Old 04-11-2011, 10:45 PM
How to test the BMW E39 pressure-controlled crankcase ventilation system (CCV)?
Long story short, we don't seem to have a comprehensive "How to test the E39 pressure-controlled crankcase ventilation system (CCV)" on Bimmerfest; and the parts to order are scattered about, as are the descriptions & videos of what typically fails in the BMW E39 CCV system.
Since there are a billion CCV threads scattered about, our first goal is to 'summarize' all the known symptoms of a bad CCV & then the reliable known methods to test the CCV operation. (This is not intended to be a how-to-replace-the-CCV DIY.)
CCV synonyms:
- BMW-specific E39 acronyms
  • CCV = Crankcase vent valve, see also PCV, OSV, CVV, & CPV but not Clutch Control Valve (should be CDV)
  • CPV = Crankcase pressure valve, the official name for the CCV, aka OSV, CVV, & PCV
  • CVV = Crankcase ventilation valve, see also CCV, OSV, PCV, & CPV
  • OSV = Oil separator valve, see also CCV, PCV, CVV, & CPV (not the same as the oil separator, OS)
  • PCV = Positive crankcase ventilation, see also CCV, OSV, CVV, & CPV
CCV Operation: (1) (2)
A properly functioning pressure control valve is designed to maintain a slight vacuum (approximately 10 - 15 mbar ) in the crankcase which assures reliable crankcase venting during all engine operating conditions.
  • The intake manifold produces vacuum
  • Blow-by gases produce crankcase pressure
    • Note the dipstick housing represents crankcase pressure (1)
    • Although some say the dipstick represents vacuum (1)
  • The CCV is simply a "middleman" controlled by intake manifold vacuum to maintain a slight vacuum under all conditions (1)
    • The positive pressure from the crankcase is removed by the CCV which separates motor oil and combustible vapor (1)
      • Oil goes back down the crankcase
      • Vapor goes back into the Intake manifold
  • ? anything else ?
Physical Failure Modes:
  • The CCV sticks in the open position (1) due to the diaphragm tearing (2)
  • The CCV hoses clog, causing pressure buildup, especially during cold weather & short trips (1)
  • The CCV hoses deteriorate, causing vacuum leaks (1) (2) (3)
  • Water freezes inside the CCV below -15C cold starts causing misfires, hard starting, & blown valve cover gaskets (1)
Originally Posted by Fudman View Post
I believe there are two primary failure modes in the CCV:
1. The CCV and/or hoses get clogged with the condensate which prevents proper flow of crankcase vapors back into the intake and/or liquid oil back into the sump.
2. The diaphram within the CCV fails creating a vacuum leak. Oil vapors get sucked into the intake creating the black smoke. If liquid oil goes into the intake manifold, you can have a very big problem (hydrolock).
Reputed Symptoms:
  • After -15C cold start, the engine misfires and stalls & will not restart (1)
    • Oil filler cap is blown off
    • Valve cover gasket leaks
    • Occurs more often on short drives
  • Blue smoky exhaust (1) (2)
    • Some say a puff of smoke on startup (1)
  • Brown sludge (1)
    • Apparently from condensation of oil vapors (1)
      • Exacerbated by colder weather or short trips (1)
    • Mayonnaise-like sludge in the oil filler cap
    • Blockage in the CCV lines themselves (1) (2)
  • Excessive oil consumption (1)
  • Engine runs rough
  • Whistling noise when you press on the accelerator (1) (2)
  • Check Engine Light (CEL) or Service Engine Soon (SES) light on
    • Possible DM faults stored: misfire all cylinders, oxygen sensor/mixture faults, etc.
  • Vacuum leak at the dipstick lower o-ring (1)
  • Too low or too high vacuum at the oil filler cap opening
  • Pressure inside the crankcase (instead of vacuum)
    • Oil shooting out the dipstick (1)
    • Smoking under the hood (1)
    • Smoke coming out of the dipstick (1)
  • Blown valve cover gasket from excess crankcase pressure (1)
  • Blown oil filter housing from excess crankcase pressure
  • Dipstick blown out of its hole due to excess crankcase pressure (1)
    • Some say vacuum holds down the dipstick (1)
  • Hydrolock due to oil ingestion (1)
  • ? what else ?
Diagnostic Procedures:
  • Paper (or a plastic freezer baggy) over the warm-engine oil-filler opening as a visual vacuum test (1)
    • Should move inward one inch or less
    • Some say it should improve the idle if the CCV is bad (1)
    • Some say you can feel the vacuum by hand (1)
  • Inflating balloon (or glove) over the dipstick as a visual crankcase pressure test (1) (2)
  • Removing the CCV "Vent pipe" from the front of the valve cover while the engine is cold and blowing by mouth to hear oil bubbling (1)
  • Manometer vacuum of 3"-6" of water at the oil filler cap opening (1) (2) (3)
    • BMW Service Information Bulletin number SIB 04 08 98
    • Dwyer Slack-Tube Manometer Kit, BMW PN: 99000001410, $145.00 (Tischer) to $196.63 (DDM Tuning)
    • Crankcase Ventilation System Check For 1994-2007 BMW Engines (1) (2) (3) (4)
  • Look for a visible hole in any of the hoses
    • Hole in the vent hose due to chafing with the alternator wire (1)
    • Hole in the return pipe (1)
  • ? what else ?
