525i BIG problems!
My son ran my 2003 525i without coolant. He then ran the car into the curb.
A "friend of a friend of a friend" who works part time as a mechanic for the local BMW dealership looked at the car. His opinions: - Blown cylinder head gasket - - Possible warped cylinder head - - Ruptured radiator overflow tank - - Bent lower control arm - - (Also, broken rear tail light assembly) - He estimated the cost of private repair to be at least $3500 ... possibly much more. He then offered to buy my car for $500. Does this sound on target to you? Would REALLY appreciate any thoughts / suggestions. Thanks!! |
Happens all the time. Not good.
Let me dig up some details for you. Keep us informed, if we're going to do this work to help you, it's a courtesy to us to let us know what you end up doing so we can then help the next person with the same problem. Last edited by bluebee; 03-10-2011 at 10:03 PM. |
Here are the details I dug up for you ...
Overheating a BMW E39 engine is the most common cause of blown head gaskets, cracked heads, warped blocks, cam seizures, contaminated main bearings, coolant-caused hydrolock, & piston, ring, & valve damage in the BMW E39, particularly those with the aluminum block (1) (2) (3) (4). If you think you might have a blown head gasket, you don't have many options (the solution would have been to not to let it happen in the first place), especially since, by some reports, only 1 out of 20 aluminum engines are rebuildable after exhibiting symptoms of a 'blown head gasket' (which may be a misnomer of sorts given that the problem is usually a warped block and/or a cracked cylinder head, in which case, it's time to replace the engine (1) (2)). But, if it is 'just' a head gasket you need, these are your options:
You need to run some basic tests:
- BMW phantom diagrams (1) & nominal prices by part number (1) labor rates by zip code (1) (2) (3) where to find a good mechanic (1) (2) & finding a specialty BMW indy in your area (1) Bear in mind, the entire BMW cooling system is a time bomb to overhaul the cooling system in any case. - Complete cooling system overhaul recommended parts list (1) Don't believe me. Believe these pictures: - Pictorial look at typical E39 cooling system failure modes (1) When this time bomb goes off, if you don't immediately STOP driving the vehicle, the engine can easily become toast. Again, don't believe me. Believe these people from these representative threads: - 525i BIG problems! - Major Decision - replace head or buy "new" engine - E39 528i Engine removal/replacement - Overheating and water loss - Replace head gasket or replace engine - E39 528i Engine removal/replacement - E39 540i low compression - Possible blown head gastket, but no mix of oil/water yet - Blown 528i update.....New motor advice & subsequent Engine swap advice....528i - Advice on getting new cylinder head assembly. - 2001 528i engine - Engine is apart - Anyone have info/advice for DIY head gasket repair on 2003 525i E39? - Breaking BMW E39 528i - 1989 535i help please - Head gasket done but still overheating ahhhh - bad bleeding or blown head gasket - Overheating and water loss - SH!* blown head gasket!! question.. - Very confused about this over heating thing - Add me to the "overheat" club - 2.8 L e39 528i engine for sale - Choc milk coolant etc. For a head gasket DIY, you might try these: - BMW Head Gasket Replacement, Pelican Technical Article, by Wayne R. Dempsey - Journal: M54 Head Gasket Replacement & Other Stuff Too - M62TU Head gasket/ Timing guides journal - DIY This! One Person M54 Cam Removal - Replacing the M54 head gasket (1) - Replacing the 540i cylinder head (1) - (Note: I need more and better DIY links.) The basic cylinder head gasket DIY procedure is outlined below:
- Summary advice to provide users who suspect a major engine repair due to overheating (1) & how to test an engine for blown head gasket, cracked heads, a warped block, cam seizures, contaminated bearings, coolant hydrolock, or piston, ring, or valve damage (1) (2) & a well researched reusable response to a particular user with a blown engine (1) & what questions to ask when severe heating-related damage is initially suspected (1) & what E39 engine swaps are most recommended (1) (2) (3) & how to lift & remove the engine (1) & where to obtain a new or rebuilt replacement short block or long block (1) (2) & why the E39 engines are so prone to heat-related damage in the first place (1) & real-world results from people faced with similar blown engine problems from which this advice came from (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) (13) (14) (15) (16) (17) (18) (19) (20) (21) (22) (23) (24) (25). Good luck. Keep us informed. Last edited by bluebee; 04-15-2011 at 12:12 AM. |
A "walkby diagnosis" will not suffice....you need a competent shop to perform a compression/leakdown test for further analysis.
(R.I.P. Jever) *Please support the Wounded Warrior Project* |
Wow. Just wow....
![]() Mods: Shark Injected | Magnaflow Exhaust + Resonator | H&R Springs | Bilstein SP Shocks + Struts | TMS Power Pulleys Eibach F+R Sways | BeastPower Brackets | M-Tech bumpers | Predator ICE V3 + HID Fogs | Eurodyne CF Hood | BSW Sub + Dice + spec dock [---Quote (Originally by Tex330i)--- You can warranty a turd, that way when you have a problem you can exchange it for a new turd.---End Quote--- |
How did he manage to drive the car with no coolant in it? i.e. was there a leak and it ALL leaked out and THEN he decided to drive it, ignoring the warning lights on the dash?
No offense but your kid sounds like he's in line for a beat down. You don't state your mileage but even if the head is blown the car is worth more than $500. Hell you could sell the seats for $200! and +1 to getting is checked by a solid independent BMW mechanic.
