#51
That previous 318i post is unbelievable. What on earth happened to the education system in the years since I graduated from high school?
Anyway, a great thread today confirmed, in addition to what ElwoodBlues posted, there's yet another type of mechanical tensioner that looks different than the ones pictured prior. Since the identification of the type of tensioners is visual, I'll repost the picture here from a 2003 BMW 525i. Notice the lack of the raised molded nut. Instead there's a sunken Torx #60 indentation. Who knew! Last edited by bluebee; 11-15-2010 at 04:45 PM. |
#52
Current Vehicles: 2003 E39 525i 2008 E70 X5 Past BMWs: 2001 E46 325i 2001 E46 330ci |
#53
Again for cross referencing purposes, here is a photo of a BMW E39 M54 hydraulic tensioner where the author advises against removing the pulley with the T50 Torx.
#54
Personally, I don't advise replacing a mechanical tensioner with the so-called hydraulic tensioner (which is merely a spring in a tube of oil) ... because of the myriad complications and increased cost and non-proven value.
Here's a recent post today of someone who mentions some of the drawbacks: "Oh BTY BMW dosen't sell the pulley wheels for the spring loaded tensioners but they will gladly sell you an upgrade for hydralic tensioners at four times the price of a replacement wheel fro the spring type, oh and the special wheel for the hydralic type is extra" (sic) I wonder if anyone recommends a hydraulic replacement kit over a simple replacement of the mechanical tensioners with like tensioners? |
#55
As a cross reference, I came here to quote a diagram of the mechanical belt-drive system and was surprised I hadn't posted it here before.
So, for reference in the future, here it is (for my 2002 525i) from the threads: - One users' example of total electrical failure (AAA towed away) alternator repair (1) (2) - Video of cold idle engine squeal (1) - Recommended parts list for a complete belt drive system overhaul (1) etc. |
#56
There was a strange post this week where the owner had half of a hydraulic tensioner hanging there ... without the other parts ... so we suspected the previous owner could have started a conversion of mechanical to hydraulic but left it undone ... and didn't add the compressor belt back (if you can believe that).
Anyway, in looking up help for that person, I had to go again to the mechanical to hydraulic conversion kit parts thread and just in case that thread disappears, here are the photos from that thread: - Changing from Mechanical tensioner to Hydraulic tensioner for your serpentine belt drive Here is the Hydraulic tensioner from realoem that you will need to buy: http://www.realoem.com/bmw/showparts...90&hg=11&fg=18 Here is the mechanical tensioner from realoem note: This is just a comparison so dont buy this one) http://www.realoem.com/bmw/showparts...05&hg=11&fg=18 And, here is a conversion kit from mechanical to hydraulic (although not for the E39) from that thread: - autohauz mechanical to hydraulic tensioner conversion kit |
#57
Here are pictures of these respective links from that reference thread:
Quote: *******>********>*******>********>*******>********>
#58
For those of you who have curious mind, you may want to read the following article discussing the pros and cons of mechanical vs hydraulic tensioners.
Those of you with engineering background will like this article. Also, for those who want to read about Hydraulic Tensioner: it is basically like a car suspension with a Spring + Strut (to absorb sudden shock). In the Hydraulic Tensioner, the Spring maintains the proper tension. The hydraulic oil works like a Strut to absorb sudden changes in TB tension. Here is a very good link to read on how Hydraulic Tensioner works. I also uploaded this pdf file to this forum in case they delete the pdf from their website in the future! See attachment below for pdf. http://www.gates.com/europe/file_sav...Tensioners.pdf I am attaching a picture for a quick read: Last edited by cn90; 01-20-2011 at 08:32 AM. |
#59
For the cross linking record, dcotti wrote up his hindsight recommendations over here for what he'd do differently the next time he replaces his 2003 tensioners and belts.
- Belts / Tensioner s/ Idler Pulley Replacement Notice that he had two mechanical tensioners, one of which was the TORX and the other the HEX pry point. It seems that only the 2003 is so afflicted with the torx pry point. Also dcotti described what he'd remove next time he contemplates the same job. Last edited by bluebee; 02-26-2011 at 11:12 AM. |
#60
For the record, G. P. Burdell, over here, kindly provided a pointer to the following BMW alternator-belt tensioner retrofit service bulletin:
Note the following BMW SI B 11 04 03 details:
The question I would have is, since most cases of noise are in the bearings, not in the spring, what is in a so-called hydraulic tensioner that would cause it to be less noisy than a mechanical tensioner? Note what cn90 said: Both are mechanical; one is a spring in oil, the other doesn't have oil ... but noise is usually from the bearings, which, presumably, both have. Last edited by bluebee; 02-25-2011 at 06:11 PM. |
#61
The Gates technical bulletin posted by cn90 states that hydraulic tensioners are "mainly used on applications with high loads and/or angular vibrations, where a mechanical automatic tensioner can not provide sufficient damping or tensioner movement." It may be that the mechanical tensioner, while less expensive for BMW to install at the factory, wears its pulley bearings out faster and becomes noisy because it's less capable of handling the loads of the belt drive system compared to the hydraulic tensioner.
