Air bag light ON with no codes... - Bimmerfest - BMW Forums
Old 03-03-2011, 10:35 AM
vetaldj vetaldj is offline
Mein Auto: 2015 VW eGolf
Question Air bag light ON with no codes...
Hi All,
I have following situation:
My SRS light is on by following pattern:
- turn key to 2: light is on, then in 2-3 sec off for few sec and then back on
after that stays on.
I checked AIRBAG unit with carsoft 6.5 and it says OK without any codes. I did reset it just in case. Also I've noticed that I have errors in Instrumental Clusters module but didn't see codes yet (just was able to set up carsoft finally).
Why it's on then if no codes? Can it be some electrical problem (fuse, connector etc). BTW I check passenger seat mat - all connections are fine there....
Old 03-03-2011, 10:41 AM
Dunno.
It's good you checked the mat.
Maybe it's something else in one of these threads?
- What can cause an airbag light (1) (2) (3) (4) (5) (6)
Old 03-03-2011, 10:45 AM
Flybot's Avatar
Flybot Flybot is offline
Mein Auto: '98 528
I know nothing about Carsoft, but if its showing an airbag light, there is a code for it. I dont think its reading the BMW properly.
Old 03-03-2011, 10:49 AM
Thanks for quick answers... Will need to get SRS reader to check it out and get second opinion on codes...
Old 03-03-2011, 01:11 PM
Spencercat Spencercat is offline
Mein Auto: '03 540i/6
That's funny I've used carsoft 6.5 to read and clear codes from my SRS. Are you connecting to the plug in the engine compartment or under the drivers dash?
Sent from my Droid using Bimmer App
Old 03-03-2011, 02:34 PM
I didn't realize Carsoft 6.5 could reset the airbag light.
We should add that to one of these threads, for reference purposes, so that all knowledge is in the canonical threads for ease of location.
- Description of Carsoft, GT1, INPA, DIS, EDIABAS, & Peake (1) & which can modify the auto-lock car door feature (1) & what does Carsoft do anyway (1) (2) (3) (4)
Old 03-03-2011, 03:17 PM
I've used under the hood ones. I will played a little bit more with it...
Did you used real serial port or any adapters to connect unit to laptop?
Old 03-03-2011, 03:29 PM
usedbimmer usedbimmer is offline
Send a message via AIM to usedbimmer
Mein Auto: 1997 540i
Question:
It just so happens my airbag light is on. Seems to have happened after my kid dinged the rear end into the mail box.
I don't have a code checker
What do you mean by checking the passenger mat?
Dunno.
Old 03-03-2011, 04:13 PM
xraye39 xraye39 is offline
Mein Auto: 530i
It has been noted that Carsoft can reset/read SRS codes for years, I am sure even prior to my post in 2009 it has been discussed.
See post #4 http://www.bimmerfest.com/forums/sho...t=#post4721162
2003 530iA Sport - Titangrau Metallic/Schwarz Montana
Build Codes: ZSP/ZPP/ZCW. Born on date: 09/02, Dingolfing, Deutschland
| NAV MKIV | PP | CWP | Xenons | Style 42s | Rear Shades | OEM ULF Bluetooth | Euro Armrest | Beisan Vanos Seals |
2003 530i/5Spd Sport - Titanium Silber/Schwarz Montana
| PP | Xenons | Style 42s | OEM TCU Bluetooth | Euro Armrest | Beisan Vanos Seals |
2001 525iA - Anthracite Metalic / Grau Montana
Sold but in the "family"
Old 03-03-2011, 07:23 PM
I used a staples USB to serial adapter, but the driver makes my laptop crash running XP.
We have to be careful ... I won't say much more than this ... as there was a thread that the mods closed and deleted half the posts on ... but there's "Carsoft" and there's "Carsoft".
Some of the things Carsoft says it can do, Carsoft actually can't do.
PM me if you don't know what I'm talking about.
But the point is that it's good if the specific Carsoft version can actually reset the airbag light! That's the main takeaway here.
Old 03-03-2011, 07:27 PM
BTW, if you have good links for "resetting" the airbag light, let me know as I should update the links for everyone to benefit.
- What can cause an airbag SRS light (1) (2) (3) (4) (5) (6) and what can reset it (1)
Old 03-03-2011, 08:12 PM
lild's Avatar
lild lild is offline
livin the 'Fest
Mein Auto: 97' 528i, 06 ninja
two ways to reset the light, one make sure all the sensors are working properly, two use the proper tool to reset it. plus, it has also been noted that if you have worked on the doors, and unpluged the airbag and didn't dissconect the batt. first it will set off the light, and needs a reset tool.
NOTE-----PLEASE BE VERY CAREFULL USEING CARSOFT SOFTWARE, IF YOU DON'T HAVE COMPLETE KNOWLEDGE ON HOW TO USE THE PROGRAM YOU CAN RENDER YOUR CAR UNDRIVEABLE.
The more you complain, the longer God makes you live. SPHOBA #00002
Old 03-04-2011, 10:00 AM
I'm using Carsoft just for diagnostic no more no less, don't want to ruin it with that staff.
Thank you all for answers! Looks like I'm going to eBay to buy SRS tool...
Old 03-04-2011, 04:39 PM
It would be great if you like this tool (just click the picture):
And then report back to the team how well it works.
Old 05-26-2011, 12:46 AM
nieye nieye is offline
Banned
Mein Auto: l
You are very powerful!