2001 530 Steel Blue Metallic, purchased Dec 03 SP/PP/CWP/Slushbox (I know I know) OEM M5 bumper, 40% Huper Optik ceramic tint, Dice Silverline Pro iPod adapter, 540SP radial spokes, Zimmerman Z-Coat rotors w/ Hawk HPS pads "Mods": driveshaft, cooling system, Vanos, CCV, PSR, VCG, FSU, spark plugs, buncha belts-n-hoses, & other things I'd just as soon forget BMW CCA member for 12 years |
LMAO! I was thinking the same...
I would not trust that mechanic. He is already trying to rob you by offering $500.00 for a 2003 BMW. Its worth alot more than that with no motor at all.
Hell, I'll give you $750 for the car.
Sent from my iPhone using BimmerApp |
800$
i want to see SOLD in the end of this thread Last edited by champaign777; 02-21-2011 at 01:40 PM. |
It's not nice to leave us hanging like this ...
What did the OP end up doing? And, by the way, what brought me back here is I was looking for advice for others posting today about swapping engines: - E39 528i Engine removal/replacement See reference link: - Engine swap advice....528i |
Update from the OP?
850$ seriously. But also seriously You should take it to another mechanic, yours I think is trying to get a good deal. If you do decide to sell, maybe eBay?
sold
00 BMW 528ia Sport M5 F+R Bumpers, M5 Mirrors with OEM setup, M5 rear sway bar, Cluster Rings, 03 Business player with AUX input, HID fogs slim, OEM 01+ Hella headlights, EAC Aluminum Adjusters, FX-R low beam retrofit, Umnitza VXX 10w LED Halos, Hella Euro Celis Retrofit Kit, Koni yellow shocks adjustable, 19" M6 Reps, Full LEDs. ![]() |
you should have it take to another Mechanic where you can get the diagnostic correctly. The car can be sold more then the price that was offered. You can replace the used engine and it should only cost less then two thousand. Goodluck.
Today, we received an almost exact duplicate of this thread:
- 2001 528i engine Where the OP stated: Quote:
To the OP: What was your outcome and what advice can we provide that would have helped? |
I guess the OP died (along with his engine).
Anyway, this problem (overheating killing the engine) keeps coming up. For example, see this thread today for advice: - E39 (1997 - 2003) > Engine head Quote:
- Summary advice to provide users who suspect a major engine repair due to overheating (1) & how to test an engine for blown head gasket, cracked heads, a warped block, cam seizures, contaminated bearings, coolant hydrolock, or piston, ring, or valve damage (1) (2) & a well researched reusable response to a particular user with a blown engine (1) & what questions to ask when severe heating-related damage is initially suspected (1) & welding the crack between cylinder #3 and the water jacket on the exhaust side (1) & what E39 engine swaps are most recommended (1) (2) (3) & how to lift & remove the engine (1) & where to obtain a new or rebuilt replacement short block or long block (1) (2) & why the E39 engines are so prone to heat-related damage in the first place (1) & real-world results from people faced with similar blown engine problems from which this advice came from (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) (13) (14) (15) (16) (17) (18) (19) (20) (21) (22) (23) (24) (25) (26) (27) (28). Last edited by bluebee; 07-16-2011 at 07:30 AM. |
For the record, this thread has a lot of good advice on how to handle an overheated engine repair:
- E46 (1999 - 2006) > Lost Cause? I need blunt honesty here... Here is the summary of the current advice: - Summary advice to provide users who suspect a major engine repair due to overheating (1) (2) (3) (4) & how to test an engine for a blown head gasket, cracked heads, a warped block, stripped head bolt threads, cam seizures, contaminated bearings, coolant hydrolock, or piston, ring, or valve damage (1) (2) & what are the major factors in deciding whether to rebuild the engine, replace the engine, or sell the car (1) & a DIY for replacing the I6 M54 head gasket (1) (2) & replacing the V8 M62TU head gasket (1) & why these engines are so prone to heat-related damage in the first place (1) & welding the crack between cylinder #3 and the water jacket on the exhaust side (1) & what engine swaps are most recommended (1) (2) (3) & where to obtain a new or rebuilt head (1) replacement short block or long block (1) (2) & how to lift & remove the engine (1) & real-world results from people faced with similar blown engine problems from which this advice came from (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) (13) (14) (15) (16) (17) (18) (19) (20) (21) (22) (23) (24) (25) (26) (27) (28) (29) (30) (31) (32) (33) (34) (35) (36) (37) (38) (39) (40) (41). Last edited by bluebee; 11-25-2011 at 11:39 AM. |
Actually Champaign is right on the money.
The kid not only super overheated the car, he damaged the front axle so bad, the control arm is bent. So you have 2 major issues: 1.) The engine - repairable, but it will be expensive 2.) Drive train issue - once you bent the suspension components, no matter how you try to fix it, the car will be NEVER the same (unlike a rebuild engine), it will not drive the same. I can go as far and predict an almost uncurable shimmy, which you will correct, only to have it come back after a while. I would have NEVER entrusted the youngster with this car. A 10-15 year old Kia or Hyundai would have sufficed until he learns how to drive and how to take care of a car. Another e39 down.
Looking for a DIY? Parts? Check this out, it might be your ticket TMS underdrive pullies - Stewart WP - PSS9 - Beisan Vanos seals - Zimmerman cross-drilled & Akebono Euro - Deka 649 MF - 55w HID headlights - 35w HID foglights - Hualigan double din - ACS (rep) alu pedals - Euro central storage console - Breyton Magic Racing staggered wheels - M5 bumper - M5 steering wheel - Tint Stable: e39 M54, e53 N62 & Tribby |