![]() E36 DIYs: Air Pump | Vent Gauge | E46 Armrest | SmarTire TPMS E46 DIYs: Hella TPMS | Aftermarket Horns | Window Regulator Notes | Trunk Wire Harness | Trunk 12V Socket Last edited by G. P. Burdell; 02-25-2011 at 05:25 PM. |
#62
I copied your response over to this specific thread I opened on the topic: - WHY would a hydraulic belt tensioner be any quieter than a mechanical belt tensioner? Where the three related questions are asked:
#63
While BMW won't sell you "just" the pulley for the mechanical tensioners, apparently the pulley "can" be bought separately.
At least it says so in this E46 reference: - a/c belt tensioner pulley And, in this E39 reference: - Squeak Last edited by bluebee; 02-26-2011 at 12:19 PM. |
#64
For the record, another user today reported you can replace "just" the pulley on the mechanical tensioners:
- Belts / Tensioner s/ Idler Pulley Replacement Quote:
#65
I have 2001 and 2003 and both have mechanical tensioner I believe all M54 has mechanical tensioners both have been replaced to the same mechanical on 80k miles 0 issue, will last another 80k Last edited by champaign777; 02-28-2011 at 07:21 PM. |
#66
Together, we're a team (alone we're nothing) ...
For the record, many people (including me at first) are confused whether to twist on the mechanical tensioner pulley centerbolt or to leverage on the raised knob (or sunken Torx in the 2003 E39) on the side of the tensioner. To make matters worse, folks with the hydraulic pulleys often unintentionally mislead we mechanical tensioner people by talking about the pulley Torx centerbolt (which, unless you're replacing 'just' the pulley, which most of us do not do, then it buys you nothing to loosen the pulley centerbolt on the mechanical tensioner). Anyway, the topic came up, again today, over here: - Serpentine Belt Replacement To which WagonTheDog posted a wonderfully succinct picture that I reproduce here for all to benefit: |
#67
Thanks for for the cross-reference, BB.
#68
Thanks for noticing.
For every thread I ask a question on, I go to great pains to ensure there is a complete & comprehensive answer, which just gets better and better (over time), always aiming toward the goal (but never reaching) of having every single possible question answered. That takes a LOT of cross links because you want one place to find the answer, even if the answer is scattered all over the place. The worst thing, to me, is when someone asks a common question, and the respondents are so jaded that the OP gets no response, or jokes, or half answers. Even worse, as it seems to have happened even in this thread, well-meaning people give WRONG answers. In the end, everyone who asks this question finds out the right answer (if by no other reason than by trial and (expensive) error) ... so it's just wrong for them, once they find the answer, to not edify the rest of the team. By way of example of how the process 'can' work when it's well honed, today someone asked the simple question: - Belt tensioner hydraulic or mechanic ? We pointed them here! And, that makes me feel good that the OP in that case has a ready-made answer, a one-stop-shopping combination of all our collective tribal experiences. The OP's job, now, is to improve our collective knowledge ... any way he can (as we're always improving our tribal answers). |
#69
Today, fiat84 reported anecdotal experience with changing 'just' the mechanical tensioner pulley in:
#70
Today, someone struggled with the wrong bolt attempting to remove a hydraulic tensioner:
- Need help changing my belt - problem with hydraulic tensioner Luckily, folks set him straight with nicely edited pictures, which I reproduce below for the edification of those who need to know. |
#71
For the record, here is a nice picture of the adjustment arc of the V8 hydraulic tensioner today:
- E39 (1997 - 2003) > AC tensioner installation NOTE: The I6 hydraulic tensioners do not have this adjustment arc. Quote:
In addition, cn90 referenced a nice DIY: - BMW 740il Serpentine Belt Quote:
- How to tell if you have mechanical or hydraulic belt tensioners (1) & how to switch from mechanical to hydraulic (1) and what is the difference between the two types (1) (2) & how to rebuild your hydraulic tensioners (1) Last edited by bluebee; 08-22-2011 at 10:59 PM. |
#72
For the record, yet another person (this time on an E46 M54 engine) posted an idler roller that simply fell off the centerbolt, unbeknownst to the owner:
- E46 (1999 - 2006) > Alternator replacement with deflection pulley surprise. Other related threads show why the idler roller is replaced along with the belts & tensioners: E46 (1999 - 2006) > Another Possibility of a P00128 - E39 (1997 - 2003) > Mechanical Fan Exploded! Is another one Last edited by bluebee; 09-14-2011 at 11:15 PM. |
#73
For the record, a side discussion of which tensioners are adjustable went on today over here ...
- E39 (1997 - 2003) > Battery light on.. Quote:
#74
For the record, yet another 540i owner was confused today about the 'ability' to adjust belt tension on the hydraulic tensioners with the arc:
- E39 (1997 - 2003) > Alternator Swap, Loose Belt, Help! Quote:
- How to tell if you have mechanical or hydraulic belt tensioners (1) & how to switch from mechanical to hydraulic (1) and what is the difference between the two types (1) (2) & how to rebuild your hydraulic tensioners (1) & the answer to the question of adjusting the 540i hydraulic tensioners' belt tension (1) (2) |
#75
For the cross-linked record, the question of how to tell, hydraulic vs mechanical, came up again today:
> E39 (1997 - 2003) > Cooling system! be safe than sorry? Luckily, I think 'this' thread has all that anyone would need to answer that question!
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! |