Please improve this summary so that it forms a canonical reference for all of us now, and in the future.
Note: This photograph of a BMW 530i CCV is from cn90, the original being here (Oil seperator).
ID:	274143   Click image for larger version
ID:	274156   Click image for larger version
ID:	274157   Click image for larger version
File Type: pdf CCV_Crankcase_Ventilation_System_Check_For_1994-200_BMW_Engines.pdf (512.5 KB, 5612 views)
Last edited by bluebee; 04-16-2011 at 10:21 AM. Reason: Updating with references & new information as it comes in from the team.
Old 04-11-2011, 11:15 PM
Diagram of the M54 CCV components (with annotation & corrections)
I have no prior experience with the BMW CCV system so I'm trying to identify all the components visually (for future reference).
Comparing the photo above from one of the DIYs to the M54 diagram in Realoem, a few questions pop up that others might be able to answer:
  • To me, the realoem diagram below has the #7 "return pipe" reversed in direction. Do you concur?
  • Fudman tells me his M54 does not have the small vacuum line on the ccv shown in Realoem. Do you concur?
  • For those with the vacuum line (aioros, for example), where does that #6 "vacuum hose" go on the other end?
  • What is the purpose of the #5 "oval head screw" on the CCV itself?
  • The realoem diagram has a #8 (removed from this diagram below for simplicity) that goes nowhere and has no description (it may be the clamp). Is that simply a typo?
This (slightly modified) post probably describes the CCV system the best:
0. The following numbers are arbitrary just to illustrate the concept.
  • Sea level air pressure is 760 mm Hg or 14.7 psi.
    • But let's set this as zero as a point of reference purpose.
  • And let's say the CCV is designed such that when there is a differential of 3, it opens the spring
    • Thereby allowing vapor to return to the intake manifold.
1. Crank case pressure is the same whether you measure it at the top valve cover outlet or at the oil-level dipstick because the top part of the engine cam Lobes area connect to the sump via some air channels (this is how crankcase air goes from the sump upward into the cam lobes area).
2. [The] intake manifold [creates] vacuum.
Scenario A: car warm and idling at 700 rpm:
- Atmospheric air "zero"
- Intake Manifold vacuum = "- 1"
- Crankcase Pressure: goes slowly from "1" to "3" (from blow-by)
At "-1" and "1", the difference is only 2, so the CCV is closed, but at -1 and 3, the difference is 4 so the CCV is open allowing vapor to return to the intake manifold. At the same time, liquid (oil) is allowed to flow back down the crankcase drop by drop (basically dripping, not a full flow).
Scenario B: you are driving at 3000 rpm:
- Intake Manifold vacuum = "- 3"
- Crankcase Pressure: goes slowly from "3" to "5" (from blow-by)
In this case, the CCV is always open because the minimum difference is still 6.
NOTE: Realoem may be wrong for the M54 because Fudman says, over here, there is no vacuum hose:
- Cute little trick to diagnose blocked CCV (see post #16)
Also, note most people replaced the o-ring at the bottom of the oil dipstick guide tube, and, many replace the dipstick guide but with the newly redesigned one (it has the same bore end diameter without the concentric pipes).
From RDL in CCV replacement tips:
In the new design guide tube, the concentric sleeve/ring has been eliminated so the oil dripping from the CCV goes straight into the single large diameter tube & down into the sump. It is no longer routed into a narrow channel that can easily become plugged by cool, thick, sludgy oil. ... The overall diameter is unchanged. The new guide tube has to fit in the same hole in the lower crankcase as the old guide tube did.
ID:	274145   Click image for larger version
Old 04-12-2011, 02:19 AM
BMW CCV valves look different but function the same
According to this document, the BMW CCV valves differ in looks for the various engines, but all function similarly:
- Crankcase Ventilation System Check
Old 04-12-2011, 03:18 AM
This thread is NOT intended to be a CCV DIY; but for the record, it is nice to LIST the parts most often replaced by users performing a CCV system overhaul.
