Old 03-21-2011, 04:48 PM
pal's Avatar
pal pal is offline
S54=Living on the Edge
Mein Auto: 2007 M Coupe, 2004 Audi T
Z4M: What to clean dust off leather seats?
So I spun out on the track this Sunday and slid off into the dusty portion of the run off area and had some of that fly into the cabin. I vaccumed off the insides and the seat crevices but there is a thin layer of dust on the seat surfaces.
What can I use to safely clean this off without scratching or damaging the (nappa?) leather before applying a conditioner? Its black leather seats if the color matters ...
Thanks guys!
Pal
Euro headers w/relocated sensors|RPI scoop|K&N panel filter|KW Clubsports w/400lb Linear Rear Springs|RE RSMs|Zeckhausen CDV|SpeedBleeders|Stoptech Brake Lines|StopTech 4-pot BBK all around|BBS RGR 18x8.5/18x10|Potenza RE-11s
Texas Mile (March, 2010): 155.4 mph
Old 03-21-2011, 06:46 PM
zkeeper zkeeper is offline
Mein Auto: 08 Z4 3.0si,11 128Msport
Wink
I think your best procedure will be to vacuum with a brush attachment...doing so lightly, but working it over seams and stitching of course. Once all loose dust particles are lifted it then can be wiped carefully with a good microfiber with a good cleaner like [I use Griot's Interior cleaner...but there are others] sprayed on the MF and then applied to seat.
Afterwards yes, then apply a good quality conditioner. I have used the McGuires Gold Class and or Connelleys from UK for years...but now recently have switched over to the Griot's [www.griotsgarage.com] Leather Conditioner and I find it better, longer lasting and soaks into the leather and stitching better. Hope this helps some...but if you get at it, the leather will not be ruined. Its pretty tough stuff...
Old 03-21-2011, 10:22 PM
STIHLBOLTS STIHLBOLTS is offline
Hat's On, Tops Down!
Mein Auto: 2013 335is
+1 McGuires Gold - That stuff does a good job.
Best regards
2013 335is Convertible
MODS:M3 Strut Brace / Smart Top Module / Ikon Lip and spoiler
VRSF Charge Pipe /
BMWCCA Member
Previous: 2004 3.0 Z / 2008 Z4M
Old 03-22-2011, 06:03 AM
JonM's Avatar
JonM JonM is offline
Moderator
Mein Auto: 01 Mc, 08 M3, Motorrad x2
Vaccuum with a soft bristle brush, but pat the vaccuum on the leather, don't drag it across.
Then wipe with a very damp cloth.
Then pat dry.
Repeat the damp cloth if you have to.
Jon Maddux
08 E90 M3 | 06 M Coupe | 01 M coupe | 99 M coupe
http://coupenut.blogspot.com/
http://x5nut.blogspot.com/
Old 03-22-2011, 11:18 AM
pal's Avatar
pal pal is offline
Thanks guys.
JonM- I thought water and leather are not a good combination? Will I mess up the leather?
Old 03-23-2011, 07:50 AM
JonM's Avatar
Moderator
It might if you leave a lot sitting on it for a long time. If you dry it, no problem. Cows get wet all the time.
Jon Maddux
Old 03-23-2011, 07:29 PM
No problem on the water issue...and agreed, just don't let leather sit and get wet and stay wet. You shoes get wet all the time, and they survive unless you let them get wet and stay that way. The tanning oils will keep it protected, and it gets wet often when you get in on a rainy day and sit down with a wet coat and often its that way for a loooot of minutes.
BUT once dried off, be sure to re-feed the leather with conditioner. In fact it ought to be done every couple months or so...depending upon where a oerson lives and what the weather is. In Arizona?? Imight feed it every 60 days or so...here in St.Louis area, maybe 3 times a year. Keeps the leather soft and protected. Good luck with it...
Old 03-24-2011, 08:59 PM
Wheaton2010 Wheaton2010 is offline
Have Fun... Life is short
Mein Auto: 2006 BMW Z4 3.0si
I would vacuum first to get the big stuff. Then, with a compressor and an air "wand" blow out the crevices. You can get a wand for about $10 at an auto parts store. They are about 18" long and have a very small hole for the air to come out. Wipe it down with a damp cloth and use an auto leather conditioner as mentioned above.
I detail my cars so that they always look brand new. I don't know what I would do without my air compressor. It gets the dust out of all the air vents and hard to reach places.
Old 03-26-2011, 07:15 AM
pal's Avatar
pal pal is offline
Thanks guys. Planning to go with Murphy's Oil Soap for cleaning the seats and then use a conditioner - either the Coach stuff or the VW german leather conditioner. One of the local Z4Mers suggested the Lexus leather conditioner - may even take a run at that if I can get off my lazy bones.
Good idea on the compressor to blow off the tiny dust particles - I dont have one, but I will use the compressed can of air that I use on keyboards A little geeky, but it should do the trick.
Old 03-27-2011, 02:28 PM
For about $300 you can get a great Makita air compressor. I have the one below (see link). Maybe you can get it cheaper somewhere else. I like the Makita because it is extremely quiet compared to others.
You can get one that is louder for a lot less. Possibly in the $150 range.
I use the compressor for everything, especially for cleaning the cars. It gets under the seats and places I could never reach in the engine compartment. Couldn't live without it.
http://www.amazon.com/Makita-MAC2400...1260683&sr=1-1
