Interesting warranty fix - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > Z Series > E89 Z4 (2009 - current)
Old 02-26-2011, 01:58 PM
Z4golfer's Avatar
Z4golfer Z4golfer is offline
Mein Auto: 2011 Z4 35is
I've had a rattle in my passenger side tail pipe for months and have just lived with it until this week. The butterfly valve would rattle when it was in the closed position. I took it into a BMW dealer to be fixed this week and they said that they were directed by BMW to spot weld it in the open position.
From what I've read, it's purpose is to reduce the sound at low rpm's. If that's it's only purpose, I'm fine with the fix.(It sounds good) However if it is also for back pressure, I'd like them to actually fix the problem by replacing the muffler.
BMW obviously engineered the flap for a reason and I probably could demand that it be corrected under warranty.
If anyone knows the exact purpose of the valve, please let me know.
Here is a link to my original post back in August.
http://www.bimmerfest.com/forums/sho...866&highlight=
2011 Z4 35is
2014 X3 28i
Old 02-26-2011, 04:04 PM
rmorin49's Avatar
rmorin49 rmorin49 is offline
Mein Auto: 2011 335d
I think it is for one or both of these reasons:
1. Sound control at lower RPMs
2. Faster engine warmup
Others will jump in and correct me if I am wrong.
COL(Ret), US Army
Hagerstown MD
2016 528ixdrive/MSport
2016 Corvette Stingray (Fun Car)
2013 Audi A6 (Ret)
2013 Audi A4 (Ret)
2010 Z4s30i (ED) (Ret)
2011 335d (Ret)
2009 335i vert (Ret)/ED/PCD
2007 335i vert (Ret) ED/PCD
2000 740iL (Ret)
1998 328iC (Ret)
1990 535i (Ret)
1988 635CSi (Ret)
1985 M635 Euro (Ret)
Old 02-27-2011, 03:37 AM
Rubber Ducky's Avatar
Rubber Ducky Rubber Ducky is offline
Mein Auto: '15 M3 DCT; '14 Stingray
Dunno what might be in engineers' minds (I've worked with engineers a lot in my lifetime and that's a permanent bafflement) but can say no adverse effects of having the butterfly valve open all the time. A bunch of us have removed the short vacuum line that actuates it and capped both ends with no ill effect and better low-rpm sounds. I'd say fret not.
Old 02-27-2011, 06:45 AM
rmorin49's Avatar
+1, I did the same thing on my R32. Car sounds better and I have observed no adverse effects. Has been in to the dealer for several routine maintenance visits and no mention has been made of any effect on engine diagnostic codes.
COL(Ret), US Army
Hagerstown MD
2013 Audi A6 (Ret)
2013 Audi A4 (Ret)
2011 335d (Ret)
2000 740iL (Ret)
1998 328iC (Ret)
1990 535i (Ret)
1988 635CSi (Ret)
Old 03-01-2011, 07:22 AM
need4speed's Avatar
need4speed need4speed is offline
Mein Auto: 16 435 CV Msport PPK
Isn't this the same as the "golf tee" mod? N4S
Old 03-01-2011, 08:31 AM
Well, yes, but without the golf tee... Carburetor caps work better. http://www.amazon.com/Holley-26-105-...1&sr=1-1-spell
Old 03-01-2011, 10:06 AM
Z4golfer's Avatar
When I was a kid, we'd sometimes clip playing cards to our bicycles for a cool sound as it slapped the spokes. However, I don't remember the man at the bike shop doing the same to prevent me from hearing a rattle in the chain.
2011 Z4 35is
2014 X3 28i
Old 03-01-2011, 10:38 AM
HerrK's Avatar
HerrK HerrK is offline
From the Society of Automotice Engineering and bafflement dept, the light vehicle sound standard is SAE J1492. The sound level is measured and averaged from idle to 3/4 of rated engine speed ramped up over a max 15 second period. J1492 details how to conduct the test based on exhaust orientation, location of instrumentation, surface, backgound noise, etc. 95dB (A Scale) is the max most states and mfgs have adopted. So if it is quieter at idle it can make more noise at the higher speeds.
Thus the flapper in on leg of the exhaust system, to keep the average sound pressure down at idle. The flapper has nothing to do with vehicle warm up.
HerrK - Keine Eifelfahrt ohne eine Runde über den Nürburgring
May 2010 ED l 2011 35i l Crimson over Ext'd Coral Red w/brushed Alum l 6sp MT l Prem Sound l Sport Pack l 296's l Comfort Access l Alarm l Power Heated Seats l & Nav.
FrauK - 2014 Q5 TDI - May 2014 ED | Cuvée Silver over Pistachio beige | Premim Plus | MMI | Nav | B&O
Old 03-01-2011, 05:41 PM
rmorin49's Avatar
I stand corrected on the vehicle warm up issue.
COL(Ret), US Army
Hagerstown MD
2013 Audi A6 (Ret)
2013 Audi A4 (Ret)
2011 335d (Ret)
2000 740iL (Ret)
1998 328iC (Ret)
1990 535i (Ret)
1988 635CSi (Ret)
Old 03-02-2011, 09:39 AM
Z4golfer's Avatar
Thanks HerrK
2011 Z4 35is
2014 X3 28i
HTML code is Off
