Old 10-20-2010, 04:49 AM
X3cellent! X3cellent! is offline
Mein Auto: X3
Spare tire
I currently have a 2007 X3 with run flat tires, but I purchased the car CPO. As far as I can tell the spare is still attached to the back underside of the car. I will probably go back to regular tires, but would like to check the pressure in the spare and if I need a replacement where would I get this from and wonder how much it would cost. Is the spare easy to take out and put back so I could check the tire pressure.
Old 10-20-2010, 05:01 AM
X3-po's Avatar
X3-po X3-po is offline
Mein Auto: 2009 X3
If the spare was installed correctly you do not need to remove it to adjust the pressure as there is on area at the rear where you can reach the valve stem.To remove the spare you undo the large nut and release the long handle that drops the carrier to the ground.If you need a replacement spare assy.your best bet would be a salvage yard or online.
Old 10-20-2010, 05:05 AM
vern vern is online now
Send a message via AIM to vern
Mein Auto: 01 330ci 05 530i 06 X3
Thumbs up
[QUOTE=Alex102366;5558839. Is the spare easy to take out and put back so I could check the tire pressure.[/QUOTE
Its easy, just follow the instructions in the manual. Good luck
cheers
vern
2012 335iA Blk. Sapphire- Sport-Blk. Dakota Leather/Red-Brushed Alum.Trim-DAP-PP-CWP Rear View Camera-BMW Asst w/Enhanced BT&USB-High Gloss Blk.Trim Hghight-PSP-Speed Limit Info-Tech. Pkg-PDC-Rear Manual Sun Shades-SAT-Variable Sport Steering-Wheel Locks- Rubber Matts-Euro Del 5/14/12-Redelivery 7/16/12 2006 X3 3.0iA 4/6 Silver Gray Metallic-Black Leather-Nav-PP-SP-Xenon Headlights-PDC-Heated Front Seats-Privacy Glass-Servotronic Steering-Premium Sound System-R R R- Wheel Locks- Rubber Matts
Old 10-20-2010, 06:40 AM
AzNMpower32's Avatar
Tar Heel Faithful
Mein Auto: X3
I would remove the spare tyre at least twice a year anyway because a lot of road dust and gravel gets caught up in the wheel and causes corrosion. I think the correct pressure is 4,2 bar (check the manual to verify).
Old 10-20-2010, 06:44 AM
SWMc SWMc is offline
Mein Auto: LCI X3
My only caveat is to keep upward pressure on the lowering handle while you fold it up.
If for some reason the tire itself is bad contact Mac at Tire Rack. He's very knowledgeable on mini spares and can get you a replacement tire. I contacted local tire shops about them and they all said it was a dealer only item.
Name:	Mac at Tire rack.jpg
Old 02-21-2011, 09:47 PM
Bearcat's Avatar
Bearcat Bearcat is offline
Mein Auto: 01 530ia Sport, 2010 Golf
Would the spare tire assembly fit the new X3?
Old 02-22-2011, 02:50 AM
Evlengr's Avatar
Evlengr Evlengr is offline
Ukemi - that's how I roll
Nope. the whole back well area is completely different.
2007 AT X3 RIPOS
2005 GC
2000 Jeep Cherokee
1997 Twin Turbo RX-7
