Radio? - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 02-24-2011, 11:42 AM
my car goes psh my car goes psh is offline
Mein Auto: supra 328is
Radio?
My radio stopped working so I bought a new deck and a new harness as well. So I hook all the wires to there colors and it still is not working. If anyone noes the wire diagram post it please and thanks
Old 02-24-2011, 11:45 AM
bmw1992 bmw1992 is offline
Mein Auto: 1996 328i
Does ur car have a factory amplified system?
Old 02-24-2011, 11:47 AM
Just Bryce's Avatar
Just Bryce Just Bryce is offline
Mein Auto: Slammin Taco
Are you sure you didn't just blow a fuse and there is no power ?
Old 02-24-2011, 11:48 AM
I checked all the wires for power and the solid red wire only has power
Old 02-24-2011, 11:53 AM
Just Bryce's Avatar
There should be one with constant power ( live all the time and connects to the yellow wire on aftermarket head unit) and one with switched power ( off and on with the key and connects to the red wire on the aftermarket head unit)
Old 02-24-2011, 11:56 AM
I check the fuzes
Old 02-24-2011, 01:03 PM
ryder23's Avatar
ryder23 ryder23 is offline
BuckFifty
Mein Auto: 1998 328i Manual
Did you use a volt meter to check? The red one should show constant 12V and make sure you got the right ground wire too hooked up too. On mine the brown is GND.
Old 02-24-2011, 01:36 PM
Ellemus Ellemus is offline
Mein Auto: 92 BMW 318is
you might want to check to make sure you have the remote wire (blue) tied in, also check your ground (black) on the car and be sure its actually grounded, and if that still doesnt work connect the power (red) and the accessory (yellow) by splicing the accessory into the power wire! good luck
Old 02-24-2011, 03:50 PM
I found the problem it was a fuze easy fix
