Old 04-27-2009, 03:58 PM
TheStig TheStig is offline
Some say...
Mein Auto: N/A
^^Ewww, why did you use Electrasol??
Old 04-27-2009, 08:30 PM
mosearch mosearch is offline
Mein Auto: 528i, Y2K
oh, you prefer Palmolive?
Old 04-27-2009, 08:48 PM
Some say...
Mein Auto: N/A
No, I like Dawn. The one that conditions your hands.
Old 04-28-2009, 07:40 AM
weasel like's Avatar
weasel like weasel like is offline
Technical Graphite > ALL
Mein Auto: E39 528i 5-speed
LOL! This was when we were de-gunking our cooling system when we had to drain it of all glycol-based coolent and run distilled water for race day. Since DEXCOOL is known to degrade into what is called "mung", and accumulated in the heads, we wanted to wash it out as best as we could. Believe it or not, running the engine with this sudsy mix got all the gunk out and worked well. Of course, this car was destined for destruction so we weren't too concerned about engine longevity, but she ran at full tilt for 2 days in the South Carolina sun after that! We destroyed the transmission before the 4.9L V8 went!
Rules to live by:
- Fast, reliable, cheap. You can only have two.
- BMW: Just because you can afford to buy one, that doesn't mean you can afford to own one.
Old 04-28-2009, 09:59 AM
JoeFromPA JoeFromPA is offline
Mein Auto: 01 M5, 08 535xit
OP - You need to do a comprehensive, and multiple times, flush of the trans system and cooling system if you plan on keeping this car for awhile.
A little bit of leftover ATF (i.e. a few ounces) in the cooling system isn't going to kill your engine, but coolant in the ATF will kill your trans. Just flush both with about 3x the amount of fluid it regularly needs, and I'd definitely recommend using a synthetic ATF for your final fill.
If your trans is working fine now, and your engine hasn't overheated, then you don't have much to worry about as far as existing damage goes.
Coolant just completely removes the ability of oil to lubricate.
01 m5 - 118k miles 1/2013....08 535xit - 85k miles
Old 04-28-2009, 10:24 AM
bmw_n00b13's Avatar
Freude am Fahren
Send a message via MSN to bmw_n00b13
Mein Auto: 99 528iA
Dishwasher detergent may not be what you want in your engine; it's far more reactive than dish soap. Palmolive would be a far better choice :S
'99 528i ('98/12 build). 174,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals
'99 540i (grandfather's)
Old 04-28-2009, 10:54 AM
ascott ascott is offline
Mein Auto: 1999 540i
Dishwasher detergent doesn't foam up. Regular dish soap does.
You can also flush with simple green. You just don't leave it in there very long and flush it really well with clean water afterwards.
Old 04-28-2009, 01:08 PM
2002Dinan5 2002Dinan5 is offline
Mein Auto: X5 & 540i
Does anyone know if there can be possibly more than one place where coolant can mix with tranny oil with 540iA transmission? Some one mentioned busted pinion could leak coolant into the tranny but I still don't see how that can be possible in 540iA. I need some advice from someone familiar with 540iA automatic transmission.
Old 04-28-2009, 01:58 PM
poolman poolman is offline
Mein Auto: 525i station wagon
Good luck using that tranny---coolent will melt the clutch packs in a heart beat--hope it works for you---but evne a couple of spoonfulls of the stuff in your tranny will ruin it
Old 01-01-2010, 04:09 AM
Kheng Kheng is offline
Mein Auto: 2003 e46 318i
hey,
look at my rad pics
what is causing. is the coolant mixing with the atf.
http://i975.photobucket.com/albums/a...s/DSC01927.jpg
http://i975.photobucket.com/albums/a...s/DSC01925.jpg
http://i975.photobucket.com/albums/a...s/DSC01924.jpg
http://i975.photobucket.com/albums/a...s/DSC01922.jpg
http://i975.photobucket.com/albums/a...s/DSC01920.jpg
but my engine oil is clean..
http://i975.photobucket.com/albums/a...s/DSC01921.jpg
Old 01-01-2010, 06:13 AM
gtxragtop's Avatar
gtxragtop gtxragtop is offline
Mein Auto: 2003 530IA
I'd like to know what the heck a "busted pinion" is that could cause coolant and AFT to mix
In general terms for many years in all automatic transmissions I'm aware of which were primarily domestic, there is a heat exchanger in the radiator where the transmission oil is cooled (and heated more quickly when cold). If this leaks, then AFT and coolant will mix.
