Key wont turn
My key wont turn from positon zero unless I pump the brakes for abot 30 seconds, it sounds like air is coming out of my front defrost vents on the dash. After a while the key starts and the car runs normal. Any ideas before I take it to the shop?
Vacuum leak in the booster pump?
Looking for a DIY? Parts? Check this out, it might be your ticket TMS underdrive pullies - Stewart WP - PSS9 - Beisan Vanos seals - Zimmerman cross-drilled & Akebono Euro - Deka 649 MF - 55w HID headlights - 35w HID foglights - Hualigan double din - ACS (rep) alu pedals - Euro central storage console - Breyton Magic Racing staggered wheels - M5 bumper - M5 steering wheel - Tint Stable: e39 M54, e53 N62 & Tribby |
is that expensive, would it also cause the check engine light to come on?
I cannot imagine a link between the ignition switch and the brake pedal.
Ed in San Jose '97 540i 6 speed aspensilber over aubergine leather. Build date 3/97. Golden Gate Chapter BMW CCA Nr 62319. |
Next time it happens, jimmy the steering while while turning the key.
Sent from my iPhone using BimmerApp |
Dunno what the problem is ... but others have had the same problem and have been given similar advice ...
So it behooves you to see what they did (and what they were told). A quick /steering wheel(F3) in the bestlinks nets me the following. As a courtesy to you, I highlighted the reference in red which you might be interested in ... - What to do when both your automatic steering wheel tilt and manual & automatic driver seat control fails (1) (2) (3) (4) (5) (6) (7) (8) & related automatic steering wheel tilt details (1) (2) (3) & what to do if your steering wheel & key cylinder locks in place (1) & signs of a failing ignition switch (1) or ring antenna (1) & the BMW TIS for when the ignition switch spins but does not engage (1) & rebuilding a failed ignition switch (0) (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) & how to test your BMW E39 DSC steering wheel sensors (0) (1) (2) (3) (4) (5) & how to retrofit to a 3-spoke M-Sport steering wheel (1) (2) (3) (4) & heated steering wheel retrofits (1) & updating the life of an old steering wheel (1) & where to buy the BMW steering wheel roundel (1) (2) (3) (4) (5). |
