| View Poll Results: How many miles on your transmission before repairs or replacement needed? | |||
| 50,000 to 100,000...transmission repaired/replaced. |
124 | 7.79% |
| 50,000 to 100,000...no problems!!! |
582 | 36.56% |
| 100,001 to 125,000...transmission repaired/replaced. |
93 | 5.84% |
| 100,001 to 125,000...no problems!!! |
285 | 17.90% |
| 125,001 to 150,000...transmission repaired/replaced. |
60 | 3.77% |
| 125,001 to 150,000...no problems!!! |
188 | 11.81% |
| 150,001 to 175,000 or more...tranny repaired/replaced. |
40 | 2.51% |
| 150,001 to 175,000 or more...no problems!!! |
220 | 13.82% |
| Voters: 1592. You may not vote on this poll | |||
#251
simplify33
Well, my reverse in my 2000 323i just quit and my dealer wants $5500. for repair/replace. I bought my car almost new, 20k miles, and I have taken my car in promptly to them for all scheduled maintenance and repairs. I don't have $5500 right now nor do I have wheels to make it to work.... What's a girl to do?
#252
If I am right, your transmission is GM (correct me if I am wrong). If so, it might be relatively cheap fix, since on GM transmission the cause of the reverse lost is a solenoid and not the drum (like on ZF).
I'd recommend to find a knowledgeable BMW indy mechanic (I know, it is hard....) and get his second opinion. Anyway, even if trans has to be replaced it will be MUCH cheaper to do in indy shop. Another option is to sell your car as-is for cheap and buy a new one. |
#253
'02 330i | OE Tuning Tune | H&R/Bilstein | 3.38 Cooling System Guide Dayco 89133 Mechanical Tensioner Pulley |
#254
Mine is lifetime and doesn't have a ready way to get to it.
Dealer said not causing any problem, at 173,000 miles leave it alone. 97 BMW 540I |
#255
I voted for 100,001 to 125,000...no problems!!! Recently had filter and fluid change at 106,000. Plan to do the next service at 50,000 miles. In the mean time just keep driving.
#256
So try to find a cheaper chop or tranny only shop in town and tell them your issue and you researched and it is common, and mahybe someone might say ohh yea I seen this before etc etc. You can even google/research online and bring print outs of the issue. Found sme links I saved when doing the research online a while back for my sister. This first link I just remember is another common issue with no reverse, So there is 2 total parts that fail for the no reverse, now maybe someone can chime in here because I forgot which failed part, but one way to tell which part for sure it is that failed on the tranny and I think it depends on the model tranny thats in the car too is one of the failed parts will alow sometimes it to engage in reverse sometimes. So if it will never ever go into/engage in reverse then its one of the failed part that will never alow it to do so. http://blog.bavauto.com/bmw-e46/bmw-...325z-zf-5hp-19 Heres actually a DIY- How to fix your no reverse issue on a ZF5HP19 http://forum.e46fanatics.com/showthr...verse+drum+diy Last edited by pctek; 03-18-2011 at 08:34 PM. |
#257
hi,
read your reply on the transmission. What were the symptoms? I may be having some beginnings of a problem. My DSC light comes on strangely and I don't have any power or acceleration for about 2 seconds and then the transmission kicks back in again. Do you still have your car? |
#258
what were your symptoms?
what were your symptoms when this started happening? I'm getting my DSC light pop on sporatically for 1 or 2 seconds. Then I have no power or acceleration, then everything goes back to normal..... |
#259
Well, now at 90K miles the car is at the gearbox revision specialist... The dreaded error 0741 was there to stay, and now accompanied by the torque convertor slipping code. I could actually feel it slipping; for example driving at about 2000RPM, slightly thottle up 200-300 RPM, and nothing happens... I needed to push the throttle further every week before the box started to relay the torque.... The box (5-sp AUT) will be repaired or exchanged for an overhauled one. Good thing: still under warranty, so it won't cost me anything.
E46 330Cic Executive 07/2003 Silver Gray Metallic Last edited by von jot; 04-06-2011 at 02:12 PM. |
#260
I had 70,000 and was working as brand new
BMW CCA Member, Capital Chapter |
#262
Was?
#263
The original owner had it BMW NA come to the dealer to repair it with 70K on it. It has just under 50K since then. I think a fluid change will be in my future this summer.
She's back with a brand new torque converter and gearbox ECU, oil and filter. Shifting smooth as butter, and a normal, even a bit agressive throttle reaction. And yes, all fixed under warranty!
E46 330Cic Executive 07/2003 Silver Gray Metallic |
#265
2002 325i everything running good at 128k miles
iM MLG FkN PrO
#266
Hey,
Had to replace transmission within 5 months of buying my 2004 318i (second hand). It had 84000km and had been regularly serviced. Ended up buying reconditioned part as new installed would have cost me $8k AUD!! Instead it was $3k AUD with a 1 yr warranty. |
#267
ouch!
Current Ride: 2013 328i Sport Line - Mineral Grey Previous Ride: 2004 325i Black |
#268
161K on my 2002 325i sedan with no problems, changed tranny fluid and filter once at 60K.
#269
2000 323i. Bought it brand new and the tranny went out at around 70,000. Put a rebuilt one in with 2 year/24,000 mile warranty and darned if it didn't go bad 35,000 miles later.
#270
Tyler,
We have 175,000 miles on our 97 540I and our transmission has not been touched. There is no way to change the fluid in it anyway is what the dealer and our mechanic locally told us. BMW dealership here in Birmingham say to leave it alone so we have. Its an automatic and does fine. All we have done recently is change out one sensor in front of the muffler on the passengers side. |
#271
1998 E46 323i with 171,000km:thumbsup:
#272
Mine went out around 118k miles but for how much I drive and how much I use the steptronic I think it def lasted a long time!
![]() Current Car: 2008 BMW 328i Sport package and Premium package Previous Car: 2003 BMW 325i Premium Package |
#273
1999 232i bought it second hand with 67k miles on it, and now with almost 120k miles the tranny seems well
#274
Been two years since I posted in this thread. My car is now on 150k miles and still no issues with my auto tranny. And I average 350 to 400 miles a gas tank. I love this car, only if it was 5 speed though.
#275
What did you do for maintenance during that time? Sorry if you posted it already, I have not looked though the entire thread.
