Old 04-18-2011, 08:31 AM
ragal ragal is offline
Mein Auto: 2012 F01 730d M-Sport
05' 645ci convertible Logic 7 Amplifier Replacement
Hello
i come from Germany-Berlin
I got a 645ci and my sub from left, rear side are sound like he blowing up
its the amp 100% but now i tryed to open the plastic trunk cover but there's one problem:
I removed all screws etc,,, but theres 1 fiber cable that hold the cover?
how i remove him??, and
DOES Somebody have a nice guide how to replace amp????? this would be nice!!!!
gretting's from hauptstadt berlin
Old 04-18-2011, 06:24 PM
Please could someone help me!!
I used the search function but only found 1 thread and there's no guide how to replace :/
BMW Fanatic
Old 04-18-2011, 06:42 PM
Yorgi's Avatar
Yorgi Yorgi is offline
Here are the TIS instructions: Online TIS Logic 7 Amp Removal
I'll go take a few screenshots of the missing first 2 steps. I'll need to get those from my local copy of the TIS.
Here is a step by step set of instructions, no pictures but it explains that you need to unplug the fibre optic cable. coug60's Logic 7 amp install DIY
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 04-18-2011, 07:49 PM
Originally Posted by ragal View Post
Hello
how i remove him??
Seems like you may be stumped pulling off the cover. If I read this right, it is a metal cable and is nothing more than a ball end, release it by pulling the metal wire sideways out of the channel. The little ball comes out last. When you put it back in make sure and snap the little ball back into the clip all the way. Just take a look at the picture to see what it looks like with the clip removed.
Make sure you reattach all the way, this has something to do with the convertible top if memory serves me correctly.
EDIT: On a side note, the TIS program also has a special warning you should be aware of. When removing and installing the Wheel Arch Cover take extra care and confirm that the convertible drain hose is still attached. It is easy to knock it off and then you will have water ruin your electronics in the trunk.
Name:	bmw cover 004 (Large).jpg
ID:	275185   Click image for larger version
Name:	bmw cover 006 (Large).jpg
Old 04-18-2011, 11:54 PM
Yorgi's Avatar
Here are a few more TIS instruction pages. First 2 on how to remove trim and last is how to remove the amp.
'04 M3 - track
Old 04-19-2011, 05:07 AM
Hello,,
Omg, Thanks to all who help me!!, it helped me allot!
This is the best helpful forum in the world for Beamers
Thanks again...
EDIT:
Now i removed the whole cover (trim or w/e) , And Removed 5 Screws
But the Amp Dont move a bit!!!
Now i Explore , Behind the Amp are 2 screws more
But how the hell i get the screws removed?? my fingers are fat and even with the pincers i cant get it drilled
Here i tryed to show u what screws i removed:
I'm now @home
I will make later a Photo with my M-O-B-I-L-E P-HoNE
Sry for my bad english =)
BMW Fanatic
Old 04-19-2011, 10:04 AM
hmmm, I have never gone so far as to have to pull the amp out. I had removed the back carpet and arch for another issue so I am no help there. There must be something you are missing, perhaps you do not need to remove those behind the amp? The TIS shows some releases in the front.
Good luck.
Old 04-19-2011, 03:43 PM
NVM
I Fixxed the problem was i dont removed the plates under the amp
Now the amp is removed and i try to fix this by a local hifi dealer
Thanks to all!
BMW Fanatic
