Old 03-21-2011, 01:55 PM
Bimmervillain Bimmervillain is offline
Mein Auto: Z4
Question Z4 03' 2.5 Warning light after changing wheels.
I recently changed the wheels on my Z4, I switched from the stock 17" to an 18" wheel and tire. The first time I drove it afterwards, a Red exclamation point warning light popped up. I have seen from other posts that this is either a tire pressure warning or DSC. I changed the wheels myself, used a torque wrench to the correct 88lbs. I checked the tire pressure and corrected it to factory specs. Is this some sort of error due to changing wheel size or just a coincidence? Any thoughts or comments by someone who has experienced this would be greatly appreciated.
FYI: 03' Z4 2.5 23k miles, and new tire size is 225/40R18
Old 03-21-2011, 02:49 PM
tequila mike tequila mike is offline
Mein Auto: 1999 MZ3
dsc
I put tires of slightly different sizes on my car and the dsc in my case asc would come on.
2 new and 2 used tires did it to me.
i had to replace the 2 used tires to get it to go off.
Old 03-21-2011, 03:17 PM
Mein Auto: Z4
All four tires are the same size and condition. It seems to be driving the same, if not a little better.
Old 03-21-2011, 07:46 PM
Swanicyouth's Avatar
Swanicyouth Swanicyouth is offline
Mein Auto: M Roadster
Something may not be the right size. Double check each tire has the correct size printed on the sidewall. If someone someplace pulled those tires out of stock, there is a chance one is the wrong size. Or, if they are not factory sizes and are staggered someone may have looked up or recommended the wrong sizes for front or rear. The possibility also exists that the magnetic ring or it's sensor was somehow damaged during the install. I know it's a dumb thing, but if they are staggered, make sure both wide tires were mounted on the back on the wide rims. A lot of times it's the silliest things that get missed that can cause an issue like this.
Old 03-21-2011, 07:52 PM
Oh, one more thing. If it's the tire pressure light, (the light looks like the tread of half a tire facing you front ways) just reset it by holding in the reset button located near your ashtray. The switch may have made the light go on and it just needs to re learn the new tires. I can't recall, but I think the DSC light is yellow. As long as the light does not come once re set you are good.
Old 03-22-2011, 10:46 AM
DashingDaryl DashingDaryl is offline
Mein Auto: 2005 E85 Z4
I agree, I think you have to re-initialize your tire system when you change your tires. I read someplace the system does not actually read the actual pressure in your tire, but the DIFFERENCE in pressure from the baseline you set at initialization.
Old 03-22-2011, 10:49 AM
madurodave's Avatar
BMW Enthusiast!
Did you install the Pressure monitors and initialize?
Madurodave
My garage: 2013 BMW 550xi GT, 2007 BMW Z4 3.0si Manual, 2006 BMW 530xi
Retired: 2007 BMW X3, 1998 BMW Z3
Member of BMWCCA!
Old 03-22-2011, 04:22 PM
imz4n's Avatar
imz4n imz4n is offline
Z ENTHUSIAST
Mein Auto: 06 3.0 si Z4R
2003-2006 do not require pressure monitors, only 2007 and newer. OP has an 2003
Old 03-22-2011, 07:48 PM
madurodave's Avatar
BMW Enthusiast!
Sorry - same as my wife's 530 then.
Is the overall wheel + tire height still the same? Maybe the sensor(s) detected a change in rotation speed?
Or maybe a bad sensor?
Madurodave
Member of BMWCCA!
Old 03-22-2011, 08:26 PM
Mein Auto: Z4
Thanks a lot for the replies. I reset it this morning and it turned off, drove about 40 miles with no reocurrence. I am very pleased to find out it was something so simple. I really appreciate the helpful info!!
Old 03-23-2011, 02:48 AM
madurodave's Avatar
BMW Enthusiast!
Great - I am glad the reset worked!
Madurodave
Member of BMWCCA!
