have the o-ring handy (perhaps saved after a DISA valve replacement). If you have an E39 DISA Valve o-ring - please measure and report back! Also, it would be interesting to find out what the dimensions of the known DISA valve PN 11617504543 o-rings are. I find it odd that realoem does not list the size for 11617504543 when I looked just now (at only one model) as shown above. |
I'm thinking that this 0 ring on Ebay is for the m54 engines that didn't come with an 0 ring--I made a gasket to fit and works fine for me--just thought someone might not want the trouble to do that--hadn't thought about it but Fastenal sells all sorts of 0 rings and has them in stock--next time mines off the car I'm gonna check and see if they might have the size that will do the job and post that back here as well.
dealer DO NOT sell M54 o-rings for DISA ( had the same question recently )
This is a Great find Poolman !! Thanks for sharing ! I am going to order 2 right now
When you get the O-ring, can you measure it for us?
Or when you buy 2, just put one in an envelope and send it to bluebee. She will take a very very precise measurement :P Then she will send it back...I think...haha.
Does anyone have a size for the M54 DISA o-ring yet?
Also, anyone with the older DISA o-ring that "can" be bought from BMW ... please measure that too! Then, with both o-rings measured, we can tell if they're the same (or not). More details here. Last edited by bluebee; 02-17-2011 at 11:58 PM. |
Me and 2 other members from Bfc ordered those DISA O-rings from e-bay - the linky posted by Poolman. They never arrived (yet) but the wait time already passed 2 weeks. It seems it's a scam....
Just so you guys are aware. I will keep you posted if there are any changes.
Is the O-ring on M54 DISA units just an O-ring or more complicated? Has anyone measured that one? Per the ebay seller, I enjoyed his responses to some of his negative feedback. |
i have pushed this ebay seller and he finally ( after 2 weeks ) said the o-ring was send
will see soon |
so who is a scammer ? Poolman ??
![]() guy also sent me the tracking number today Last edited by champaign777; 02-25-2011 at 03:17 PM. |
Copying from my post in another thread...
OK, just got my $2.50 version from PelicanParts.com. It measures approx. 50 mm internal diameter (with me trying to get it to stay in a perfect circle) and is 3.2 mm thick, so about 56 mm OD, give or take a few tenths ... ..... And it's green ....... |
Apparently they were not available for the 530? Or maybe a different size for the M54 engine as opposed to the M52? Reference
(I did not bother to check thoroughly)
Looks like that ebay guy is selling the same O ring for every DISA-equipped 6-cyl BMW on the market. Are they all red?
#25
1). I ordered 2 of the DISA o-rings from the link on eBay (above) back on 2/2/11...I plan on seeing if it will fit my 525 DISA.
2). I believe it will fit, very curious. Disappointed by JDM...but they did finally send me an email and let me know, "It's on the way." 3). I am VERY curious about part # above 11617504543 to see if it would fit...it SEEMS that inded it would as Realoem shows that 11617504543 fits: Part 11617504543 (O-ring) was found on the following vehicles: E39: Details on E39 E39 528i Touring E39 528i Sedan E46: Details on E46 E46 323Ci Coupe E46 323Ci Convertible E46 323i Touring E46 323i Sedan E46 328Ci Coupe E46 328i Sedan Z3: Details on Z3 Z3 Z3 2.5 Roadster Z3 Z3 2.8 Roadster Z3 Z3 2.8 Coupe 4). Star Wars is on Cartoon Channel tonight fyi. Last edited by HanSolofliesBMW; 02-18-2011 at 05:08 PM. |
