Old 04-08-2011, 08:40 PM
franka franka is offline
Mein Auto: E39 540i Sport
Its the immediate help that was asked for.
Frank
540/6
Dirrezas (4) @ 275/35-18, Eibach springs & bars, Bilstein Sports, Dinan Stage 2, slotted ATEs, Hi-Temp HTP pads, SS Lines, UUC-SS, White/Tan, Bling-free & Stealthy
Old 04-08-2011, 09:04 PM
Whorse Whorse is offline
Mein Auto: e30, e39
Wow I never believed in stuff like that. Too scared things get clogged up and such. But after reading those stories I'm surprised. I wonder if it would of worked on this old e30 I had, compression from the cylinder was making its way into the cooling system and I was blowing up radiators every month. I didn't know since oil and water wasn't mixing and water apparently wasn't making its way back into the cylinder. I noticed a cheapo radiator swelling up in size and got the clue that the head-gasket took a dump.
Do they make different sealers depending on the type of head-gasket leak? ie: i have an old m20 that leaks from oil the outside of the head-gasket. Its not making its way into the cooling system or the cylinders.
Andreas
Queens NY
BMWCCA# 186796
86 325es (wrecked by careless driver)
87 325 300k (project for life) aka 1BADETA/Christine
00 540is 6spd 202k (daily driver)
Old 04-09-2011, 04:44 AM
I answered your questions in my post # 23. As I stated, they make 4 types of products for just blown head gaskets and cracked heads & blocks, alone. They also make multiple products for oil leaks. And other multiple products for other specific problems/items like radiators, etc.
1) Read post # 23, page 1. 2) Follow the instructions therein when you click on the link. 3) Call them if you still have questions.
Frank
540/6
Old 04-09-2011, 04:53 AM
ncmallard78's Avatar
ncmallard78 ncmallard78 is offline
Mein Auto: BMW 2003 540i m-sport
are you gonna drive this thing for a couple of years, or are you going to flip it? If you are going to drive it, buy the used engine and run it. you will have a cheap and reliable car. if you are going to sell it, you are better off parting the car.
Old 04-09-2011, 06:18 AM
This is just my opinion. I don't think we have the required information to make economic and reliablity judgements at this point. I believe there are just too many unknowns here to be able to draw such conclusions.
Besides not knowing many factual matters we don't even know what the owner's intentions are. And they could change, for a variety of reasons, as he or this project goes forward.
There are many factors operating in this situation.
Frank
540/6
Old 04-09-2011, 07:24 AM
TemporarySanity's Avatar
TemporarySanity TemporarySanity is offline
Mein Auto: 2000, 1995 540iA, 07 525
I used the Bars Leak because the engine had 250,000+ miles on it and the rest of the car wasn't worth much more than a $12 bottle of the stuff. That being said, I wouldn't rely on it in my daily driver. I would use it in a pinch but would still plan on changing the head gasket or block to be safe.
I discovered I scream the same way whether I'm about to be eaten by a great white shark or if a piece of seaweed touches my foot.
Old 04-09-2011, 07:51 AM
Frank has a great point.
A few weeks ago, I felt badly about the fact that people were coming in (more and more) with symptoms of an overheated cooling system which damaged the engine (in a variety of ways) ... yet we didn't have a comprehensive answer for them that outlined ALL their options in one fell swoop.
Since then, I've spent probably ten or fifteen hours compiling & summarizing the suggestions from scores of sad threads into the bestlinks. For example, here are just the last two dozen ruined-engine threads that I tried to cull the available options from (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) (13) (14) (15) (16) (17) (18) (19) (20) (21) (22) (23) (24), all of which had symptoms of suspected blown head gaskets, cracked heads, warped blocks, cam seizures, contaminated bearings, coolant hydrolock, or piston, ring, and valve damage.
However, to the point of Frank's suggestion, none of those (IIRC) mentioned successful use of the stuff Frank proposes! So people are getting incomplete information. More importantly, lots of people are getting an incomplete list of their options. We need to improve on that.
The problem is getting this new information to the people who need it. Just having it in 'this' thread, won't solve that problem!
For lack of a better method, I recently opened this thread which might help the OP:
- What advice should we provide when a newbie asks for help with a blown E39 engine?
But, 'that thread' had NOTHING about this new (to me) option (which wasn't listed in the sad stories I had read).
So, I'll add Frank's suggestion to that list of options once I analyze what's at Frank's suggested link in post #23. At least, it will be there, if/when we point people to it for a list of their options.
Thanks Frank!