This parts list was compiled from the following sources:
Cold-weather CCV parts list for M54 from Mark at EACTuning
Generic CCV parts list first attempt by Bluebee
CCV parts list from Edgy36-39 in Fudman DIY
CCV parts list spreadsheet from VitaminXX
CCV parts list from Jason5driver (includes air distribution piece)
Parts list including CCV cold weather kit from rdl
Total $220 to $235 for the following 7 to 8 items:
- Parts required to be changed when replacing CCV
  1. Pressure regulating valve (insulated cold-weather version, 11617533400 = $66)
  2. Vent pipe (insulated cold-weather version, 11617533398 = $28)
  3. Connecting line (insulated cold-weather version, 11617533399 = $34)
  4. Vent hose (insulated cold-weather version, 11157532629 = $15)
  5. Return pipe (stock version is already insulated, 11617504536 = $34)
  6. Dipstick guide tube (redesigned version sans concentric rings, 11437531258 = $41)
  7. Dipstick guide tube lower o-ring (19.5x3mm, 11431740045 = $2)
  8. Vacuum hose black (not on all E39s = $15, e.g., not on the M54)
There is a 3-component 'cold weather CCV kit', PN 11617534237, (EAC Tuning $110, BMW Parts Source $93) which contains:
$66 Pressure regulating valve (cold weather version)
$34 Connecting line (cold weather version)
$15 Vent hose (cold weather version?)
Ancillary items to consider replacing when doing a CCV overhaul:
Set of six air distribution piece o-rings 7x3mm, PN 11617502761 $0.88 each (see reference here)
Set of six intake manifold profile gaskets PN 11611436631 $63.30 (see reference here & here & here)
Air distribution piece PN 11611440318 $58.23 (see reference here & here)
Throttle body housing gasket PN (see reference here)
Valve cover gasket PN (see reference here)
When ordering less than the full complement of hoses, keep in mind what rdl said over here:
The drain hose and drain in the dipstick guidetube were plugged solid. In my case, I was able to remove the drain hose from the dipstick guide tube while in place. I used a small screwdriver pushed into the slip joint & ran it all the way around the circumference to break adhesion, then pulled the hose up & off the guidetube. It was the only hose that didn't crumble when disturbed during CCV removal.
When deciding on the ancillary parts, keep in mind what Doru said here:
those 6 little O-rings go bad. Also the profile gaskets of the intake manifold start getting "cooked".
The distribution piece, If the car is not needed for 24 Hrs, "could" be cleaned. It is hard to clean the inside where all the gunk settles, you will need to let it rest, filled with some sort of solvents that will not damage the plastic. I believe Jason said the new distribution piece was significantly lighter than the old one due to all that gunk build-up. Bimmerfiver suggested "Simple green". Maybe if one would pour brake cleaner inside, it might do the trick as well. It has to be left with the solvent until it breaks the gunk and can be cleaned out. The 6 openings are very small for a mechanical cleaning, and even the chemical cleaning "might" not be efficient. That's why Jason just changed it out.
Tools required for a typical CCV overhaul:
T-40, T-27 & T-25 Torx
6mm, 10mm, & 13mm sockets
Ratchet -1/4" & 3/8"
Extension bars, various lengths - 1/4" & 3/8"
" drive handle
Small mirror (absolutely necessary!)
Assorted flat blade screw drivers in different lengths
Magnetic pick up tool (optional)
Small blade knife or cutter (for old hoses)
WD-40
This is not a CCV DIY, but, it is nice to LIST the DIYs for future reference about CCV operation:
- DIY: Oil Line --> Vanos, CCV, ICV and Alternator Air Duct, by cn90
- CCV Replacement FYI - M54, by Jason5driver
- DIY: CCV Replacement on an M54 & Replacement of the CCV on M54, both by Fudman
- DIY: change of the CCV / Pressure regulating valve / oil separator, 99 528i, by aioros
- Crankcase/Oil Seperator (CCV) (M52), by jamesdc4
- CCV replacement tips, by RDL
- Detailed DIY for CVV Overhaul for the M52TU Motor, by Graham_E39_528i
- DIY Supplemental: Crankcase Vent (CCV) Replacement Notes and Photos (97 540i), by cerber
- Crankcase/Oil Seperator (CCV) (740i M62)
- 1998 528i CCV(Crankcase/Oil Seperator Fixed!!! w/Pics!!!, by jfive96
Old 04-12-2011, 03:40 AM
And, here are some closeup pictures of the COMPONENTS of the CCV system, in general.
Aioros' CCV "pressure regulating valve" (with the enigmatic vacuum hose):
JFive96's 1998 528i CCV autopsy picture showing the diaphragm and spring:
- CCV(Crankcase/Oil Seperator Fixed!!! w/Pics!!!
