Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series
6 Series
The BMW 6 Series builds on BMW's sporty heritage with aggressive lines and an incredible motor to back the design up. Available in coupe and convertible trims with a standard 4.8 liter engine producing 360 horsepower and 360 lb-ft of torque, the 6-series is a popular choice that exceeds expectations.
Old 03-17-2011, 05:13 AM
mpc1971 mpc1971 is offline
Mein Auto: 645i vert
cheer yorgi,
that saved me some time. back to the paint option then .
txtaz. your trim .... did you wrap it in cf ? if so do you have any pics please
thanks
Old 03-17-2011, 06:47 AM
TxTaz's Avatar
TxTaz TxTaz is offline
It's hot in Texas
Mein Auto: 2005 645CI Convertible
thanks
My trim? My interior trim is Di-Noc and the engine cowl and valve covers are painted with engine enamel.
Pics:
Taz... My favorite BMW so far.
Sport, Cold weather, Logic 7
19" Miro M6 Wheels w/competition stems
MGP Claiper Covers (BMW)
Dension Gateway 500 and Audio Video Router
AC Schnitzer pedals
Carbon Fiber Di-Noc Trim
5W White Angel Eyes
Polk tweeters
Old 03-17-2011, 02:54 PM
Laslonimne's Avatar
Laslonimne Laslonimne is offline
Send a message via ICQ to Laslonimne
Mein Auto: 650i Cabriolet
Originally Posted by Yorgi View Post
I went for a spin with the top down today (woot) and read temps at a few spots under the hood.
Engine cover: 208°F
Engine block: 254°F
Air filter cover: 108°F
Valve covers: 215°F
Hood insulation: 102°F
Water pump: 150°F
Interesting. I just pulled in from a 300 mile road trip and measured the following with my Raytek MT6:
Ambient: 84°F
Oil Temperature: 210 (indicated)
(Black) Hood: 101°F
Left Side Engine Cover: 141°F
Right Side Engine Cover: 131°F
Left Valve Cover: 171°F
Right Valve Cover: 155°F
Engine Block: 208°F
Water Pump: 198°F
Air Filter Cover: 120°F
Odd that we should be so different. I was also surprised at my side-to-side variance. Did you measure both sides and get the same temp for each?
Old 03-17-2011, 03:07 PM
cheers taz,
interior looks very classy. that will be my next mod. not too sure about leaving the grey piece around the stick. i think thats the worse part of my interior. hate all the grey plastic. but then i dont want to overkill on the cf ???? decisions decisions. think i will play around and see
thanks for the pics
very nice engine cover
Old 03-17-2011, 03:42 PM
Yorgi's Avatar
Yorgi Yorgi is offline
Wow that is crazy. I'll try again today and use my very accurate tire pyrometer as a backup to the el-cheapo infrared gun.
I did a 30min drive in stop-and-go local traffic so maybe things run a bit hotter in stop-and-go vs highway? My ambient was only 45°F
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 03-17-2011, 04:35 PM
Laslonimne's Avatar
... I did a 30min drive in stop-and-go local traffic so maybe things run a bit hotter in stop-and-go vs highway? My ambient was only 45°F
I can buy stop-and-go running hotter than highway - even with the difference in ambient - since there's less airflow over the engine.
I still wonder about the side-to-side variance.
Please post your oil temp also, often a 30 minute local drive won't get my engine/oil up to temp.
Old 03-17-2011, 05:24 PM
TxTaz's Avatar
It's hot in Texas
not too sure about leaving the grey piece around the stick. i think thats the worse part of my interior. hate all the grey plastic. but then i dont want to overkill on the cf ???? decisions decisions. think i will play around and see.
I wasn't sure either so I covered it first since I had scratches. I thought it was too much cf so I bought a new trim piece.
AC Schnitzer pedals
5W White Angel Eyes
Polk tweeters
Old 03-17-2011, 08:04 PM
Yorgi's Avatar
OK, re-did the test using my $$ tire pyrometer along with the $30 infrared gun. There were big differences so I boiled a pot of water and found out (thankfully) my pyrometer is 100% accurate and the infrared reads about 30°F too high @200°F but almost dead on @100°F. Time for a better infrared.
New readings - left = left side when facing car (passenger side on American cars):
Ambient: 57°F
Engine oil: 230°F (1 tick below midpoint, the warmest my car gets)
Engine cover left: 144°F
Engine cover mid: 109°F
Engine cover right: 118°F
Valve cover left: 184°F
Valve cover right: 182°F
Engine block: 226°F
Air filter cover: 98°F
Hood insulation (under the hood): 101°F
Water pump: 194°F
'04 M3 - track
Old 03-18-2011, 05:52 AM
Laslonimne's Avatar
OK, re-did the test
Thanks, I feel better about my readings now.
Old 04-23-2011, 06:23 PM
Superhart1977's Avatar
Superhart1977 Superhart1977 is offline
Send a message via AIM to Superhart1977
Mein Auto: BMW 645CI
Did my Engine compartment today
cleaned and detailed, painted and shined the silver crossover pipe with mag wheel cleaner.
ID:	275877   Click image for larger version
ID:	275878   Click image for larger version
2005 BMW 645ci
Stratus Grey Metallic/Black int.
20" M6 replicas
2006 BMW 325ci Black
18" RPM rims
50% tints, Black grill, tinted tail lights
Eclipse double din Nav
Retired BMW's
2003 Z4 3.0
2000 323i
1995 318i
1990 318is
Old 04-24-2011, 12:27 PM
6serial6's 6serial6's is offline
Mein Auto: 645
Ooohh I want to paint mine too. Thinking red. Is engine enamel the best way to go? If so, what brand and where can I get one?
