E46 (1999 - 2006)
Old 02-21-2011, 06:44 PM
terpjam terpjam is offline
Mein Auto: 2003 330 CI
Another Possibility of a P00128
After reading the code and following the options posted on the site, I ordered a few parts for my 97K 330CI including a water pump, belts, idler, tensioner, etc. Problem is that as I got started, I the real problem. Thanks to Smolck for the Mechanical fan nut loosening technique getting access was pretty straight forward and I had all the right parts. Water pump was probably not that old, (only had the car since 89K) but at least I don't have that worry for now. Funny thing is that the car ran for about three weeks with half an idler.
ID:	267332   Click image for larger version
ID:	267333   Click image for larger version
Old 02-21-2011, 06:56 PM
mrblorry's Avatar
mrblorry mrblorry is offline
No User Serviceable Parts
Mein Auto: '04 545i, Schaltgetriebe
That's amazing. Not only was the pulley gone, but your belt rotted so bad, it was ready to snap in two at any moment whether the pulley was there or not. You look under the hood how often??
-Steve
Old 02-21-2011, 07:12 PM
Make sure you know about the cn90 trick for putting the fan nut back on straight without stripping the threads (ask me how I know).
- Tools necessary for a cooling system overhaul
- Cooling system overhaul tips (fan clutch nut removal tools) (cn90 fan clutch nut replacement trick) (bb hose removal trick) (o-ring replacement parts)
The reason I know how to make mistakes is I make 'em all!
- My cooling system overhaul mishaps (broken radiator nipple) (crooked fan clutch nut) (broken bleeder screw) (thermostat loom misplaced) (broken expansion tank nipple & cn90 repair) (expansion tank fell apart inside)
Pretty amazing picture. Even though it's an E46, the stuff looks the same as my E39 so I think I'll add it to the E39 bestlinks for the belt drive replacement DIYs!
- Recommended parts list for a complete belt drive system overhaul (1)
Old 02-21-2011, 07:22 PM
mrblorry's Avatar
Darn. I was gonna ask you some questions as I'm thinkin' my next car is gonna be an E39, but it looks like your car is missing two cylinders.
-Steve
Old 02-21-2011, 07:55 PM
I bought the car five months ago and learn/fix something new nearly every week. I have completed the following:
Valve Cover Gasket
Plugs
Pre-Cats
CABs (A particularly difficult repair when the Haus sends you two right wheel CAB housings)
Water Pump
Two Oil changes.
Belts, Pulleys, Tensioner
Vacuum hoses
Removed the Ghetto Woofer in the trunk.
Took the 19" M6 clone wheels off and put the original 17" OEMs back on.
Added a Blue tooth the the after market system.
Fuel Filter is next up. Expect to get through the other items picked up from reading the site over the next 3-6 months, but I do live in New Orleans so working on my car only happens if the hang over isn't too severe.
Old 02-21-2011, 08:10 PM
mrblorry's Avatar
Welcome to the club. I've been fixing things regularly as well. No ghetto woofer to remove though. Smells like teen neglect to me. Good luck.
-Steve