Fudman insulated cold-weather CCV and associated hoses:
Aioros picture of the old (prone to failure) "Dipstick guide tube":
NOTE: BMW redesigned these "dipstick guide tube" drain slots (1)
Coupled with RDL's plugged "dipstick guide tube":
- E39 (1997 - 2003) > CCV replacement tips
Further coupled with Jason5driver's old-and-new "dipstick guide tube" photo:
- (E12, E28, E34, E39, E60, E61) > 1996 - 2003 (E39) > CCV Replacement FYI - M54
Fudman mayonaise in the Y portion of the CCV connection to the dipstick guide tube:
Spydrz mayonnaise in CCV line:
NoMercy346 Mayo in the CCV itself:
- E46 (1999 - 2006) > CVV repair - my results w/ pics
Champaign777
picture of the new ($200 redesigned) "Dipstick guide tube":
- CCV Replacement FYI - M54 (see post #53)
Fudman's in situ "return pipe", "connecting line", & "vent pipe":
Here is a good shot of Jason5driver's "vent pipe" from underneath the 'air distribution piece", also showing the "connecting line".
ID:	274159   Click image for larger version
Name:	1999 bmw 528i CCV showing vacuum hose.jpg
ID:	274161   Click image for larger version
ID:	274162   Click image for larger version
ID:	274252   Click image for larger version
ID:	274344   Click image for larger version
ID:	274519   Click image for larger version
ID:	274573   Click image for larger version
ID:	274931   Click image for larger version
Old 04-12-2011, 04:23 AM
Fudman's Avatar
Fudman Fudman is offline
Great thread. The CCV is a very common e39 problem and to collect all the information to diagnose, troubleshoot and repair this component is much needed. One thing: the RealOEM diagram is INCORRECT. When replacing my CCV, I discovered that there is no vacuum hose attached to the CCV (02 M54). My CCV (original and replacement) had the vacuum hose connection plugged. Can't speak for other years but that was how mine was configured. Remove that yellow arrow from the vacuum hose connection and your diagram is spot on.
Old 04-12-2011, 07:15 AM
JimLev JimLev is offline
Mein Auto: 540/6, '16 Highlander XLE
Got some actual vacuum readings from an M62tu engine
I replaced my CCV a few years ago and took these readings using a Lucas Schaevitz P3061-5WD vacuum/pressure transducer. (0-5 inch water column, +/- 0.5% accuracy)
Readings taken thru the oil cap with installed 1/8" NPT fitting.
Eng Temp-----RPM---------Vacuum in inches
Cold-----------1300--------4.64" (at startup, Sec air pump running)
54C------------600--------3.61" (Sec air pump just stopped)
70C------------550--------3.58"
80C------------500--------3.37"
93C------------500--------3.32"
102C-----------500--------3.29"
108C-----------500--------3.28"
If the engine was held (1500-4000 RPM) the vacuum was 2.92"
The RPM didn't matter.
A Dwyer Magnehelic gauge can also be used, lots of them are usually on ebay, same for the P3061.
The homemade U-tube is cheaper, however you risk a remote chance of sucking the water into your engine.
Old 04-12-2011, 08:05 AM
rdl rdl is offline
Mein Auto: 530i 2003
EDIT JimLev & I were composing in parallel it seems. His post is good. If you have a commercial gauge it would me more convenient.
EDIT2: My "MeasureWC.jpg" red arrows are wrong %^&*. As drawn, they indicate CCV pressure not vacuum. Sorry for the mistake.
There is no need for or benefit from a commercial slack tube manometer to measure CCV vacuum. (BTW, "slack tube" means that one end of the manometer is open to atmosphere - a fancy name for a simple idea)
A home brew slack tube manometer will give you a reading more than accuate enough at a fraction of the cost. All you need is a length of clear tube, a bit of masking tape, some water and a ruler. A tube size that worked for the diameter of the dipstick gude is labelled 0.375 ID, 0.5" OD (3/8 x 1/2)
BMW specs for the CCV are 10 to 15 millibar crankcase vacuum at idle, which converts to 4 to 6 inches of water column.
1 Wrap masking tape into a tapered plug at one end of the tube
2 Pour some water into the "U" of clear plastic tube so that you have say 8" on each leg.
3 Remove the dip stick and slowly insert the tape plug end of the tube into the dipstick guide tube while watching the water level change in the "U". Do this slowly since if the CCV is malfunctioning and pulling too much vacuum, it could suck all the water out of the tube into the sump. Not the end of the world, but would make an immediate oil change a wise idea.
4 With a ruler, measure the vertical difference in water levels in the "U." In my example, the red arrows on the MeasureWC.jpg. This is your vacuum in inches of water column.
Note 1
In step 2 you want to be sure to have enough water in the "U." Say you start with 2" each side and your CCV is pulling 6" of vacuum. All the water will be pulled into one side of the "U" for a total of 4" w.c. which is not enough to resist the 6" w.c vacuum from the crankcase. The slug of water could be pulled into the sump, unless you quickly yank the tube off the dipstick guide tube.
Note 2
The high water will be on the engine side of the "U" for vacuum. If the high side is on the open end, the crankcase has pressure indicating a failed CCV.
