2011 M3 Concierge to Nav not working - Bimmerfest - BMW Forums
Old 03-24-2011, 12:44 PM
mharshany@gmail mharshany@gmail is offline
Mein Auto: 2011 BMW M3
Exclamation 2011 M3 Concierge to Nav not working
brand new m3. signed up for concierge. had concierge person deliver a point of interest (POI) to my system. problem is, i can't navigate a route with the POI they send, only have option to make a phone call. had them send a couple POI's. same problem. turned car off for several minutes, turn back on, semi-reset. no fix.
fyi, if i send something from googlemaps to system, works flawless. open message and click start nav. nav also works fine with local search, etc. only doesn't work with concierge.
bmw assist, customer relations, and local advisor stumped!!! local advisor says, "u sure u r supposed to be able to nav?" RUFKM!
please help!
Old 03-24-2011, 01:02 PM
Technic's Avatar
Technic Technic is offline
OEM Audio PnP Integration
Mein Auto: 2017 M3
please help!
If MyInfo works as you stated then the answer is that the format of the Assist POI sent is obviously defective and Assist is responsible of fixing it. Both messages should have the same formatting (xml).
There's nothing you can do or anybody else in this forum.
Old 03-24-2011, 01:05 PM
my advisor and i had the same hunch and questioned concierge via my car link. they claimed they only have one format they send. ugh! now what!
Old 03-24-2011, 01:23 PM
matts335 matts335 is offline
Mein Auto: 2009 335xdrive (E90)
tell the concierge to look up the POI in google maps and send it from there. They would need your email address i believe, but they probably already have that. Of course, you have to explain why this was necessary to each new operator you received, but better than nothing.
Old 03-24-2011, 01:31 PM
Technic's Avatar
Mein Auto: 2017 M3
It is not unusual for Assist to experience glitches like this after a system update/maintenance/whatever at their end. I lost several days of BMW Search network access just because of some system update of theirs.
Just reiterate that MyInfo works and their message does not when both should have the same xml composition/format and they will escalate this issue to their technical dept. All my technical issues have been resolved by Assist, and my issues were way more complex than yours -BMW Search and MyInfo enabled in a CIC retrofit in a MY2008 M3 with CCC iDrive, something that it should be not possible at all but they accomplished it.
This will get fixed, just keep them busy.
Old 03-24-2011, 01:55 PM
Kilgore Trout's Avatar
Kilgore Trout Kilgore Trout is offline
Chicks dig Wagons!
Mein Auto: E91
That's really odd. I have a POI send to my unit at least once or twice a month and have never had a problem.
Isn't there a little icon on the left side (I forget which one) that you just click on?
2009 E91 Montego Blue w/ Gray Dakota 6AT ZPP/Logic7/Sirius/Idrive/Butt warmers/6FL/PCD/CA/6NL/Xenons
Old 03-25-2011, 07:09 AM
@matts335 - field tested. had poi sent to my email/myinfo from concierge - worked flawless! thx mate!
@kilgore - the icon was missing for nav when the poi arrived...that was the problem...only had call icon
@technic - still gonna have diagnostic on apr 7, gonna shoot data to germany, see why regular concierge format is bolo'ing in my car
thx everyone!
Old 03-25-2011, 09:46 AM
You mean I actually contributed something useful to this forum? Wow. Guess there is a first time for everyting. Glad I could help.
2011, concierge, m3, nav, route