Old 04-13-2011, 10:31 PM
Jeff3344 Jeff3344 is offline
Mein Auto: 97 528i
Post It Worked!!
Guys, the blown headgasket was confirmed by a reliable tech as I previously stated. I was very lost and at my wits end. The last post informing me that they had used the Head Gasket Repair was a last chance. I purchased the product and followed the instructions carefully and....It worked!! The car is running great! It is not pushing coolant out and the oil is clear and clean. It is not running hot and I have put almost 300miles of stop and go etc. It seems so far to be holding..Now, I know ethically I need to reveal this if I sell it, but I think I am going to keep it a year, drive it and then sell it, revealing that then that I did do this fix. I like the car and it has become a project, but they are great cars if taken care of. I know this might only be a temp solution, but it is worth a try. I am going to check back with my engine guy in a few months and gauge his desire to unload the motor with 110k on it at a reasonable price. If so, then I will do the full engine swap. The car has much appeal to me and the fact that you guys are so much help, I really feel that I can take care of anything that might come along. The next project is the LCM. I have read the blogs on it and purchased the resistors (I think that is the right term) and I am removing the LCM as we speak and I am going to have a electronics guy remove the bad resistors (solder) and go from there. Any further advice will be greatly appreciated, especially concerning my need to fix this LCM. Thanks
Jeff
Old 04-13-2011, 10:47 PM
Mein Auto: e30, e39
Awesome This thread made a "non believer" a believer. now im praying i will never have ti use this stuff
Andreas
Queens NY
BMWCCA# 186796
Old 04-14-2011, 04:14 AM
Jimmys 530i Jimmys 530i is offline
Mein Auto: 2003 530i
Great, I hope it holds up. Engine swaps are not fun at all.
2004 BMW 330ci Silvergray Sport Package, Cold Package, Xenon Headlamps, Premium Package, 6 Speed Manual, Build Date 9/03
Sold - 2003 325i Sedan Japanrot 5 Speed 8k Xenon Headlamps Build Date 11/02
Old 04-14-2011, 11:33 AM
Glad to hear you gave it a try before more difficult and expensive fixes. And that it worked as advertised, as I had heard that it would.
Please update us in a few months.
Frank
540/6
Old 04-14-2011, 11:08 PM
elvistopic elvistopic is offline
Mein Auto: bmw m5 e39
there was the air in the system ,,, then u blow head GASKET .....the first thing u should drain the air from the
COOLANT LINES GOOD LUCK
Old 04-15-2011, 07:50 AM
Mein Auto: 97 528i
Smile Thanks to All
Thanks, I did all of that and installed the gasket repair kit as described later in the blog. All is working fine and I now have learned so much from you guys!! It's running great and I am keeping every body part crossed that it will remain the same! Any input on repairing the LCM
module? I could use all the help that I can get!
Jeff
Old 04-19-2011, 08:32 PM
Mein Auto: 97 528i
Guys I Need Help Again!!
Guys, I am baaaaack!! I have fixed the head gasket problem (Temp as it may be) and everything has been working great!! Well I have attacked the LCM problem by going to the link that you guys gave me and ordered the parts. I followed the instructions concerning removing, ordering of parts etc. to a T. Well, I had a professional install the chips (I have 7 extra if anyone is interested) and put the LCM in following the exact instructions. No sooner did I install the unit and hooked up the battery and started the car, the vent fin on top started to get warm. Before I could get the unit unplugged, it literally started burning at the opposite side of the unit from where the chip was installed! I went over every inch of the unit making sure the clips were correctly installed on the fin and that nothing was grounded etc. The chips are the exact make and model per the instructions and links I was given. Does anyone have any ideas on what could of caused this? Secondly, does anyone know where I can get and LCM part # 8-377-874, LCM II ? I am so disheartened at this point! I detailed the car this weekend and it looks awesome! I have given her much love and yet....I just need to get over this hurdle! Any help, you guys have been wonderful!!
Jeff
Old 04-19-2011, 09:44 PM
Mein Auto: e30, e39
Go back to the installer of the chips, he probably did something wrong. What were your symptoms on the lcm before repair? As for a new LCM your gonna have to spend about $450 for the module and another $100 to code it to your car.
I had a fire at the LCM, after about 8 hours of heavy rain over night, water soaked my lcm and started a fire. long story but i was able to save the car.
Its a good thing you kept an eye on it.
Andreas
Queens NY
BMWCCA# 186796
Old 04-20-2011, 03:55 AM
Jeff
I will check my parts car today. I should have it though.
