Does the M54 coil have a separate spark plug boot (or not)? - Bimmerfest - BMW Forums
Old 04-16-2011, 11:12 AM
I asked two days ago (in post #35 over here) but there was no response so I ask separately in case it was lost in the details.
Simple question:
Q: Does the BMW E39 M54 engine have a separate spark plug boot or not?
I noticed in the misfire DIY the following admonishment:
If the misfire moves, replace the spark plug boot
That never meant anything to me until I replaced my plugs; belatedly, I wished I had checked if that bottom part of the coil in the picture below is a separate spark plug boot (but I didn't know to test it at the time).
Is there a separate spark plug boot or not in the E39?
Old 04-16-2011, 11:13 AM
champaign777's Avatar
no
Old 04-16-2011, 11:15 AM
Originally Posted by champaign777 View Post
no
It sure 'looked' like it was one piece when I removed the coils; but Realoem lists it as two pieces (so I'm confused):
- Engine electrical system => Ignition system => Igtn. coil/sparkplug connector/sparkplug
But, realoem has been wrong in the past (all too often); and, the diagram does not look the same (it's only slightly different) as my photo shows above.
Old 04-16-2011, 11:57 AM
bobdmac bobdmac is offline
Older than old school
Mein Auto: 2001 540i/6, '90 k75s
Since it appears you can buy the "spark plug socket" separately for $13.95, vs. $85.84 for the coil, I'd guess it's a separate piece.
Old 04-16-2011, 12:11 PM
Fudman's Avatar
Fudman Fudman is offline
Correct, the lower tubular section is a separate part from the coil itself. It is called the spark plug connnector. The bottom end of the connector that connects onto the top of the sparkplug has a rubber boot on it. This is the part that rotted out when I had oil accumulate in my spark plug well.
Old 05-06-2011, 02:35 PM
Thanks for the answers.
My hands must be too weak to pull the boot off because I tried and nothing budged.
Anyway, today someone else with an M54 also had trouble separating the boot from the coil so I don't feel so badly anymore:
- HOW DO I REPLACE THE BOOT ON THE Ignition Coil
Originally Posted by moiz21 View Post
Pretty sure you just pull. If its the original boot it will be stuck on there pretty good. Just work at it.
Old 05-08-2011, 05:46 AM
Jimmys 530i Jimmys 530i is offline
Mein Auto: E92 335i
If you pull on it, it will come right off. Make sure not to punch yourself in the face when it comes off like I did.
Old 05-08-2011, 03:16 PM
MatWiz's Avatar
MatWiz MatWiz is offline
Psychology Reversalist
Mein Auto: 528
They are very hard to come off. What I usually do is I punch myself in the face before I try to separate them, to get my adrenaline going. Then I pull on them and they come off in no time.
I tried the drumming on my chest method, by it didn't work well.
mw
MatWiz
"The greatest thing about the internet, is that you can quote something and totally make up the source." - George Washington.
Old 05-08-2011, 11:37 PM
Apparently the some coil boots are removable while others are not ...
Originally Posted by oembimmerparts View Post
If the car was built on or after 09/2002 [the boot is] part of the coil and can not be replaced separately.
