E46 (1999 - 2006)
Old 02-22-2011, 09:05 AM
alintatoc alintatoc is offline
Mein Auto: Bmw E46
E46 - airbag problems
Hello everybody
Is there any way to reset the airbag light on the dashboard without going to the dealer?
Can one OBD scanner (not original Bmw one) delete the error of the airbag?
Thank you in advance!
Old 02-22-2011, 09:33 AM
mujjuman mujjuman is offline
tappa tappa toit
Mein Auto: hoopty
I don't think so, sorry.
mujjuman
Old 02-22-2011, 10:01 AM
Mein Auto: Bmw E46
What about this?
Old 02-22-2011, 12:18 PM
ECSTuning's Avatar
Instructor of the Stig™
Can't go wrong with PEAKE!
Manufactured specifically for BMWs, Peake scan/reset tools make servicing your BMW cheaper and easier than ever.
The tool easily connects to your diagnostic port in the engine bay and allows you to read any codes for a check engine light as well reset your oil service and inspection light with the push of a button.
This tool is a must for the first time do-it-yourself mechanic and to complete any tool box.
Click HERE to order or for more information.
Please let us know if you have any questions! Feel free to shoot me a PM or email.
Best,
Joe
Customer Service Hours: M - F 8:00am - 8:00pm EST | Saturday: 10:00am - 7:00pm EST
Sales Team Hours: M - F 8:00am - 11:00pm EST | Saturday: 10:00am - 7:00pm EST
800.924.5172 | OEM BMW Part Number Search
Click HERE to read what people are saying about ECS Tuning
Old 02-23-2011, 05:14 AM
Italianchick328 Italianchick328 is offline
Mein Auto: 328i sport 5spd
I have the same issue on my 2000 328. The stupid airbag light keeps illuminating on my instrument cluster. I took it to my shop that has a BMW dis tester and fault code reader. They reset it, but it just came back on a couple of days later.
Old 02-23-2011, 05:22 AM
controlfreak101 controlfreak101 is offline
Mein Auto: 06 330i ZPP, ZSP, 6MT
Check your battery connections. There is a pigtail wire that if loose will trigger an airbag light.
Old 02-23-2011, 06:47 AM
Do you know that you don't actually HAVE an airbag problem?
- What can cause an airbag light (1) (2) (3) (4) (5) (6)
- SEAT CABLES BREAK: seat cables that fall out causing seat twist (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) & accidental airbag light fix (1) (2)
Old 02-23-2011, 04:29 PM
e46_platform e46_platform is offline
Mein Auto: 2002 330Ci 5M sport
Originally Posted by alintatoc View Post
What about this?
like the only comment to this youtube video says, this tool can't be found from their website.
however, from related videos, i found this one kinda interesting, but may seem a little fishy.
it shows a webpage that doesn't look professional, but claimed a copyright for their method.
and u need to pay before they would even say anything specific about the method.
based on my experience with this forum and some other similar ones, BMW fans are willing to share excellent, costless ways of fixing BMW problems (like the zip-tie fix for a failed windows regulator). but no one ever said they knew of a solution to the airbag light issue without using proper scan/reset tools.
so according to rational thinking, it's just hard to believe that such a solution exists.
i suspect the solution that costs you $7 to be told is probably something like disabling the light, or even removing the bulb.
(i actually did that to my old corolla, whose seatbelt light keeps flashing while the seatbelt is already buckled up. so i opened up the instrument panel and removed the bulb)
anyway, does anyone think if it's worth a try to pay www.bmwairbag.com $7?
Old 02-24-2011, 12:23 AM
jcjdavis1's Avatar
jcjdavis1 jcjdavis1 is offline
Mein Auto: E46 1999 323i auto
Hi. An easy way to get rid of 'Airbag' light- http://shop.ebay.com/?_from=R40&_trk...All-Categories
Simple to fit . Jim
The older I get the wrong bit gets stiff!!
Old 02-25-2011, 12:59 AM
no idea why i haven't heard of "Passenger Seat Occupancy Mat Bypass" way to fix the airbag light issue.
all i remember was that it requires a scan/reset tool that is capable of resetting the airbag light for BMWs
to save even more money than buying a sensor bypass unit, like jcjdavis1 mentioned above, i am following what these two guys do:
and
http://www.bmwfanatics.co.za/showthread.php?tid=10737
just bought some 100 ohm resistors and 1N4001 diodes from radio shack today and will build the unit and insert it to the circuit under the passenger seat tomorrow
100 ohm resistors: 5x for $0.99 (only two are needed)
diodes: 2x for $0.99 (only one is needed)
this simple sensor-bypassing mod basically tells the ECU that there's ALWAYS a passenger on the front passenger seat...
so that in case it determines to deploy the airbags, it will deploy the front passenger airbag, which means, having this mod done, you should never have an underage kid at the front passenger seat.
hopefully, the light will be off when i finish this mod/fix... some claimed that it still requires a reset tool to turn the light off even with this sensor-bypass fix done.
Old 03-02-2011, 04:06 PM
and
since the $2 DIY fix was completed a few days ago, i've driven over 400 miles with and without passengers.
and the problem is gone!
i didn't need a scan/reset tool to reset it, maybe because the airbag light wasn't always on before the fix.
Old 03-18-2011, 11:56 PM
Totte Totte is offline
Mein Auto: E83 X3 2.5si (2009)
+1 on this fix, did it a week ago and it works perfect
