7 Series - E65 / E66 (2002 - 2008)
Discussion pertaining to the flagship BMW here. |
!!!! Brake Fluid flush DIY - How many liters?
Doing a brake fluid flush right now, deciding whether or not I should go back to the store to get an extra liter. I've usually only used 1liter in the past for my other cars, but the e65 is a much larger vehicle.
How many liters will I need for a proper flush? |
I know the 7th has different brakes but I used only 750ml, tops, to flush my brakes, with ASC. same with a DSC equipped 540.
'99 528i ('98/12 build). 174,000km BY29428/Royalrot Breaking My Wallet since 2009 Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals '99 540i (grandfather's)
hrmmmm... Anyone with an e65 know from experience?
1 liter - or if you want to over bleed then 2 liters. but you will end up with only 1 liter in the car.
I just did this last fall and I used 1 liter. I even had a little left over and flushed a lot just to make sure there were no air bubbles in there. Good luck.
Yep, I used exactly 1 liter, flushed it quite a bit also. All of the lines had brand new fluid coming out with no bubbles