When the engine warms, the coolant becomes pressurized and will force coolant into the ATF. When the engine cools, a slight vacuum is created and this could suck ATF into the coolant. It is also possible with a cold engine that the slight pressure of the ATF flow force itself into the coolant.
If the transmission cooling lines enter the radiator, then the ATF is cooled by the coolant.
- Replace the radiator
- Flush out the engine coolant using the PROPER engine flush
- Flush out the transmission AFT as others have noted. As others have noted, getting the transmission well flushed is the most important.
[IMG]http://www.**************/Classroom/Images/Cooling-Radiator.gif[/IMG]
Ever wonder why 5 series electrical issues are common and complicated.. Spend time here and you will understand why. http://www.bmw-planet.com/diagrams/r...9new/index.htm
Old 01-03-2010, 05:48 AM
john_p john_p is offline
Mein Auto: 2004 M3 Convertible
Originally Posted by Kheng View Post
hey,
look at my rad pics
Hey Kheng,
I am having exactly the same problem with my 2000 328, steptronic - oil is fine but mustard-coloured contamination of the coolant.
I will be taking the car to a garage for checks but I wonder if we are having the same problem as 2002Dinan5 had .. leak within the ATF heat exchanger. I will post if I get any more info.
Old 03-30-2011, 08:39 AM
john P
replaced Gasket but still had issues. the i used thermagasket and its been over a year no issues.
Old 03-30-2011, 09:59 AM
I realize this is a resurrected thread so I will just point interested individuals to the common set of tests one can perform when they have oil in their (chocolate) coolant:
- Combined summary advice for major decisions when a cooling system overheating caused suspected blown head gaskets, cracked heads, a warped block, cam seizures, contaminated bearings, coolant hydrolock, or piston, ring, and valve damage (1) (2) (3) & advice previously given to people faced with similar blown engine problems (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) (13) (14) (15) (16) (17) (18) (19) (20) (21) (22) (23)
Old 03-30-2011, 11:18 AM
BigCo540i's Avatar
BigCo540i BigCo540i is offline
The Usual Suspect
Mein Auto: 98 E39 540i
Originally Posted by ascott View Post
Probably because it really isn't relevant. Due to wear and manufacturing variances and even the temperature of the engine when you do the test, it's going to vary. The important thing to check is if the cylinders are all within 10-15% of each other.
Good point-
Old 03-30-2011, 11:36 AM
Wonder how this all played out?
Old 03-30-2011, 02:56 PM
sferley sferley is offline
Mein Auto: 540iT, Brabus
wonder if i should add this to my list of items to replace while engine is out of car.. as per other post...
Old 03-30-2011, 04:18 PM
MSPORT540I MSPORT540I is offline
Mein Auto: 540i Sport
Hey now,I had the same problem with that crap in my expansion tank,but it ended up being tranny fluid due to the crappy stock trans cooler going bad.. Not sure about yours but I would definately check it out..
C Burkett - 2000 540i Sport
Old 11-13-2011, 03:27 PM
windsmith windsmith is offline
Mein Auto: 1999 540iT
I had this issue, but not quite to the extent of the 'chocolate milk' coolant. I just purchased the car ('99 540iT, 107,000 miles) with a known 'no reverse' issue, so I've really looked closely at what needs to be done. While doing so, I noticed the o-rings in the cooling hoses and expansion tank cap were swelling, and there was a thin sheen of oil floating on the coolant. I flushed it clear, and then ran it up to temp with clear water. What came out was milky / red tinged and had the odor of transmission fluid. So, I've ordered a new transmission cooler to go along with the valve cover gaskets and complete cooling system overhaul (with the exception of a new radiator, as it appears to have been replaced recently). Fortunately, there was no water in the transmission.
The point here is that the ATF caused the o-rings in the cooling system hoses to soften and swell. The implications aren't good for those of us that have seen this problem and not replaced the hoses and coolant sealing o-rings.
