Old 03-06-2011, 06:14 PM
Mpire's Avatar
Mpire Mpire is offline
The Anti-Rice
Send a message via AIM to Mpire Send a message via MSN to Mpire Send a message via Yahoo to Mpire
Mein Auto: S54 M Coupe x2, M52 Z3
Help? Plastic fell into engine?
Ok, so I am doing the valve cover gasket on the Z3 and it looks like a piece of the valve cover has fallen into the engine.
Its a piece about 1 inch long by 1/4 inch wide by 1/16 thick.
I can't find it anywhere, and I have been looking with dental instruments.
I also tried to blow it out with air hoping it would show up, no luck there either.
So now I am worried that I have a plastic bit bouncing around inside the engine.
What do you think? How much trouble is this going to be?
Here is a pic of where the missing piece came from.
2001 Alpine / Schwartz Coupe
2001 Estoril / Estoril Coupe
2001 Steel Grey / Estoril Coupe
1999 Estoril / Estoril Coupe
Sunroofs are for girls.
Old 03-06-2011, 06:51 PM
Miller 1000 Miller 1000 is offline
Mein Auto: 2001 z3 2,5
Are you sure you knocked it off? That valve cover has probably been off before. maybe more than once. Perhaps some one knocked that piece of plastic off on a previous go around. By the by. Thanks again for the heater fix. I really appreciate it. Miller 1000
Old 03-06-2011, 07:33 PM
Mpire's Avatar
The Anti-Rice
I have no idea. Randy said not to worry about it, so I am not.
Old 03-06-2011, 08:06 PM
Mpire's Avatar
The Anti-Rice
Any time. I love the small projects.
Its harder to screw those up!
Old 03-08-2011, 08:52 AM
Swanicyouth's Avatar
Swanicyouth Swanicyouth is offline
Mein Auto: M Roadster
Same thing happened to me during valve cover replacement on my old Z. ** Frantic *** I drove it another 30k with no problems.
Old 03-08-2011, 09:50 AM
Mpire's Avatar
The Anti-Rice
Yeah, I was a little upset, but the consensus is that if it gets into the gears, they will just chew it up. If not, then it will fall down into the pan to live the rest of its life.
Worst case would be if it got completely ground up and clogged the oil intake screen, but I am not too worried about that. Its a relatively small piece of plastic, and I have an oil pressure gauge that I will be watching.
I will be changing the oil a little early though just in case.
I change it ever 3k miles with Mobil 1 0w40 as it is, so I should be OK.
