Old 04-01-2011, 05:32 PM
rtl1369 rtl1369 is offline
Mein Auto: 2001 530 sport
rough idle after spark plug change
Hi Everyone,
2001 530 sport
I followed the threads on this site and successfully changed my valve cover gasket and re built my vanos seals without a problem. I changed my sparks to bosch brand not NKG. The car started and ran with a rough idle. I drove a little and the service engine light came on. I pulled the battery to re set the computer. No change.
Once warmed up the idle flattens out and the car runs good. When cold the car sounds like it may be missing a little . Any advice on where to begin looking greatly appreciated.
Tim
Old 04-01-2011, 07:58 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Dis it do this before all the work? If not, something you did caused it.
The spec plug is NGK BKR6EQUP. Try a set.
Old 04-01-2011, 08:08 PM
Jimmys 530i Jimmys 530i is offline
Mein Auto: 2003 530i
Make sure the ground that goes from the coil harness to the valve cover grounding is tight. I have replaced a VCG before and had a misfire only to discover it was a loose ground.
2004 BMW 330ci Silvergray Sport Package, Cold Package, Xenon Headlamps, Premium Package, 6 Speed Manual, Build Date 9/03
Sold - 2003 325i Sedan Japanrot 5 Speed 8k Xenon Headlamps Build Date 11/02
Old 04-01-2011, 09:16 PM
WagonTheDog's Avatar
WagonTheDog WagonTheDog is offline
Mein Auto: 2000 528iAT
Rough idle at cold start-up is usually misfire(s). Rebuilding your VANOS may or may not cure such a condition, in my case it did not. I have a '00 M52TU, and while giving my VANOS the Beisan treatment cured such cold start issues as RPM dip/occasional stall/occasional limp mode, it did not eliminate occasional misfires on cold starts. I've been studying the topic extensively, and chances are you have a vacuum leak somewhere. If all your hoses, etc. are good, it could very well be your intake gasket. As those gaskets go bad, when it's cold, it's not able to do it's job properly, but after it warms up, there's sufficient expansion to restore the seal. If this is your problem, the situation will only continue to deteriorate, as it takes warmer and warmer temperatures to keep that gasket functioning.
"Experience is a hard teacher because she gives the test first, the lesson afterwards."
Old 04-01-2011, 10:39 PM
Nice.
I'm going to add that to the misfire diagnostic tree:
- How to diagnose a typical BMW E39 engine misfire (1)
So far, after reading over a hundred misfire threads, I've added all that has been suggested, as best I could, so that thread is both complete and consistent.
Old 04-03-2011, 02:22 AM
smallie smallie is offline
Mein Auto: 1999 528i
Vacum leak???
Possible vacum leak.....????
There was a volentary recall on my 1999 528i in 2002 for hoses that were no good and caused a condition that you have explained.
Is it possible that during your gasket and vanos repair that a vacum hose may have been disrupted??
Just a thought.
Todd