Note 3
A few extra feet of length as in my example is a good idea. If you have a high vacuum & the water starts rushing toward the engine, you will have a second or two to pull the tube off the dispstick guide tube before the water is sucked into the sump.
Note 4
This measurement is not a definitive test of the CCV.
If the CCV has sludge &/or water, it could misleadingly pass or fail depending on whether the water is frozen or not and whether the orifice valve is blocked.
Prolonged driving in ambient temperature that enables the CCV & hoses to get good and hot might clear a sludged up CCV. But, you risk engine damage before the sludge cleared.
Conversely, a CCV with sludge that passes when warm/hot, could freeze up in cold conditions & cause problems.
Regards
RDL
ID:	274176   Click image for larger version
ID:	274177   Click image for larger version
ID:	274178   Click image for larger version
Old 04-12-2011, 08:20 AM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
Hello Jim, nice to see you here once in a while
Old 04-12-2011, 08:43 AM
doru's Avatar
Hello Bluebee.
Under reputed symptoms:
The freeze-up of the diaphragm WILL occur once the car was submitted to short trips and the mayo starts building up. The mayo is condensation & oil - emulsion.
I believe one has to park his car in a garage in cold conditions. The car might make it driving short distances, but has to be parked right away in a garage.
My saga: I had the mayo starting to build. It was not bad (whatever it was visible - so I cannot comment what was in the lines). Drove from Calgary to Edmonton. The temperature was between -50C to -55C all the way (-58F to -67F).
I arrived in Edmonton no problem this is a 300 km drive (186miles). The temp gauge was never at 12 o'clock, just shy. I stopped to grab a bite to eat. Started the car and the CCV blew - the oil smoke cloud wafting in through the vents. End of trip.
Previously, the car was driven in -25C and -30C with no problems. (-15 to -22F). In the city. Probably the cold drive, especially the operating temperature never reaching the optimum, had something to do with it. Probably the engine compartment never had a chance to thoroughly warm up, leading to even more condensation as the CCV system tried to separate the oil from vapors. Probably more water vapors formed, pooling heavier on the diagphragm and freezing it solid in the 5 or 10 minutes of stoppage. Also, at that time I didn't have the cold weather CCV, but honestly, in retrospect, I don't believe it would have made a big difference.
I believe, if one has to drive in cold weather, you should closely monitor the temp gauge, and actually unlock the OBC for a more accurate reading. If the temp never manages to get to the "normal" operating temperature, don't stop the car - drive it until you can park it in a garage that is above freezing. Stopping the car in sub zero environment with the engine temp not reaching the optimal value (that is parking outside) increases the risk of instantly freezing the CCV.
Since that incident, I always followed "my method" described above, and although i had some heavier (visual) mayo build-up due to some short driving distances, I have not experienced the CCV freeze anymore. I also "remove"" the mayo, once it's spotted by a few hi-way drives, again, I wait for some closer to "normal" ambient temperatures to do that. It seems that this is working for me. And my car is a DD, all year long.
Old 04-12-2011, 09:42 AM
Hi Doru, the new format over on RF seems like it's bombing. I've been mostly on RF for the last 11 years and pop in here and a few other boards infrequently.
Guess I'll be hanging out here more often, at least there is some action here.
Old 04-16-2011, 11:49 AM
Now that we've covered the basics of the CCV system, it's time to move onto the testing.
- Cute little trick to diagnose blocked CCV system... (see post #4)
Originally Posted by Rajaie
"The crankcase vent valve and 4 associate hoses fail and cause a vacuum leak. The valve gets stuck open and the hoses crack. These last 70-120k miles and usually fail 80-90k miles. Here are a couple diagnoses.
At warm idle, place a small plastic freezer storage bag on its side over the oil fill hole. If the bag sits on top or gets slightly sucked in, ~1", the valve is good. If the bag gets significantly sucked in the hole the valve is stuck open and bad. With the engine off and cold, carefully remove the hose at the valve cover front corner. Blow hard into the hole. You should hear oil bubbling in the oil pan. If you don't hear the bubbling the top or bottom hose is likely cracked. The bottom hose often breaks just below the valve connection. There can also be cracks in the other two hoses."
Here, by way of example, are my results of the oil-filler-opening vacuum test (very slight suction, maybe 1/2") from this thread with the dipstick in place & my M54 engine at idle:
And, here is the same test on the dipstick guide tube with the oil filler cap in place:
Lastly, here's my attempt at rubber banding a nitrile glove onto the dipstick guide tube (sorry cn90, I didn't have any balloons handy).
End result:
  • Oil filler cap has slight (about 1/2 inch) suction
    • Also the oil filler tube "gurgles" when I remove the oil filler cap (what does that indicate)?
