Old 03-28-2011, 09:47 AM
markobb markobb is offline
Mein Auto: Z3Q, 2.8L, 1999/2
Changing front plastic glass from, head light?
Is it possible to replace only a plastic transparent front of the headlight couse its scratched?
Old 03-28-2011, 10:53 AM
khammack khammack is offline
Warning - Thin Air
Mein Auto: 2002 M Roadster/2014 435i
I guess you could, but it would be a real pain because the headlight is a unit and I don't think anyone sells just the cover. You could also try one of the headlight polishing kits on the market now, or just replace the entire unit.
2014 435i M-Sport, Mineral Gray, Black Dakota Leather, Driver Assistance Pkg, Prem Pkg, Tech Pkg, 8 Speed Sport AT, Heated Front Seats, Active Cruise Control, BMW MPPK w/MPE, BMW Limited Slip Diff, BBS CH Wheels.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, Black Soft Top, Steel Gray Metailic Hard Top, TC Kline Double Adj Shocks with H&R Springs, Stromung Exhaust, SSR Type C Wheels.
Old 03-28-2011, 11:06 AM
Do you have any cool polish kit, for low price and with good effect, to buj it on ebay?
My drive BMW Z3Q, 2.8L, 1999/2
Old 03-28-2011, 11:57 AM
Skyhawk Skyhawk is offline
Mein Auto: BMW 325i, M-roadster
Depends on how bad the scratch is on your headlight, you can alway try to use some scratch X. I used that before on the Lexus headlights, I had good results from it. Or the Freight Harbor sells a headlight cleaning kit..pretty cheap.
Old 03-28-2011, 01:03 PM
dougmcintyre dougmcintyre is offline
formerly updmst
Mein Auto: 2000 M Coupe, 1997 318ti
See http://www.bimmerfest.com/forums/sho...d.php?t=526414
Old 03-28-2011, 03:14 PM
Wheaton2010 Wheaton2010 is offline
Have Fun... Life is short
Mein Auto: 2006 BMW Z4 3.0si
I don't think you can simply replace the lens. Replacing the whole headlight assembly will cost more money than you think ($300-$600 each). If you use a lens cleaner/restorer be very careful. Use a brand name and follow the instructions. If you buff or polish too hard you will end up having to buy a very expensive new headlamp.
Old 03-28-2011, 03:56 PM
tequila mike tequila mike is offline
Mein Auto: 1999 MZ3
You can sand it out no matter how deep it is.
A very deep scratch will leave a depression after final polishing.
I shallow scratch not so much.
You could take it to a place like tap plastics for polishing out the scratch.
They would likely charge $50 or so for a scratch repair and full polishing.
The kits are $20 dollars or so and are great i used one with great sucess.
You could also ignore the scratch.
Once you polish the thing you might not notice the scratch as much.
