E30 (1982 - 1993)
Old 04-16-2011, 06:36 PM
mzambrana78 mzambrana78 is offline
Mein Auto: 1985 325e
Oil leak
So i replaced the drain plug and washer and i still have a tiny leak dripping. Does anyine else know what it could be? The drip is right ilon the oil plug but since its new it cant be that.
Old 04-17-2011, 12:17 AM
hornhospital's Avatar
D'oh, You Kids!
Yes, it can. Take the plug out again (catch the fresh oil), clean the contact surface on the pan, put another new crush disc on it and retighten, then refill with oil.
Quotes to live by:
BMW-CCA #441426
Old 04-17-2011, 06:48 AM
Ill try that but do u think it could something wrong with the oil pan itself?
Old 04-17-2011, 05:19 PM
downhiller's Avatar
livin large
only other thing it could be, is the threads have been previously stripped and someone just replugged it. only thing if a new crush washer doesnt work is to pull out the plug, drill retap and new plug. or helicoil and jb weld and new plug
Old 04-17-2011, 05:46 PM
Or would it just be easier to get a new oil pan. I bought this car 6 mnths ago and i think it still has the original oil pan.
Old 04-17-2011, 08:35 PM
eieio4tn's Avatar
eieio4tn eieio4tn is offline
BMW...riceless
Mein Auto: 1987 325is
no, that won't be easier. crush washer is probably it. but you could teflon tape the plug if the washer doesn't fix it.
Old 04-18-2011, 01:05 PM
I had the plug and washer replaced thats why im confused why it still leaks
Old 04-18-2011, 03:24 PM
Pennyw1se Pennyw1se is offline
Mein Auto: 1988 325e
Im with downhiller on this one.
Old 04-18-2011, 05:22 PM
a930rocket a930rocket is offline
Mein Auto: 1991 318is
A new pan would be easier than welding a new bung on there. You'd have to pull it any way to weld it on there.
Tap and re-threading might allow shavings in the pan as well.
Try the Teflon tape, but plan on a new pan in the future...
1991 318is
1987 911 Turbo
Old 04-18-2011, 05:39 PM
Yeah its 25 yrs old i might as well get a new one. Thanks to all for the input
