Old 03-15-2011, 05:05 PM
kevinl34 kevinl34 is offline
Mein Auto: 325is
Exclamation steering wheel locked HELP!
I have been having a problem with my steering wheel locking this week but today it locked up completely I can oly turn the key but it will not stay in the first position I guess because of the way the wheel position was left in. I heard there is some type of pin that locks it in place I have a 1997 528i and I dont know if its metal or plastic. I was wondering if theres a diy around somewere with pictures for Im not the best mechanic thanks for any help.
Old 03-15-2011, 05:07 PM
Calicoastin Calicoastin is offline
Mein Auto: 2003 E39 540i auto
Have you tried turning the steering wheel slightly left or right and then turning the key?
Old 03-15-2011, 07:25 PM
Mein Auto: 325is
yea its locked it wont even stay in the first position I cant even get the car out of gear good thing it happened at home
Old 03-15-2011, 07:44 PM
jarhed1964 jarhed1964 is offline
Mein Auto: '99 528i Sport, '05 530i
Grab your drill! Had the same thing happen last year when I replaced my key cyl.
I'll see if I can find the pics, but you can drill out that little locking mechanism under the column. A little ball and spring will fall out and you'll never have the wheel locking again. Took me 5 minutes for a permanent fix.
Old 03-15-2011, 08:01 PM
Mein Auto: 325is
I want the permanet fix this is driving me nuts I just need to see what needs to be drilled out if I can get the diy for that ill be good
Old 03-15-2011, 08:20 PM
Ok, I couldn't find the picture on here but I'll take a picture of where I drilled the hole as soon as I can get home and get a flashlight on it.
Old 03-15-2011, 09:01 PM
Mein Auto: 325is
ok thanks
Old 03-16-2011, 12:43 AM
Ok,
Grab your drill, pull the bottom cover from your steering column, and drill in the middle of the little aluminum rectangle that you'll see in the following thread. The spring will fall out or you can pull it with a needle nose pliar. This took me all but 6 minutes to complete, then another two minutes to put the cover back on. No more wheel locking FOREVER.
http://forums.bimmerforums.com/forum...=284817&page=4
Old 03-16-2011, 07:54 AM
cn90 cn90 is offline
You need a new lock cylinder (BMW only).
Old 03-16-2011, 12:03 PM
Mein Auto: 325is
thanks a million............what size bit did you use?
Old 03-16-2011, 04:08 PM
I cant remember exactly. Try to match up a bit (if you have a set) with the pic. It's not a very big spring, but a bigger bit will cover more area and prevent re-drills being needed.
BTW, I put some putty up into the hole to close it off. I think some folks use heavy tape to cover it though. I don't think you really need to cover it, but I didn't want dust getting up there over the years.
Old 03-16-2011, 04:59 PM
This thread seems to have an ingenious enough solution that we should make it easier for others to find it in the future when they have locked steering wheel problems.
Doing a quick slash-F3 "steering wheel" in the bestlinks, I found many "steering wheel" related links.
Putting tehm together, along with this thread, into a keyword-rich somewhat organized sentence, I newly come up with (for future users) something like:
- What to do when both your automatic steering wheel tilt and manual & automatic driver seat control fails (1) (2) (3) (4) (5) (6) (7) (8) & related automatic steering wheel tilt details (1) (2) (3) or if your steering wheel & key cylinder locks in place (1) & signs of a failing ignition switch (1) & the BMW TIS for when the ignition switch spins but does not engage (1) & rebuilding a failed ignition switch (0) (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) & how to test your BMW E39 DSC steering wheel sensors (0) (1) (2) (3) (4) (5) & how to retrofit to a 3-spoke M-Sport steering wheel (1) (2) (3) (4) & heated steering wheel retrofits (1) & updating the life of an old steering wheel (1) & where to buy the BMW steering wheel roundel (1) (2) (3) (4) (5).
Of course, as always, if you know of BETTER links, please let us know as the goal is to have an easy cross reference to all possible questions, over time.
Old 03-18-2011, 07:46 AM
Mein Auto: 325is
great job!
Old 03-18-2011, 08:29 AM
great job!
Did it work?
Old 03-21-2011, 01:55 PM
Mein Auto: 325is
is this a picture of an e36 or an e39?
Old 03-21-2011, 11:01 PM
Not sure. But it does look pretty much the same. That aluminum rectangle housing is there on the E39. That is where you want to drill through.
Old 03-22-2011, 12:30 PM
Mein Auto: 325is
ok after going thur the searches I believe the problem is mechanical safety lock Is this the spring that pushes them up and down? I cant find tha box on my e39 but Im pretty sure that a e36 on the pictures above because i had a 325is and the underneath looks just like that I can tell were the undeth comes out the e39 is connected to the woodgrain and doesnt seem to come out easy didnt want to break it.
Old 03-23-2011, 08:22 AM
Did you remove the lower cover from the steering column? It's under there, trust me. What year is your E39?
Old 03-23-2011, 08:37 PM
Mein Auto: 325is
yea I remove the covers were the steering wheel is ( the top/bottom covers that covers the steering wheel. Also removed the lower covering down on the floor board by the break pedal....do you have a pic of an e39?
Mein Auto: 325is
unless u want to drive to greenvile sc to show me lol...I just saw you were from charlotte
Old 03-24-2011, 05:30 AM
Jimmys 530i Jimmys 530i is offline
Mein Auto: 2003 530i
I had a similar problem on my former E36, and I just went ahead and put a used column on. It is fairly simple but very time consuming.
2004 BMW 330ci Silvergray Sport Package, Cold Package, Xenon Headlamps, Premium Package, 6 Speed Manual, Build Date 9/03
Sold - 2003 325i Sedan Japanrot 5 Speed 8k Xenon Headlamps Build Date 11/02
Old 03-24-2011, 09:35 AM
moots's Avatar
moots moots is offline
wat's dat noise
Mein Auto: '04 525i
the fact that the key won't even stay in the 1st position and the gear is also jammed is telling me that the mechanical interlock between the key assembly and the gear lever is stuck.try this :
remove the leather gear gaiter and then pull up the cover surround
pull up this lever all the way and hold.now try see if you can move your ignition key.
if you can,exercise this lock lever up and down till it moves freely.this is the lever that acts as the interlock that prevents the gear lever from being moved if the key is not in and turned to at least position 1.the elect solenoid prevents gear selection from P or N if the foot brake in not pressed
good luck
Old 03-24-2011, 02:18 PM
Mein Auto: 325is
tried that trick above it did let me move my gear shift however, it didnt fix the problem I think it internal thanks for the trick thought....
Old 03-28-2011, 07:52 PM
Mein Auto: 325is
JARHED YOU ARE THE MAN!!!!!!! It worked althought we had to pull the cyl lock off but once that happen saw what was wrong and got the drill spring is out no more locking thanks.....
Old 03-29-2011, 12:31 AM
Wish I could take credit for it, but I found it on this or another forum. Glad you got it squared away though!