  • Dipstick guide tube has neither vacuum nor pressure
    • Suction seemed barely minimal or even non existent
    • Pressure seemed non existent
Does that seem 'normal' to you by way of testing the CCV vacuum & pressure?
Old 07-01-2011, 12:54 AM
Regarding the little vacuum hose in the middle of the CCV, pay attention to the warnings from PhilH on another forum today (thanks Doru for pointing this out):
- Cold start issues, Indie VS. You
Read post #15 where PhilH says:
[The DISA] was a big problem, but not likely the cold start issue.
The Crankcase Vent Valve was apparently changed by the previous owner/ mechanic, they did not change the associated hoses with it, although the hoses were not the culprit here I did have them replaced. When they replaced the ccv they did not realize that some of these engines have a small vacuum hose attached, and some get that nipple plugged, mine gets the nipple plugged but they did not do it.
It caused one of the connections to overheat and melted the connection point, causing the small leak which wasn't enough to turn on the check engine light, into a big leak which did.
And that is why the cold start issue progressively got worse, every time I drove it melted a little more. So for all four hoses, the ccv valve and the intake runner valve it ran me $676, not terrible I think. Indie told me the check engine light was out as soon as he started it, he didn't even have to clear it.
Old 07-01-2011, 11:18 AM
microswitch's Avatar
microswitch microswitch is offline
Mein Auto: 2006 5251
I removed the old CVV parts last nite and like Fudman mentioned the little nipple was plugged on my Valve.
What I found though was the hose that goes to the oil stick was collapsed ( wish i was able to take a picture) just under the connection to the valve. I figured that it was the reason I had high suction from the dip stick/ oil cap. In fact with both on i would feel a hiss noise but if i removed the oil stick or the oil cap the noise would go away. My valve did not look to bad but the hose were more cracker like than plastic.
Another culprit was the cracked and broken throttle body intake boot. The little nipple that goes to the idle control was really chewed out.
Incidentally I called the dealer to order the intake boot. I gave the part number stamped on the old part and the dealer said " it is not what my computer say" Now I had my car since she had 23,000 miles and I know no one changed the boot or the CVV before so, stuck with the parts you remove from your car, even if the dealer say otherwise ( unless discontinued)
Old 07-01-2011, 07:30 PM
bmwdriver17 bmwdriver17 is offline
Mein Auto: 2000 BMW 328i
This really helped me thanks guys! My 540i might have a failed CCVV
Old 07-01-2011, 07:49 PM
jayster0966's Avatar
jayster0966 jayster0966 is offline
Bimmer Loyalist
Mein Auto: E24 E39 E83
Thank you guys once again for getting all the scattered info out there combined in one organized place. Great job. This will really help me keep my E39 in tip top shape as I am a firm believer in preventive maintenance is the key to a super running bimmer.
Old 07-01-2011, 11:34 PM
Thanks for understanding the intent of this thread.
For the record, today, this cn90 thread came to my attention which contains very nice descriptive pictures of the older E39 CCV hose locations:
- E39 (1997 - 2003) > Need help with Vacuum Hose location on 97 BMW 528i
For consolidation, here are the (shrunken to 640x580) photos in that thread (in case the linked sites go down in the future).
ID:	283556   Click image for larger version
ID:	283557   Click image for larger version
ID:	283558   Click image for larger version
ID:	283559   Click image for larger version
ID:	283561   Click image for larger version
ID:	283562   Click image for larger version
ID:	283563   Click image for larger version
ID:	283564   Click image for larger version
ID:	283566   Click image for larger version
Old 07-02-2011, 04:26 AM
poolman poolman is offline
Mein Auto: 525i station wagon
Along with Doru on all that Jim, good to see you back around, great insight in whats going on in each of your
posts. The vac readings you submitted are spot on, do you have vacuum readings for the engine at idle through the intake manifold? I've tried to find what the vacuum of the engine should be, but can't get a
measurment anywhere.
Old 07-28-2011, 02:05 PM
Originally Posted by poolman View Post
I've tried to find what the vacuum of the engine should be, but can't get a measurement anywhere.
I think this post by RDL has a lot of good data on how the CCV works and what levels of vacuum do what ...
The balloon test over the dipstick tube can be useful since if you find any pressure (i.e. inflating balloon) the CCV has failed.
OTOH, I think the plastic bag over the oil filler is not precise enough to measure a failure on the too much vacuum side. From my experience it pays to do the test with accuracy - and pay attention to the results .
For instance, I sarted getting a bit of a rough idle. I tried the baggy test & passed. I assumed the CCV was OK. Then I measured crankcase vacuum accurately & found 9 inches of water column vacuum; well outside the 4 - 6 inches specified by BMW. I knew the CCV was going south, but took a chance and hoped it would be "OK enough" until warmer weather arrived. A few months later I had ~45 inches w.c. (!) vacuum and most of the symptoms listed for a failed CCV. And weather around 0 F.