Old 04-20-2011, 06:35 AM
DrewCrewOf2 DrewCrewOf2 is offline
Mein Auto: 1998 528i
I would not put the Bars in this car. I am 68 years old and have been doing my own mechanic work for over 50 years. I have used Bars from time to time and only would do that to a worn out car you didn't care about too much. It works on radiators but is less reliable long term on cracks in the head... sooner or later they will return. My engine shop guy found me a head for $350 down here in LA area and machined back to spec for a total of about $600. I got 30,000 on it so far. 10 hours of labor at $100 per and gaskets and oil and coolant is about what I would expect IF the head is cracked. There is no way to know for sure until you got in your dirty little hands and have a sharp machine shop put it on a pressure deck and test it. There is little difference IMHO between pulling the head and doing a gasket job only and having to find a rebuildable head as well - add $300-$500 maybe for the head. 'Course these cars are legendary for everything else in the cooling system playing out on you so consider that for sure. I have had to replace the radiator, fan, resistor block, idlers, water pump, head, hoses - everything. See my fan/rad job below
Purr's like a kitten
Old 04-20-2011, 07:05 AM
540gurl 540gurl is offline
540gurl
Mein Auto: 1998 540i E39
Does anyone know of someone using Thermagasket in a Bimmer? I ordered this but afraid to try it now because the instructions call for cutting into a hose to flush the entire cooling system. Want to find out if anyone else has used it before I purchase the hose. Here is a link http://www.rxauto.com/
Old 04-20-2011, 08:24 AM
Well, you saw my post above... the reason they want you to pre-flush the system is because there cannot be rusty water or ethylene glycol (antifreeze) in the system for the stuff to work properly. You clean and flush, put fresh water in, put in the "glue", run for a while to let the stuff seal then put antifreeze back in. Good luck!
Old 04-20-2011, 08:42 AM
540gurl
I don't like the sound of that. Glue?? I may be better off just replacing the gaskets because it's obvious that the owners before me (there were only 2) didn't do anything to this car except drive it. I have already had sooo much stuff done to it and it's too late to turn back now. At least she drives and rides like a brand new car since replacing the entire front suspension. Never thought it would make that much of a difference but omg it does!!! Now if I can just find a carrier bearing that will not go bad after a month....
Old 04-20-2011, 09:01 AM
I will get on my knees and BEG you not to put it in... if you promise not to tell anybody I did that!
You never said why you were considering the stop leak stuff... do you "think" or "know" you have a bad head gasket? 2 ways to be sure, one is to have a smog shop stick their probe into the radiator tank while the engine is running. If there is a leak into the combustion chamber, the smog test probe will "smell" the exhaust... the other is to use a special air pump in place of the radiator tank cap. Here is one you can but and do it yourself for $79 bucks.
http://www.harborfreight.com/catalog...+pressure+test
Old 04-20-2011, 09:08 AM
Burning2nd Burning2nd is offline
Spinning Vinyls
Mein Auto: e39(01) e36(97)
Mechnic in a bottle .... let me ask you if you think there is such a thing?
01 540I
97 328is
live Thursday and Saturday night
www.ukbassradio.com
Old 04-20-2011, 09:13 AM
We Irish Mechanics resent that!
(giggle)
Old 04-20-2011, 09:17 AM
Spinning Vinyls
Pmsl...... Omg we use to joke about that back in the day, that's just to funny .....
Sent from my ADR6300 using Bimmer App
01 540I
97 328is
www.ukbassradio.com
Old 04-20-2011, 10:43 AM
I understand your point. I'm in my 60s too and have done more than my share of wrenching. I'm also a degreed Engr. I too felt like you too, based on old past experiences. Back when these types of products were marginal and could cause as many problems as they might fix. Back in the (not so good) old days.
Today Bars makes very specialized products. They have 4 products for head problems alone. Plus other, multiple and specialized products for radiators only, lub systems only, etc. No more one size fits all.
The tech in these products today has no resemblance to the old stuff. Bars has been in business for many years, and they are still here today, when other similar companies have died, gone, dead, kaput.
It's important to look at the Bar's Leak site. Look at a specific product. Click on 'more info' and then click on the 'tech spec sheets' and read the specifics of when, where and how to use the product. Then you can read the experiences of others that have actually used the product.
I've heard good things about the head products, especially the HG1 with carbon fibers, even before I've read the successful experiences on this and other forums. That is why I didn't hesitate to mention it here. Especially to bring it to the I6 guys that have had head woes and can't spend big bucks to replace the head.
Fortunately I haven't had to use it. But I most definitely will if that time ever comes. I will because I believe in the rapidly changing world of doing things with new technology, that we see all around us.
Frank
540/6
