E34 (1989 - 1995)
Old 03-28-2011, 08:06 AM
Monsignor's Avatar
BMW CCA Memeber #445389
Mein Auto: Sig
Anybody wanna lend me tools?
Hey guys, I was wondering if any of you have fan removal tool and cam sprocket turning tool that you'd like to lend. I'll pay shipping and will be sure to have them back to you in good time. Were all buddies here and I figure you guys could help save me some big bucks.
Sent from Joe's iPhone using BimmerApp
1995 525iA 250k mi
2003 350Z 90k mi FOR SALE
2014 F-150 9k mi
Instagram: @Titan_E34
Snapchat: Titan_E34
Old 03-28-2011, 09:50 AM
ricks5series ricks5series is offline
Mein Auto: 525i, Corvette, 530i
Do you at least have an open end 32mm wrench. If so you can try this technique I've seen on YouTube.
Spray the nut with liquid Wrench an hour prior, attach the wrench and give a good smack (clockwise) with a heavy mallet. Seems to work 50% of the time. Seem the sudden impact breaks free the nut. The video showed that pulley didn't even need to be secured.
If I find the video I'll send it to you.
Old 03-28-2011, 10:40 AM
Monsignor's Avatar
Mein Auto: Sig
I have the wrench, I also have on blaster (catalyst) and a decent hammer. I'll try this. I sprayed the bolt a week ago, I'll try it again, spraying it again, an hour before.
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 03-28-2011, 11:11 AM
Found it!
Good luck!
Old 03-28-2011, 11:29 AM
injunmort injunmort is offline
Mein Auto: 1990 525, 1991 535
use a strap wrench or a large pipe wrench to hold the fan clutch. remember that the nut is left handed and to loosen you will turn it to the right while facing it. they generally come right off as they are only torqued to about 12 ft/lbs.
Old 03-28-2011, 12:55 PM
Monsignor's Avatar
Mein Auto: Sig
I know the nut is reverse. The problem is that it spins with the clutch. I don't have the holding tool. I have a 32 mm wrench, and I think mine is a bit more than 12lbs. You're actually the first person I ever Spoke to who regarded doing this job with any ease. I'm going to lube it up, put the wrench on it, and tap tap tap at it with a hammer until it comes loose.
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 03-28-2011, 01:34 PM
It's not tap, tap, tap, its one big smack! otherwise the pulley will just turn with the tapping. You need that initial impact to release it.
Old 03-28-2011, 01:40 PM
Monsignor's Avatar
Mein Auto: Sig
Gotcha. I noticed that in the vid.
Much thanks rick!! Comin through in the clutch again
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 03-28-2011, 02:31 PM
Bob Eddy Bob Eddy is offline
530er
Mein Auto: 530i
You could be VERY carefull and use an air chisel on the nut. You had better be good with air tools though...
Old 03-28-2011, 02:43 PM
Monsignor's Avatar
Mein Auto: Sig
Don't even have an air chisel
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 03-28-2011, 03:42 PM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
The hammer smack procedure may work if you leave the serpentine belt on. My experience is that the nut is hard to break loose until the fan pulley it secured with the proper tool. Oh and BTW, don't try the strap wrench on the pulley itself. I ceremoniously screwed one up that way
Steve
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 03-28-2011, 04:09 PM
On the E39 side of the house, we make our own tools for less money than it would cost to ship the $20 professional tools themselves ...
Here's the reference from the VERY best of E39 Links if you need it:
- How to make your own BMW cooling system overhaul fan clutch nut counterhold tools (1)
Notice in that thread you can use a garage door plate, a stock steel plate from Lowes, a cheap plumber's tool from Home Depot, etc.
Old 03-28-2011, 06:42 PM
Banned
Mein Auto: car
I think Bluebee and the rest of the solid gold dancers are so cool! Saved that link...