Here is a link describing how to measure CCV operation accurately, cheaply and in about 10 minutes.
http://www.bimmerfest.com/forums/sho...42&postcount=8
Since there have been so many questions on the topic of CCV operation and failure, here is a description of how I think the CCV operates using Bluebee's picture for reference.
The vent pipe, swirl labyrinth chamber and vent hose are always at the same pressure or vacuum - there is no valve or obstruction between them. The swirl labyrinth is the lower part of the CCV assy that the vent pipe & vent hose connect to. Further, they connect to the valve cover & crankcase without restriction and are at crankcase pressure/vacuum.
The connecting line and return pipe connect to the inlet manifold which has a vacuum of ~20 inches Hg (mercury) at idle; ~260 inches water column vacuum.
The portion of the CCV immediately beside the blue "CCV" label in Bluebee's picture is a vacuum regulator whose job it is to maintain 4 -6" w.c. vacuum in the swirl chamber.
When the engine starts, the labyrinth is at 0 vacuum (i.e. vacuum is less than 4" w.c.) & the orifice/valve in the regulator is open. The gases in the swirl chamber flow through the regulator into the connecting line (which is at high vacuum), on to the inlet manifold and through the engine. Soon the vacuum in the swirl chamber (also the crankcase to which it is connected) is sucked down to 4 - 6" w.c. vacuum and the orifice valve in the regulator closes.
The engine runs, more blowby gases from the combustion chamber enter the crankcase & raise the pressure (reduce vacuum) in the vent pipe & swirl chamber. The regulator opens again, allows manifold vacuum in the connecting line to suck them away until crankcase vacuum is back to 4 - 6" w.c. at which point the regulator closes again. And on it goes, cycling over and over.
As the blowby gas travels through the engine toward the CCV, it picks up microscopic droplets/mist of oil. We don't want this oil mist to go through the vacuum regulator, into the inlet manifold and be burned: high oil consumption and air pollution. Enter the swirl labyrinth; it causes oil droplets/mist in the blowby gases to stick to the wall of the labyrinth and drain down the vent hose into the dipstick tube and sump while the "cleaned" gases carry on through the regulator.
Now the problems that ocurr.
One
One of the CCV hoses ruptures with age and lets air into the swirl chamber. The regulator stays open in a losing battle to get down to 4" w.c. vacuum. Lots of air is sucked in through the hole, on to the inlet manifold and the ECU senses a vacuum leak - bad news.
Two
The regulator diaphram ruptures with age. Now it can't close the orifice and crankcase vacuum goes high. And/or the rupture is so large that we have enough of a vacuum leak the the ECU gets upset. Plus gaskets and seals are being pushed harder than designed may fail entirely.
Three
The CCV and hoses can get very cold in winter conidtions since they aren't heated or even insulated. Blowby gases have lots of water vapour as a product of combustion chemistry. If these gases get cold enough, the vapour condenses into water and we get sludge/mayo. The mayo/water can freeze and block the regulator orifice - either open or closed.
Stuck open - high vacuum resulting in damaged gaskets/seals (or at worst, hydrolock according to BMW)
EDIT 2 - had this sentence in the "stuck closed" paragraph:
Also, seals and gaskets can start leaking air into the crankcase - a vacuum leak according to the engine.
Stuck closed - high pressure resulting in oil leaks &/or blown out gaskets and seals. BMW warns pressure can get high enough to crack the valve cover.
Four
Again in cold weather, water condenses in the swirl chamber, sludges it up so it can no longer separate out the oil mist droplets. Then, the blowby with oil mist is routed straight to the vacuum regulator into the engine. High oil consumption and in the worst case, hydrolock.
Five
Again in cold weather, the oil draining down the vent hose toward the sump plugs up in the narrow channel of the dipstick tube. Perhaps with some mayo/sludge if the regulator isn't operating properly (see above) to get all the water vapour out of the swirl chamber fast enough before it condenses. The liquid oil backs up into the swirl chamber, oil gets sucked through the vacuum regulator into the engine. In the worse case, so much oil the engine hydrolocks.
Three, four & five being good reasons for installing the cold weather CCV kit & insulated hoses.
EDIT: six
I occurs that if the CCV fails as above, oil mist and water can condense out in the distribution piece that the connecting line attaches to on the way to the inlet manifolc. One could then replace the CCV but have enough sludge in the distribution piece that a slug of it is pulled into the inlet manifold after the repair when the CCV is perfect. Bad news.
Seems a good reason for at least checking the distribution piece when doing a CCV overhaul.
Regards
RDL
Old 08-08-2011, 04:28 AM
noup noup is offline
Mein Auto: E39 528iA 1999
My car (M52B28TU) does not have return pipe. And the connecting line is also different (there is no connection for the return pipe).
