E36 (1991 - 1999)
Old 02-24-2011, 04:42 PM
MrJanka MrJanka is offline
MrJanka
Mein Auto: 97' 328i Cab
M50 Manifold DIY???
Okay, so i've been searching around looking for a GOOD m50 manifold install. They all seem to be long gone or removed. If anyone happened to copy the Team-Bar's DIY before their link
died or know of a good one please let me know. I don't want to spend $170 on a kit that someone put together for 50. I would like to make the fittings myself but there are no tutorials that show measurements or explain what is actually being moved around.
Has anyone found any useful links..?
Old 02-24-2011, 06:11 PM
drive by72's Avatar
drive by72 drive by72 is online now
I feed trolls
Mein Auto: 3 series
I just got a kit+mani on ebay. I'll measure everything up and give ya some specs. I wanted to do this myself too but found myself in your predicament, so I just bit the bullet and got lucky with a used kit
RIP Ben "Jever" Doebele, we wont forget you
Hi, I'm Chad. Talk to me or GFY
1997 328iS... HR coilovers, Brembo F40 calipers, camber plates, so many more cool things!
1993 Chevy K3500 CUMMINS 6BT 5 speed with 19.5" commercial grade wheels. Pulling 15k pounds going 75mph up a 7% grade... cake
Old 02-24-2011, 06:15 PM
CDirks's Avatar
CDirks CDirks is offline
Is a real boy
Mein Auto: White 1997 328i
Well you can follow the Pelican article for removing the old manifold, which isn't too hard. The nut closest to the firewall is a bastard.
As far as the adapter kit goes, you're dead on thinking you don't need to buy a kit for $150. They're absolutely overpriced. All you need is the necessary hosing with a bunch of hose clamps and connectors.
In the end, the hose needs to look like the blue piece in this picture courtesy of Bimmerworld:
That piece connects the crankcase breather to the manifold and the ICV (I believe). I'd say before taking all the vacuum hoses apart under there, as there are a good amount of them, label where things go with tape or something similar. I started the swap process and didn't label anything. I ended up not having the right parts, and was left with a large vacuum leak, and a screwed up car (I connected the vanos plug into a plug on the fuel rail. Needless to say it ran like crap).
Other than that, make sure you have all the gaskets: the 6 for the m50 manifold, 1 for the throttle body, and enjoy the swap experience.
!!!ALSO!!! I don't know what you've got for mileage, but when I took my M52 manifold off, two of the injector tips cracked. It was an easy enough fix to get the repair kits for $6 per tip, but just a reminder: they can be pretty brittle and crack easily. Depending on how lucky you are, a piece or two might fall into the actual cylinder. Be ready for it
Manifold Removal
Bimmerworld Adapter
Old 02-24-2011, 06:31 PM
MrJanka
That would be awesome! Also, let me know if there was anything difficult about the swap. And if theres anything in particular I need to prepare myself for. What could make it easier, stuff like that.
I've been thinking doing a write up on this swap when I go through with it. Its seems to be a pretty wanted mod for us e36er's and we cant seem too find anything but half assed write ups on the net...
Old 02-24-2011, 06:39 PM
MrJanka
I feel comfortable with piecing my own kit together. I just don't know where the main plastic piece that actually enters the manifold came from?
Old 02-24-2011, 06:59 PM
TRaV MaNN's Avatar
TRaV MaNN TRaV MaNN is offline
Somebody stop me....
Mein Auto: EW/// 86
Unless your crusing at 4500 RPM's and higher, you'll actually lose some torque down low
You can’t spend all your time worrying about where your next Twinkie is going to come from, so follow rule #32 and Enjoy The Little Things.
Old 02-24-2011, 07:15 PM
MrJanka
Yeah, i've read that. But about 80 percent of people who have done the mod claim they can't even feel the loss. It makes plenty of sense. Bigger bores = Better air flow + OEM part + $27.00 at Salvage Yard = Cheap Gains. Essential if your up for future upgrades. You can tell the M52 is choking for air at higher rpm's as is.
Old 02-24-2011, 10:18 PM
drive by72's Avatar
I feed trolls
Mein Auto: 3 series
Amen to that. OEM upgrades rock, because you can tell people its stock and they believe it, until you race them The way I look at it is this: Low end power is the stuff that gets you into trouble, because either you have too much fun with it, or you accidentally get too comfortable with it (without suspecting it). When your in the high range, you know what your doing with the gas, and youre there 97% of the time when your racing anyway. Get what I mean?