I'd like to change my CCV system and when I ordered the parts I saw the difference between my system and the new parts (different connecting line and the additional return pipe).
What happens if I change my old parts to the new ones?
What's the difference with/without the return pipe?
Does anyone have any idea?
Thanks,
Rob
Old 08-08-2011, 07:06 AM
bmw_n00b13's Avatar
bmw_n00b13 bmw_n00b13 is offline
Freude am Fahren
Mein Auto: 99 528iA
Thanks,
Rob
Enter your serial number on Realoem.com, and go to Engine -> Cylinder head. ONE of the CCV diagrams on that page will fit your car. Order parts based on that. This is for my car: http://realoem.com/bmw/showparts.do?...94&hg=11&fg=15
'99 528i ('98/12 build). 282,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals, increasing amounts of duct tape and glue
'99 540i (grandfather's)
Old 08-09-2011, 12:11 AM
It is important to note that the "oil separator valve" is NOT the same as the "oil separator"!
Today, for example, someone (effectively) wasted their money, accidentally buying an "oil separator" - when what he wanted was the "oil separator valve" (both of which are called simply "oil separator" in realoem diagrams!
- E39 (1997 - 2003) > I'm officially lost (CCV/Oil Separator) content
See also the BMW glossary list:
- BMW E39 technoterms & acronyms (1)
Where the following are scattered about :
  • OS = Oil separator (not the same as the OSV)
Note, that for various models, Realoem, confusingly, lists the "oil separator" and the "oil separator valve" both as the "oil separator":
THIS IS THE OIL SEPARATOR: (notice realoem calls it the oil separator in this V8 diagram):
THIS IS THE OIL SEPARATOR VALVE (notice realoem calls it the oil separator in this I6 diagram):
(for the 2001 540i):
THIS IS THE OIL SEPARATOR VALVE (for the 2001 540i):
It is important to note that it is MUCH MORE DIFFICULT to replace a V8 oil separator, than a V8 oil separator valve:
Old 08-21-2011, 06:17 AM
I'm not sure why this hasn't come up sooner in a thread titled "How to test the CCV", but Poolman kindly gave a warning just now in this thread:
- E39 (1997 - 2003) > Blowen head
DO NOT try the above to test if your CCV is failed!
If you are already pulling oil into the engine through the CCV, by using the above test you can pull even more oil into the engine and possibly hydrolocking the engine and finish it.
Try this instead:
  • Go back to the exhaust.
  • Run your finger through the inside of the tailpipe.
  • Does your finger come out black and oily?
  • Good start to point to the CCV.
Next,
  • Pull the spark plugs.
  • Do the tips of the plugs look black and wet with oil?
  • It's the CCV.
If the plugs come out fairly clean and maybe one or two of them (particularly the #3 cylinder) are oily, then you may have a head gasket failure.
That head gasket isn't going to fail unless the engine was extremely overheated.
Bluebee-- the basic test above is OK for when the CCV has developed a leak somewhere, but when doing the test with oil being pulled into the engine--it's like pouring out a large plastic bottle of water.
You have the water draining out then you cut a hole in the bottle and the water fall out faster--when you take the cap off of the valve cover with the engine running, you are allowing oil to be pulled through with more ease.
Old 08-22-2011, 04:09 AM
Nittenyadhav's Avatar
Nittenyadhav Nittenyadhav is offline
Mein Auto: BMW F10 520d 2016
Hi Guys,
As it is mention in this thread I went and did the CCV test with plastic on Engine oil cap area and plastic/glove/balloon in dipstic area. My finding are bit strange and I m not sure what to make out of it. When I did the test in oil cap by placing a wide plastic thin sheet it did suck bit of it so according to your guidence it is normal. Then I did the dipstick test and as per your experience it should blowup/inflate the baloon but in my case it did not inflate instead it deflate and was showing signs of air getting sucked in. Now my question is is my CCV fine or its gone bad? Should I leave it or should I getting into it to change it? Please advice thanks a mill in advance.
Regards
Nitten Yadhav
BMW 520D M Sports Plus F10
Old 08-22-2011, 04:53 AM
rdl rdl is offline
Originally Posted by Nittenyadhav View Post
Hi Guys,
Regards
Nitten Yadhav
You got a good result from the dipstick test. The balloon over the dipstick tube should be sucked inward just as the valve cover test, i.e crankcase under a slight vacuum. Even the slightest inflation would indicate +ve pressure which would be a sure symptom of CCV failure.
Better tests providing numeric results are described in earlier posts. Several months ago I measured my CCV and got a result of 22 millibar vacuum vs 15 maximum per the specification. A few weeks later the CCV had failed completely with all the usual symptoms including the CEL lit up. The two tests you have done "passed" for me although my CCV was failing.
Regards
RDL
